MRLancaster Posted March 16, 2013 Share Posted March 16, 2013 Sold my BH9 Link to comment Share on other sites More sharing options...
BeKnwn Posted March 16, 2013 Share Posted March 16, 2013 A few weeks ago I filled the whole trunk lid insides with foam so after the seals I trimmed the foam down and dynamat'd the trunk lid sounds way better almost done fighting this rattling issues Link to comment Share on other sites More sharing options...
octain11 Posted March 16, 2013 Share Posted March 16, 2013 Sold my BH9 member on this forum? Link to comment Share on other sites More sharing options...
Sean Gage Posted March 17, 2013 Share Posted March 17, 2013 Just dropped mine off to star subaru for head gasket water pump and timing belt. I asked them to check the tranny to second has a long shift some times whn its cold?! Link to comment Share on other sites More sharing options...
BeKnwn Posted March 18, 2013 Share Posted March 18, 2013 Yeah for say the shifting mph the almost double when cold lol. When I go down town it shifts into 4th at like 35-40 rather then 32 like the book says so I end up driving around town in 3rd at 2k rpms till it warms up then it shifts so I'm sure theyres nothing wrong with your tranny I would be worried when it slams and makes grinding sounds or going up to 6k to shift out of 1st cause of slipping lol Link to comment Share on other sites More sharing options...
BrandonJ 2001 GT Limited Posted March 18, 2013 Share Posted March 18, 2013 Finally got my sub box built and fitment tested....now to get carpet and finish the install. 36"x15"x7" Roughly 1.5 cu ft http://dl.dropbox.com/u/53914667/March%2013/2013-03-15%2022.18.22.jpg http://dl.dropbox.com/u/53914667/March%2013/2013-03-16%2000.56.30.jpg http://dl.dropbox.com/u/53914667/March%2013/2013-03-16%2020.40.13.jpg http://dl.dropbox.com/u/53914667/March%2013/2013-03-16%2020.40.28.jpg http://dl.dropbox.com/u/53914667/March%2013/2013-03-16%2021.02.19.jpg http://dl.dropbox.com/u/53914667/March%2013/2013-03-16%2021.11.17.jpg http://dl.dropbox.com/u/53914667/March%2013/2013-03-17%2013.39.30.jpg http://dl.dropbox.com/u/53914667/March%2013/2013-03-17%2013.40.14.jpg http://dl.dropbox.com/u/53914667/March%2013/2013-03-17%2013.41.16.jpg http://dl.dropbox.com/u/53914667/March%2013/2013-03-17%2013.41.48.jpg http://dl.dropbox.com/u/53914667/March%2013/2013-03-17%2013.42.10.jpg Link to comment Share on other sites More sharing options...
octain11 Posted March 18, 2013 Share Posted March 18, 2013 Great handy work!! Link to comment Share on other sites More sharing options...
BrandonJ 2001 GT Limited Posted March 18, 2013 Share Posted March 18, 2013 Thanks. It's already an improvement over the old one and hasn't even been broken in yet. Link to comment Share on other sites More sharing options...
BeKnwn Posted March 19, 2013 Share Posted March 19, 2013 So I was having power issues for a long time now I couldn't redline or get anything anymore car/engine felt slow on take offs and overtaking. so I took a volt meter and tested the throttle sensor and it was working perfectl at .554volts w/ key off and on so I tighten the gas peddle wire as tight as it can go with the sensor was reading at .559volts w/ key on .But now the gas peddle is all tight and car runs amazingly and perfect I have all my power back I smashed on it to test it I got instant power and redline went from 10 to 40 in a couple seconds it was amazing to have power back I would recommend everyone else to do it if they're car/peddle feels sluggish Link to comment Share on other sites More sharing options...
BrandonJ 2001 GT Limited Posted March 19, 2013 Share Posted March 19, 2013 Where is the sensor located? Inside @ the pedal assembly or under the hood? Was there something on the sensor you tightened or did you tighten the physical cable that goes from the pedal to the TB? Link to comment Share on other sites More sharing options...
BeKnwn Posted March 19, 2013 Share Posted March 19, 2013 The sensor is on the passenger side of the throttle body there's 3 wires black/ground, red/power, yellow/signal which the yellow one is the one you want to poke with the volt meter and just find a good ground for the meter i used my tower strut bar was the best ground I could use lol while the key is on not started and I adjusted the cable on the driver side of the intake manifold set the meter to .000 so you can get a good dial in just don't go to .56v and if you hear a buzzing noise you are doing way to much lol I got probably a good 3 or 4 threads on the bolt before it was nice a snug Link to comment Share on other sites More sharing options...
BrandonJ 2001 GT Limited Posted March 19, 2013 Share Posted March 19, 2013 Yeah I noticed a lot of slack in mine...I may adjust it some after work. Link to comment Share on other sites More sharing options...
BeKnwn Posted March 19, 2013 Share Posted March 19, 2013 Yeah its night and day difference just adjust it with the volt meter in the sensor wire and key on its quite an annoying battle back and forth with meter numbers and throttle cable took me a while to get it just right lol I think the Manuel says the volts are supposed to be around .45v~.55v but mine was stuck at .55v with the sensor all away back so then I just did the throttle cable. I did notice though my P0420 CEL came on earlier then it usually does so I'm wondering if its probably from the gases not getting as hot as they should be and throwing the cel early cause I have to egg shell the gas peddle lol so I'm hoping this will help save gas possible? If I'm not smashing it around town now that I can only time will tell plus I got a lot of fixing with my exhaust anyways lol Link to comment Share on other sites More sharing options...
BeKnwn Posted March 20, 2013 Share Posted March 20, 2013 Dropping the car off at the shop today to get the windows tinted finally after almost 3 years of having the car to 35% (washington state's legel limit for sedans lol) Link to comment Share on other sites More sharing options...
rSTimpreza Posted March 20, 2013 Share Posted March 20, 2013 Installed my jdm headlights. Man it was biatch to find a reliable source how to install this on a L completely different from the DIY found here and GT legacy's. Link to comment Share on other sites More sharing options...
BeKnwn Posted March 20, 2013 Share Posted March 20, 2013 Yeah I don't get to excited either when I have to redo my projectors and halos soon lol when I got to the shop I decided to go with 20% cause its not to dark or to light lol Link to comment Share on other sites More sharing options...
Leeson187 Posted March 22, 2013 Author Share Posted March 22, 2013 I just installed my front lip spoiler. Sorry about the bad pics! It's dark and my iphone sux Link to comment Share on other sites More sharing options...
Leeson187 Posted March 22, 2013 Author Share Posted March 22, 2013 Does anyone know any info on these? Just purchased them for pretty cheap. I own a set of BBS rims that i will keep and use for my wagon but these would go to the next owner when i sell my car. Just would like to know more about em tho? Link to comment Share on other sites More sharing options...
octain11 Posted March 22, 2013 Share Posted March 22, 2013 love those rims!,they look like speedlines Link to comment Share on other sites More sharing options...
Leeson187 Posted March 22, 2013 Author Share Posted March 22, 2013 love those rims!,they look like speedlines They are speedlines! I think they are euro versions? What do ya know about em? Link to comment Share on other sites More sharing options...
4doors4hp Posted March 24, 2013 Share Posted March 24, 2013 i rebuilt my entire ej252 motor in my 00 LGT wagon with the motor in the car. no leaks. Link to comment Share on other sites More sharing options...
BeKnwn Posted March 24, 2013 Share Posted March 24, 2013 i rebuilt my entire ej252 motor in my 00 LGT wagon with the motor in the car. no leaks. Yeah thats what I did last summer its really easy but its awesome to have no leaks lol But today I installed my rear Whiteline toe/camber control arms with the toe locking kit it was really easy Link to comment Share on other sites More sharing options...
octain11 Posted March 24, 2013 Share Posted March 24, 2013 They are speedlines! I think they are euro versions? What do ya know about em? I don't know about those exact versions, but I have always wanted speedlines, they are very high quality rims, expensive and rare to find in the States. Subaru Rally team used Speedlines in the WRC. Link to comment Share on other sites More sharing options...
Leeson187 Posted March 25, 2013 Author Share Posted March 25, 2013 I don't know about those exact versions, but I have always wanted speedlines, they are very high quality rims, expensive and rare to find in the States. Subaru Rally team used Speedlines in the WRC. Thanks for the info. I guess I'll keep em forever or for my future Subie! I love Subaru's Link to comment Share on other sites More sharing options...
BrandonJ 2001 GT Limited Posted March 25, 2013 Share Posted March 25, 2013 I did this.... http://dl.dropbox.com/u/53914667/March%2013/2013-03-24%2019.58.07.jpg Actually that was last night. There were a few more inches this am. http://dl.dropbox.com/u/53914667/March%2013/2013-03-25%2009.31.26.jpg Link to comment Share on other sites More sharing options...
