InnocentGuns Posted August 15, 2012 Share Posted August 15, 2012 Thats not a high price at all. i picked up a wrecked lgt for 750 so far have 3000ish into it. 1300 plus in motor alone. and thats only head work and misc parts. i will buy it for 5000 mainly for the body. let me know if you want to sell Link to comment Share on other sites More sharing options...
king_j Posted August 15, 2012 Share Posted August 15, 2012 http://legacygt.com/forums/showthread.php/cylinder-misfires-bad-injectors-please-post-here-85099.html http://legacygt.com/forums/showthread.php/cylinder-4-misfire-120496.html good info in these threads. you have 5,300 in the car, with a P0302 code, you might get 2-3K for it. if you fix the problem (might run you 2k), you'll have a rebuilt top end engine and assuming the block is good, you should not have any problems for a while. I ended up fixing the car with the same code, i replaced eveything that was recommended (t-belt, water pump, tensioner, all new gaskets) and some other things while the engine was out (killer b oil pickup tube, new clutch/lwfw).engine now feels new. Link to comment Share on other sites More sharing options...
Hookedontronics Posted October 11, 2012 Author Share Posted October 11, 2012 I ended up going the sti swap with a new engine. Here she is: -VF48 2012 STi Turbo -S/S braided turbo oil line from P&L -Perrin turbo inlet hose -Perrin short ram intake -Sti intake manifold -top feed TGVs -top feed 565cc injectors (blue) -new timing belt and tensioner professionally installed -DW65c fuel pump -Custom made wiring harness for injectors and map sensor -Cobb uncatted up-pipe, heat wrapped -STi throttle body -SAI block of plates -CNT Catted downpipe -STi top mount intercooler -APS 50/50 blow off valve -New Exedy clutch kit (disk, pressure plate, bearings) -New F1 racing lightweight flywheel -fresh fluids: coolant, oil and power steering -new plugs -New tires -Tuned by Ray @ TurboTek http://i63.photobucket.com/albums/h135/jacobennis/27F47C0A-2886-4444-9440-CD8130B73EEA-2994-0000028867665983.jpg http://i63.photobucket.com/albums/h135/jacobennis/E39C9FEC-B715-4CC2-8A00-8EEB78C82F60-2994-000002886EB01084.jpg Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted October 11, 2012 Share Posted October 11, 2012 Looking good! Why an STI swap? Link to comment Share on other sites More sharing options...
Hookedontronics Posted October 11, 2012 Author Share Posted October 11, 2012 why not? i had to replace the engine anyway, so why not an upgrade. Link to comment Share on other sites More sharing options...
Lanaue Posted October 16, 2012 Share Posted October 16, 2012 Great job looks good , how much of a pain in the as$ was it? Link to comment Share on other sites More sharing options...
Hookedontronics Posted October 30, 2012 Author Share Posted October 30, 2012 wasn't that bad at all, these engine are pretty easy to get out/in. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted October 30, 2012 Share Posted October 30, 2012 why not? i had to replace the engine anyway, so why not an upgrade. Ive got 370+whp and no sti swap. Link to comment Share on other sites More sharing options...
Brotated_Scoobie Posted October 30, 2012 Share Posted October 30, 2012 why not? i had to replace the engine anyway, so why not an upgrade. Very nice swap! Link to comment Share on other sites More sharing options...
TenzoGT Posted October 30, 2012 Share Posted October 30, 2012 That is sick man... Love it Link to comment Share on other sites More sharing options...
