GTEASER Posted June 9, 2015 Share Posted June 9, 2015 That sounds about right. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
fredrik94087 Posted June 9, 2015 Share Posted June 9, 2015 (edited) Nice bud!!! Very nice!! You didn't by any chance weigh them before the tires got mounted, did you? They showed up already mounted and balanced or I would have! I'll see if I can get an answer out of Konig. The wheel and tire together was about 51lbs though and I read the Motivo is about 26lbs, so it should be in the 24-25lb range. http://www.atd-us.com/files/wheeldatabook2014.pdf I tend to search for pdf information on wheels in case the technical info is listed. This search on google was "oversteer pdf" 21.2 pounds Edited June 9, 2015 by fredrik94087 "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Unsp0kn Posted June 9, 2015 Share Posted June 9, 2015 Dang that's lower than I thought! I'll have to pull one off and weigh it again on a different scale. The UPS labels said each one was 52lbs, but that might be high. Link to comment Share on other sites More sharing options...
fredrik94087 Posted June 9, 2015 Share Posted June 9, 2015 Dang that's lower than I thought! I'll have to pull one off and weigh it again on a different scale. The UPS labels said each one was 52lbs, but that might be high. packaging/wheel weights/tpms/center caps/compressed air(maybe one gram ) That last part may sound funny, but it all adds up. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
s2baru Posted June 9, 2015 Share Posted June 9, 2015 Annddddd soon to be about that lowered life Link to comment Share on other sites More sharing options...
Zee199969 Posted June 9, 2015 Share Posted June 9, 2015 That 18x9 +42 is speaking to me. someone help My "Build" Link to comment Share on other sites More sharing options...
Unsp0kn Posted June 10, 2015 Share Posted June 10, 2015 That 18x9 +42 is speaking to me. someone help I'll help by saying...Do it! Link to comment Share on other sites More sharing options...
jackal8788 Posted June 11, 2015 Share Posted June 11, 2015 Zee, you know this forum well enough to realize what kind of 'help' you're going to get VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
Zee199969 Posted June 11, 2015 Share Posted June 11, 2015 (edited) So a buddy of mine likes XXRs and now this one is on the list of probables: http://www.nlmotoring.com/XXR-550-Wheels-18x8-75-Platinum-p/550881001.htm He seems pretty confident I wouldn't need to roll the fenders with the 18x8.75 +36 wrapped in 255/40/18s on RCE Black springs, but he also doesn't have a Legacy. I'm pretty much a newbie when it comes to aftermarket wheels, but does anyone prefer Konig over XXR or vice versa? One difference I see is the XXR 550 in that size is 23.2lbs, while the Konig Oversteer 18x9 +42 is about 20lbs per wheel. Edited June 11, 2015 by Zee199969 My "Build" Link to comment Share on other sites More sharing options...
fredrik94087 Posted June 11, 2015 Share Posted June 11, 2015 +36 running 255 will rub. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
GTEASER Posted June 11, 2015 Share Posted June 11, 2015 +36 running 255 will rub. ^^This. The 18x9+42 with 255 will fit in the rear without rubbing, but the fronts will either need a little pull or some camber, possibly both. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Zee199969 Posted June 11, 2015 Share Posted June 11, 2015 Trying to source a reputable local shop that does fender rolling in case I go with the XXRs My "Build" Link to comment Share on other sites More sharing options...
fredrik94087 Posted June 11, 2015 Share Posted June 11, 2015 Contrary to what I was told and what was done, you may roll the fronts....virtually flat so they hold the fender liner in place...but not too tight. Get them pulled at the same time which is quite easy with the aluminum foil they used for a fender "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
marcin93 Posted June 12, 2015 Share Posted June 12, 2015 Was wondering if anyone tried anything near 19x9.5 et22. I feel that with such an offset would poke way too much. Opinions? Link to comment Share on other sites More sharing options...
Unsp0kn Posted June 12, 2015 Share Posted June 12, 2015 Was wondering if anyone tried anything near 19x9.5 et22. I feel that with such an offset would poke way too much. Opinions? DC_Titus is running 19x10 +28 and might add 10mm spacers. Check the Slammed thread. Link to comment Share on other sites More sharing options...
GTEASER Posted June 12, 2015 Share Posted June 12, 2015 Locally I just found a virtually new set of Konig Integrams in Matte Gunmetal, 18x9+45 with one small curb rash for $500. Score!!! Gonna pick them up Sunday. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Ellesedil Posted June 12, 2015 Share Posted June 12, 2015 Locally I just found a virtually new set of Konig Integrams in Matte Gunmetal, 18x9+45 with one small curb rash for $500. Score!!! Gonna pick them up Sunday. What is your plan with them? Track wheels? Link to comment Share on other sites More sharing options...
GTEASER Posted June 12, 2015 Share Posted June 12, 2015 What is your plan with them? Track wheels? Yep. The Torchs weigh 24 pounds. The Integrams weigh 20 and will likely get some sticky rubber. They also have a 5mm higher offset, so chances are I could go 265/40 for the track rubber without having to do any more fender work. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Unsp0kn Posted June 12, 2015 Share Posted June 12, 2015 The Integram is a sick design, I wish they made them in 19" with our 5x100 pattern. Really like the Oversteers though, no regrets here. Link to comment Share on other sites More sharing options...
Ellesedil Posted June 13, 2015 Share Posted June 13, 2015 I've been contemplating off and on about selling my Wedssport TC105Ns (16 lbs each) so I can pick up a set of either SA-10Rs or SA-72Rs. Probably not selling them for $500 though Link to comment Share on other sites More sharing options...
GTEASER Posted June 13, 2015 Share Posted June 13, 2015 I'd love to get nice light expensive wheels, but I would get seriously ill and puke instantly if I ever hit a curb or something. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
s2baru Posted June 13, 2015 Share Posted June 13, 2015 Pretty sure my next setup is going to be a 5spoke design 19x10.5 +22...color will more than likely stay the same so you all can still recognize me lol. Link to comment Share on other sites More sharing options...
Ellesedil Posted June 13, 2015 Share Posted June 13, 2015 I'd love to get nice light expensive wheels, but I would get seriously ill and puke instantly if I ever hit a curb or something. Oh, you won't have to worry about that. I've already curbed them. On a related note, how wide of a tire would fit on 18x9.5 +45 do you guys think? Restricted to 245/40 or could you go up to 255 or 265/40? Link to comment Share on other sites More sharing options...
GTEASER Posted June 13, 2015 Share Posted June 13, 2015 You can put a 265/40 on 9" wheels, so you could easily do 275/35 on a 9.5" wheel but you would need coilovers with thatvoffset. 245 on 9.5 would start to look stretched. I like a square look. I've only ever curbed one wheel in my 30 years of driving. I could probably drop $3000 on a set of wheels and be fine if I only had a spare $3000. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Zee199969 Posted June 13, 2015 Share Posted June 13, 2015 Those Wedssport SA-72Rs are sexy, woulda been my choice if I had the budget for em My "Build" Link to comment Share on other sites More sharing options...
