ibr_adam09 Posted November 29, 2012 Author Share Posted November 29, 2012 I was at the shop today to look at a few things and well, there's yer problem. cyl. 4 http://i344.photobucket.com/albums/p330/ibr_adam09/photo5-1.jpg http://i344.photobucket.com/albums/p330/ibr_adam09/photo4-2.jpg http://i344.photobucket.com/albums/p330/ibr_adam09/photo3-2.jpg http://i344.photobucket.com/albums/p330/ibr_adam09/photo2-2.jpg http://i344.photobucket.com/albums/p330/ibr_adam09/photo1-2.jpg Link to comment Share on other sites More sharing options...
SBT Posted November 29, 2012 Share Posted November 29, 2012 Ton of carbon buildup too. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
ibr_adam09 Posted November 29, 2012 Author Share Posted November 29, 2012 Wasn't driven hard enough maybe? lol . It had a sea foam treatment a few months ago. Last I heard, the block and heads are in machining getting worked on. The shop said as soon as they get it back, we'll reassemble. Also going to put in Super-tech Valves instead of Manley's because they were on backorder. I hoping they would get it back from the machine shop today and button everything up by tomorrow evening, but the mechanic said he wont be in tomorrow and since I prefer him to do my build, I'll have to wait until next week. Also bought this for my pass. rear coil. http://www.ebay.com/itm/Subaru-Ignition-Coil-Wire-Harness-Terminal-Plug-Set-Impreza-WRX-STi-Legacy-GT-/330737797947 Here's to another week of waiting and hoping. Link to comment Share on other sites More sharing options...
m sprank Posted November 30, 2012 Share Posted November 30, 2012 Carbon build up is normal on EJ20 and 25's. Even more on the 20's. Good ol' busted ring land. Link to comment Share on other sites More sharing options...
SBT Posted December 1, 2012 Share Posted December 1, 2012 How much does SeaFoam remove the carbon build-up on the pistons. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
m sprank Posted December 1, 2012 Share Posted December 1, 2012 No more than good ole B-12 Chemtool. Link to comment Share on other sites More sharing options...
SBT Posted December 1, 2012 Share Posted December 1, 2012 Mike - through the intake? I've always thought of B-12 as much more of an "exposed" surfactant rather than internal cleaner. Between SF and B-12, B-12 seems a lot more powerful in use. If through the intake, what's the process v-a-v SF? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
ibr_adam09 Posted December 1, 2012 Author Share Posted December 1, 2012 You can suck it up through the brake booster line or bov line. Just as long it feeds through all four runners. I wouldn't do too much at once. (Seafoam only recommends 1/3 of the bottle ) Link to comment Share on other sites More sharing options...
Max Capacity Posted December 1, 2012 Share Posted December 1, 2012 Why don't you just drive it like you stole it...won't that blow the carbon out of it. LOL My pistons had a little carbon on them, but you could also see aluminum on the tops too. here's two of mine with 154,000 miles on them. http://i185.photobucket.com/albums/x40/92Si/DSCN4759.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
m sprank Posted December 1, 2012 Share Posted December 1, 2012 Put B-12 in the gas tank. As it cleans the injectors it will get some of the carbon too. Link to comment Share on other sites More sharing options...
FJuan Posted December 1, 2012 Share Posted December 1, 2012 ^^^ 4 real? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
SBT Posted December 2, 2012 Share Posted December 2, 2012 All I know is that if you drop B-12 on plastic or resin-plastic, it immediately softens and distorts the plastic. Not sure I'd want it flying around the inside of the IM, especially in full vapor form. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
m sprank Posted December 3, 2012 Share Posted December 3, 2012 Done it already. No harm done. Link to comment Share on other sites More sharing options...
SBT Posted December 3, 2012 Share Posted December 3, 2012 Put B-12 in the gas tank. As it cleans the injectors it will get some of the carbon too. Seems like a much better approach than sucking it into the intake. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
m sprank Posted December 3, 2012 Share Posted December 3, 2012 Yes sir. Never tried sucking it into the intake, lol. Link to comment Share on other sites More sharing options...
FJuan Posted December 3, 2012 Share Posted December 3, 2012 How much of it do you put in? A whole can? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
m sprank Posted December 3, 2012 Share Posted December 3, 2012 1 can per 20gallons of fuel iirc. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 3, 2012 Share Posted December 3, 2012 I'm sure there are directions on the can, read them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted December 3, 2012 Share Posted December 3, 2012 I thought that stuff was like carb cleaner, that's why I questioned it. Seen it, just nevered used it and I may have to give it a try. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
KuntryQuestTSi Posted December 4, 2012 Share Posted December 4, 2012 I use it in my compact diesel tractor to motor oil. Run it for a a few hours and change it. seems to help a bit. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted December 5, 2012 Author Share Posted December 5, 2012 For those who want to see. I have a LV snapshot as soon as the car stalled. http://i344.photobucket.com/albums/p330/ibr_adam09/LearningView_SS_11-3-2012123231PM.jpg I'm going to call the shop in the AM to see where they're with the build. Been a month. I've rented a car for last week, a mazda 3. A camry this week and now I'm having withdraws Link to comment Share on other sites More sharing options...
ibr_adam09 Posted December 9, 2012 Author Share Posted December 9, 2012 So I should be getting my engine back early next week. Today I bleed the brake lines after doing the sti booster/mbc install. My clutch fluid was disgusting, so bleed that as well. I notice they the shaft on the slave cylinder (that pushes against the fork)has a lot of play. As if its broken. shouldnt it be solid and only move back and forth or is that normal ? Link to comment Share on other sites More sharing options...
ibr_adam09 Posted December 12, 2012 Author Share Posted December 12, 2012 Went back to the shop to order Manley rods today. Totally on impulse Just in time as well, because they're getting the engine back from the machine shop. Assembly should be complete by tomorrow and I can pick up Friday. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 12, 2012 Share Posted December 12, 2012 So I should be getting my engine back early next week. Today I bleed the brake lines after doing the sti booster/mbc install. My clutch fluid was disgusting, so bleed that as well. I notice they the shaft on the slave cylinder (that pushes against the fork)has a lot of play. As if its broken. shouldnt it be solid and only move back and forth or is that normal ? No with out the car together it will move all over the place. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gt06unlimited Posted December 13, 2012 Share Posted December 13, 2012 See now this scares me as this is the exact belt and water pump kit i have coming for mine next tues. I know you said you had a bolt come loose, but i'm doing the job myself as i can't afford to have someone else do it, aka shop. I have loctite, should i apply that to all my bolts just to be sure? Other than this, how did the gates belt perform? loctite is usually a good idea on any bolt thats doesnt specifically say not to use it. make sure you torque the water pump bolts to spec, and do it when the engine is fully cooled down. it should take a couple hours to do at least, and thats in a shop with all the equipment. so take your time and you should be just fine. the beauty of these cars is thers lots of room between the radiator and engine to work in. Link to comment Share on other sites More sharing options...
