BoozeRS05 Posted December 28, 2013 Share Posted December 28, 2013 ^ Nice. Original turbo, motor and trans? EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
stm25rs Posted December 28, 2013 Share Posted December 28, 2013 The cabin is developing some rattles that drive me nuts. There is also a slight clunk over the right bumps. Everything suspension wise is tight though. 107K Cold weather has made my rattles worse, especially the one where the dash meets the driver's side A-pillar. I've found (well, actually stumbled across the suggestion on this forum) that running the windshield defroster seems to help with that one. I guess the extra heat causes enough expansion to tighten things up. I've got one that comes from the backseat area, which rattles with music, since I've got that bumpin OEM subwoofer. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted December 28, 2013 Share Posted December 28, 2013 Great suggestion there. Window heaters and defrost work to calm rattles in the dash, front and rear windows in my experience too. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
seanyb505 Posted December 29, 2013 Share Posted December 29, 2013 ^ Nice. Original turbo, motor and trans? To the best of my knowledge, yes. Link to comment Share on other sites More sharing options...
c-lo Posted December 29, 2013 Share Posted December 29, 2013 I'd be checking that turbo. i'm on number 3 now. replaced each of them around 100k miles. the 2nd had over 118k on it I think and it prolly had another week before it went. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted December 29, 2013 Share Posted December 29, 2013 I'm still on the original motor & turbo. See sig. below for details:cool: Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
seanyb505 Posted December 29, 2013 Share Posted December 29, 2013 I'd be checking that turbo. i'm on number 3 now. replaced each of them around 100k miles. the 2nd had over 118k on it I think and it prolly had another week before it went. I'm planning it's replacement: http://legacygt.com/forums/showthread.php/stage-3-build-plan-comments-criticism-welcome-218804.html Link to comment Share on other sites More sharing options...
c-lo Posted December 29, 2013 Share Posted December 29, 2013 I'm still on the original motor & turbo. See sig. below for details:cool: yah, yah....original motor here too. how are you on the original turbo still?? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted December 29, 2013 Share Posted December 29, 2013 yah, yah....original motor here too. how are you on the original turbo still?? Copy/Paste from other threads; This; Want your turbo to last as long as your motor. In short, check you oil level often & top as needed. Use whatever oil & filter that will protect for the OCI's your running. OA's is the only way you know that your oil & filter is up for the challenge. After that IMO no OA's are needed. Mike And this; Yes the filters + the oil line add 2 qts. Mine always took 5qts. to fill. Just above the full line. Now take 7qt. http://legacygt.com/forums/showthrea...ons-81741.html Pics with fender & bumper cover removed when I installed the RacerX FMIC. http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/th_0920112213b.jpg http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/th_0920112213a.jpghttp://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/th_0920112213.jpg Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
instantfury Posted December 29, 2013 Share Posted December 29, 2013 Make sure that switch isn't in a constant up or down position. Mine did the same thing and then burned out the window motor because I forgot one day to adjust it correctly. Link to comment Share on other sites More sharing options...
SBT Posted December 29, 2013 Author Share Posted December 29, 2013 Yeah - the neutral position detent gets gummed sometimes on these and then the switch gear doesn't return to "off". I always check it when I use it. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
forcedinductiongt Posted December 31, 2013 Share Posted December 31, 2013 137k mi....3k @stage 2....all is well, not one oddity Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
Zac88 Posted January 1, 2014 Share Posted January 1, 2014 170,000KM Stage 1 Going to need a new Oxygen sensor but besides that just some fun modding and maintenance stuff! Link to comment Share on other sites More sharing options...
Max Capacity Posted January 2, 2014 Share Posted January 2, 2014 My wagon just turned 181818 miles on the drive to work today. Going to VT in the snow storm after work, car runs great. But it should...$$$$$ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
stm25rs Posted January 2, 2014 Share Posted January 2, 2014 137k mi....3k @stage 2....all is well, not one oddity Sent from my SPH-L720 using Tapatalk Original turbo? If so, did you inspect it while installing Stage 2 parts, and how did it look? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted January 2, 2014 I Donated Share Posted January 2, 2014 Original turbo? If so, did you inspect it while installing Stage 2 parts, and how did it look? I would be surprised if he knows. Link to comment Share on other sites More sharing options...
forcedinductiongt Posted January 2, 2014 Share Posted January 2, 2014 Original turbo? If so, did you inspect it while installing Stage 2 parts, and how did it look? I bought the car at 125,000...but it was single owner, had almost all service records, and there was no record of a turbo replacement so who knows. I did inspect it when replacing the dp and there was no shaftplay/bent fins, I wouldnt be too surprised if it hasn't been replaced, the previous owner was an extremely modest senior just looking for a car good in the snow; probably never went over 10psi lol Sent from my SPH-L720 using Tapatalk Link to comment Share on other sites More sharing options...
c-lo Posted February 13, 2014 Share Posted February 13, 2014 about to drop some $$ on front suspension work and a power steering pump leak. just had new tires put on and turns out I have a front wheel bearing that's starting to go bad. new front end links, tie rod too. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
unclaimedwalnut Posted February 13, 2014 Share Posted February 13, 2014 Just bought mine two weeks ago and this morning on the way to work the turbo went. Dumb luck. 124k on it. Link to comment Share on other sites More sharing options...
evil03mustang Posted February 13, 2014 Share Posted February 13, 2014 Just cracked 77k... Bought with "rebuilt engine" at 61,212mi and I have replaced the turbo, transmission, water pump (seized) and timing kit. Here's hoping I make 100k without any more broken stuff. I have a spare turbo and a transmission I'm rebuilding just in case..... Link to comment Share on other sites More sharing options...
SATSFYD Posted February 13, 2014 Share Posted February 13, 2014 Running stage 1 with 84K and no engine or turbo change outs. **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
BGPKR Posted February 13, 2014 Share Posted February 13, 2014 137k on original engine and turbo. I'm doing sway bars once we get some reasonable weather. Where can those AVO brackets be purchased from? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted February 13, 2014 I Donated Share Posted February 13, 2014 Almost at 90k mi. BNR 16G has been in for the past 12k (35k-ish on it total; the rest of the miles were from my 05). Still running great, and I am not gentle either. Intake manifold gaskets have been the only non-wear/mod-related repair. Link to comment Share on other sites More sharing options...
Justin case Posted February 13, 2014 Share Posted February 13, 2014 Just about to 106k on original engine and turbo. Heads were taken off to replace burned valves when the original owner had it. Other than that she's never been opened up or had any other issues. When I purchased it I checked the banjo bolt and it was clean but I replaced it anyhow. Turbo looked fantastic last time I had the downpipe off at around 103k. For all the talk of turbo failures/ringland failures/everything else on these cars failures I've been really happy with it. *Knock on wood* Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted February 13, 2014 Share Posted February 13, 2014 (edited) Mines been rock solid for almost 1/4 million miles:cool: Edited February 14, 2014 by HAMMER DOWN Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
