Leeson187 Posted February 28, 2013 Author Share Posted February 28, 2013 Thanks to some of you guys, i got new shoes for my BBS rims (BFgoodstuff) sport comp 2 Link to comment Share on other sites More sharing options...
Leeson187 Posted February 28, 2013 Author Share Posted February 28, 2013 What does everyone think about VLED's in the hood scoop? http://www.vleds.com/strip-lights-led/exterior/blue-exterior-waterproof-led-strip-lights.html Link to comment Share on other sites More sharing options...
BeKnwn Posted February 28, 2013 Share Posted February 28, 2013 here's the brakes and stuff still gotta do a lot of work to get everything working right new/old compare front rear on with old summer tires front rear 215/45/17 w/o rolled finders the key is the only thing i can find that fits snug between them only a lot of rubbing till i can get it rolled only if the rain ever stops so i can use the damn heatgun i also should be getting my whiteline rear toe/camber control arms today and rear diff inserts that i hope will work so then i can do a guide for it lol Link to comment Share on other sites More sharing options...
Lwolf25 Posted February 28, 2013 Share Posted February 28, 2013 Installed lowering kit and roof rack. Link to comment Share on other sites More sharing options...
BeKnwn Posted February 28, 2013 Share Posted February 28, 2013 Installed lowering kit and roof rack. Nice how did it turn out and how do you like them? Link to comment Share on other sites More sharing options...
octain11 Posted March 1, 2013 Share Posted March 1, 2013 What does everyone think about VLED's in the hood scoop? http://www.vleds.com/strip-lights-led/exterior/blue-exterior-waterproof-led-strip-lights.html my personal opinion, i don't like anything that has to do with taping LED's on car, but that is just me, dont let that stop you from doing what you want Link to comment Share on other sites More sharing options...
Lwolf25 Posted March 1, 2013 Share Posted March 1, 2013 Nice how did it turn out and how do you like them? It turned out pretty well. I was actually able to use the stock bolts, washers, and nuts in the rear haha. Wasn't that bad of a job, was actually pretty easy. Just time consuming. The only thing is, is there is a small squeak sounds like the rear passenger side. Aside from that yeah, I think i like them so far. Link to comment Share on other sites More sharing options...
BrandonJ 2001 GT Limited Posted March 1, 2013 Share Posted March 1, 2013 What does everyone think about VLED's in the hood scoop? http://www.vleds.com/strip-lights-led/exterior/blue-exterior-waterproof-led-strip-lights.html dimmed...maybe It would have to be a subtle glow. But even then I'd feel like I was back to being 16yrs old again and driving my first car nearly 18 years ago. Link to comment Share on other sites More sharing options...
BeKnwn Posted March 1, 2013 Share Posted March 1, 2013 It turned out pretty well. I was actually able to use the stock bolts, washers, and nuts in the rear haha. Wasn't that bad of a job, was actually pretty easy. Just time consuming. The only thing is, is there is a small squeak sounds like the rear passenger side. Aside from that yeah, I think i like them so far. Oh not bad the squeak is something new I never had one I would swap sides see if its not a bushing/endlink do you have the stock swaybar? Link to comment Share on other sites More sharing options...
Lwolf25 Posted March 1, 2013 Share Posted March 1, 2013 Yeah pretty sure its stock sway bar. Link to comment Share on other sites More sharing options...
BeKnwn Posted March 2, 2013 Share Posted March 2, 2013 I would swap them sides then see if it happens still if it does on the same side its probably a bushing or endlink if it does switch then it could be a shock/spring but gotta rememeber to there's always going to be chassis creaks with hardened suspension Link to comment Share on other sites More sharing options...
BeKnwn Posted March 2, 2013 Share Posted March 2, 2013 Today I added some neg camber in the front, rolled the fenders, cut some of the inner plastic off and finaly got the right centering rings on the wheels. so hopefully I won't rub anymore went from a key sized space between the fender and wheel to a little more then a space of a thumb. Link to comment Share on other sites More sharing options...
BrandonJ 2001 GT Limited Posted March 5, 2013 Share Posted March 5, 2013 Yesterday @ lunch my sub finally blew after 12 years of good service. Ordered a German replacement. MB Quart PS3-304 http://images.techronics.com/MB-Quart/TEC-MB-PS3-304-.jpg And I heard some grinding from the front, so I ended up doing a warranty swap on some AZ C-Max pads(lifetime replacements for $54.99) after dark in my driveway. Sleet started just as I was finishing up putting the wheels back on. Link to comment Share on other sites More sharing options...
Leeson187 Posted March 6, 2013 Author Share Posted March 6, 2013 Installed VLEDs with a On/Off switch in the scoop. Pretty bright! Link to comment Share on other sites More sharing options...
rSTimpreza Posted March 8, 2013 Share Posted March 8, 2013 Installed and did Bilstein b4 suspension Front CV axle Whiteline 25mm FSB Rear brake pads Oil change. http://i60.photobucket.com/albums/h40/cramos502/photo_zps4faa8a9b.jpg http://i60.photobucket.com/albums/h40/cramos502/photo_zps412cca21.jpg Link to comment Share on other sites More sharing options...
EJ25_B4_RSK Posted March 8, 2013 Share Posted March 8, 2013 Watched it get pulled up on a flat bed.... It was totaled http://i52.tinypic.com/r8yv55.jpg http://i56.tinypic.com/5p4i2v.jpg http://s12.postimage.org/m4c6v0kgp/DSC03221.jpg Link to comment Share on other sites More sharing options...
rSTimpreza Posted March 8, 2013 Share Posted March 8, 2013 ^^^ sorry for your lost man. Are you buying it back to part it out? Link to comment Share on other sites More sharing options...
octain11 Posted March 8, 2013 Share Posted March 8, 2013 Watched it get pulled up on a flat bed.... It was totaled http://i52.tinypic.com/r8yv55.jpg http://i56.tinypic.com/5p4i2v.jpg http://s12.postimage.org/m4c6v0kgp/DSC03221.jpg sorry to hear man, what happened? Link to comment Share on other sites More sharing options...
EJ25_B4_RSK Posted March 8, 2013 Share Posted March 8, 2013 I wasn't planning on buying it back, I already took all the parts that had some value to them off and I'm selling them. The only think I left on was the full header back exhaust unfortunately and some small engine/ignition parts. And I was in Waterbury CT the other night when a person in a rental car ran a red light. He went around the cars that were stopped some how and T-Boned me spinning the car around 2 times and threw it up on a median. After the drive from the other car ran on foot from the scene Link to comment Share on other sites More sharing options...
SoupySuby Posted March 10, 2013 Share Posted March 10, 2013 A little late but here it is with Rallyarmor, Vht'd headlights, and LED's in the side markers. Anyone know what kind of roof rail we can get? Link to comment Share on other sites More sharing options...
BeKnwn Posted March 10, 2013 Share Posted March 10, 2013 Swapped put my 300w 2 12 kicker combo with 2 350w helix precision p12s and a alpine 1000w amp still got a couple things to dynamit and pad before turning them on Link to comment Share on other sites More sharing options...
rSTimpreza Posted March 11, 2013 Share Posted March 11, 2013 Installed outback sideskirts in my BE no short cut. Link to comment Share on other sites More sharing options...
BrandonJ 2001 GT Limited Posted March 11, 2013 Share Posted March 11, 2013 I still haven't built my box yet...hoping to sometime this week. I did break out the chrome polish and gave some attention to my badges, exhaust, and wheels yesterday. Link to comment Share on other sites More sharing options...
BeKnwn Posted March 15, 2013 Share Posted March 15, 2013 I cleaned and put on a new weather seal for the trunk and siliconed every crack and bolt hole inside/outside so hopefully this helps with my trunk leaking for good Link to comment Share on other sites More sharing options...
rSTimpreza Posted March 15, 2013 Share Posted March 15, 2013 Was driving around today with my wife and at the stop light my car started idling very low and then died. Started the car and it run fine till we got home. i decided to clean the MAP sensor and change the air filter coz i dont see any CEL for it. and this what i have discovered!!!!!!! STUPID TURBINE INTAKE installed by previous owner. Apparently after I did my little research this company specd claims that it should give you more mileage. I say its a fraud and a joke. Link to comment Share on other sites More sharing options...
