Hookedontronics Posted August 8, 2012 Share Posted August 8, 2012 So monday night i bought a 05 Legacy gt limited with 180,000. Car was very clean, everything ran good, i had looked at it over the weekend and test drove it and everything was smooth, car looked like a great buy for $5300. Well as luck would have it, after taking delivery within 20 miles of dirving i got a cel, P0302, misfire cylinder 2. I did a search and found a few possible suggestions for the cause. This morning i swapped out the injector, but no luck there. Tonight or tomorrow i'm going to replace the plug and coil pack. Car still runs fine, just shakes a little bit at idle. Also, twice now (of about 10-12) i've have to crank it for a while before it starts up...which sounds like it may also be a fuel/spark problem?...the rest of the time it starts up quick. Any other suggestions? I'd also like to mention i'm not at all detured by my purchase, i've owned turbo subaru's in the past and i plan to build this motor in the future, and do a 6spd or dogbone swap, but i was hoping to use it as a winter daily for this year first. thanks Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted August 8, 2012 Share Posted August 8, 2012 Suggestion: You paid $5300 for a 4th G LGT. Its not only not going to be perfect, but was a great deal! The seller cleared the codes and handed it over to you. They were aware. It did not "just pop" for the first time. Link to comment Share on other sites More sharing options...
Nrw Posted August 8, 2012 Share Posted August 8, 2012 holy ****, only $5300! talk about a steal Link to comment Share on other sites More sharing options...
dudeondacouch Posted August 8, 2012 Share Posted August 8, 2012 Welcome... Are you the "Hookedontronics" from TW? If so, stop following me! Link to comment Share on other sites More sharing options...
Hookedontronics Posted August 8, 2012 Author Share Posted August 8, 2012 Suggestion: You paid $5300 for a 4th G LGT. Its not only not going to be perfect, but was a great deal! The seller cleared the codes and handed it over to you. They were aware. It did not "just pop" for the first time. i checked the obd2 with my code reader before buying the car for any pending codes, and there were none, i really don't think that was the case. I'm not asking for a perfect LGT for 5300 lol, i wouldn't expect one. I bought the car for the longblock. It's a car i am going to build in the near future Link to comment Share on other sites More sharing options...
Hookedontronics Posted August 8, 2012 Author Share Posted August 8, 2012 Welcome... Are you the "Hookedontronics" from TW? If so, stop following me! lol, yes i am Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted August 8, 2012 Share Posted August 8, 2012 Glad you checked it. Hope you are right. Occasional stories of that sort of bs on the forum. Either way it was a STEAL anyway!!! Link to comment Share on other sites More sharing options...
dudeondacouch Posted August 8, 2012 Share Posted August 8, 2012 Link to comment Share on other sites More sharing options...
mightyS Posted August 10, 2012 Share Posted August 10, 2012 My car had the same check engine code as you. I cleared it and it seemed to run fine. Then after 2 or 3 weeks, it came back. I had it checked and the injector on cylinder 2 was clogged. I had it replaced and the code came back in 25-30 miles. Then I had a compression test and it was found the valves on cylinder 2 were burnt/warped. It seems that the injector was still working but was not spraying enough fuel to cool the cylinder. This overheated the valves. Your problem can also be the spark plug or coil pack. These are much cheaper fixes than new valves. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 10, 2012 Share Posted August 10, 2012 i checked the obd2 with my code reader before buying the car for any pending codes, and there were none, i really don't think that was the case. I'm not asking for a perfect LGT for 5300 lol, i wouldn't expect one. I bought the car for the longblock. It's a car i am going to build in the near future Id think about building that longblock sooner than later! Link to comment Share on other sites More sharing options...
king_j Posted August 11, 2012 Share Posted August 11, 2012 I had the code. Bad valve for me. Link to comment Share on other sites More sharing options...
Leviman Posted August 11, 2012 Share Posted August 11, 2012 Damn you, I got a wrecked 2.5i for 5200! Although that's not to say yours isn't a white with tan interior automatic grandma mobile Link to comment Share on other sites More sharing options...
Hookedontronics Posted August 13, 2012 Author Share Posted August 13, 2012 did a compression test and cylinder #2 is done, which i almost have trouble believing because the car runs and drive just fine. I'm really on the fence as to what i want to do with it right now. Either going to build the motor/sell the car for what i have into it/ or part it out. Decissions decissions Link to comment Share on other sites More sharing options...
Hookedontronics Posted August 13, 2012 Author Share Posted August 13, 2012 Damn you, I got a wrecked 2.5i for 5200! Although that's not to say yours isn't a white with tan interior automatic grandma mobile black on black 5 speed. limited with the sunroof, leather etc Link to comment Share on other sites More sharing options...
fahr_side Posted August 13, 2012 Share Posted August 13, 2012 You've owned the car for less than a week. Return the car and get your money back. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 13, 2012 I Donated Share Posted August 13, 2012 You're not missing an injector are you? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Hookedontronics Posted August 13, 2012 Author Share Posted August 13, 2012 can't return the car, i bought it private party. no, not missing an injector Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 13, 2012 I Donated Share Posted August 13, 2012 I believe Thor is having this same issue on his 4th gen..... -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
fahr_side Posted August 13, 2012 Share Posted August 13, 2012 So this douchebag erased the CEL, palmed a car with a dead cylinder off on you for cash, and you're going to let him get away with that? I've got some awesome land in Florida for a really good price if you pay cash... Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
Hookedontronics Posted August 13, 2012 Author Share Posted August 13, 2012 there is really nothing i can do. I can let the rest of my buddies in my local car club/ car scene know he's a bad dude but as far as ny is concerned it's buyer beware so i'm stuck right now Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 13, 2012 Moderators Share Posted August 13, 2012 So this douchebag erased the CEL, palmed a car with a dead cylinder off on you for cash, and you're going to let him get away with that? I've got some awesome land in Florida for a really good price if you pay cash... I'm interested... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 13, 2012 I Donated Share Posted August 13, 2012 I've got some awesome land in Florida for a really good price if you pay cash... More information please -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Hookedontronics Posted August 13, 2012 Author Share Posted August 13, 2012 Just tried a different compression tester and it's reading 75psi. My tester holds the pressure in there fine after you stop cranking so I'm thinking the rings are okay? Thoughts? Link to comment Share on other sites More sharing options...
fahr_side Posted August 14, 2012 Share Posted August 14, 2012 Thoughts? Even if it is just one burnt valve that's causing your compression loss, think about this. The motor has to come out to get the head off. If one valve is bad, others may on the way there, so it makes sense to pull the other head for inspection. It would be colossally stupid to pull the motor and not replace the water pump, timing belt and tensioner, unless those were done very recently. Your shortblock has 180,000 miles on it, and a brand new one is <$2k... You see where I'm going with this? Shop for a low-mile longblock from a crashed LGT/WRX/FXT, or buy a new factory shortblock, new ancillaries, have your heads freshened up, rebuild. When you're done, drive on down and look at the land I have just for you. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
Hookedontronics Posted August 14, 2012 Author Share Posted August 14, 2012 I found an engine from a xt Im gonna try to pick up. 50,000 miles for $2400. High price but it'll replace the clutch disk and plate while I'm there. Then it'll give me some peace of mind to add a different turbo, prob a vf52 and do a few mods Link to comment Share on other sites More sharing options...
