Mega Users seabass07 Posted April 4, 2012 Mega Users Share Posted April 4, 2012 No, but I'm sure if the leak was a little worse, I'd have that problem. As it is, I hit my higher targets, but I hit peak boost a little later than I should. Link to comment Share on other sites More sharing options...
Hepy117 Posted April 7, 2012 Author Share Posted April 7, 2012 Would a whine only in 1st and 2nd be from an exhaust leak pre turbo? I don't hear any in 3rd through 6th. Link to comment Share on other sites More sharing options...
bmx045 Posted April 8, 2012 Share Posted April 8, 2012 sounds like tranny whine Link to comment Share on other sites More sharing options...
Hepy117 Posted April 8, 2012 Author Share Posted April 8, 2012 That's what I thought but I wasn't sure. Link to comment Share on other sites More sharing options...
Hepy117 Posted April 20, 2012 Author Share Posted April 20, 2012 Just wanted to post a quick update for everyone who has been involved in helping me or care about the situation. I took my car to the shop yesterday and they diagnosed it as a bad BCS. I am going to get a new one and see if that is what is bad. Let's hope this is it. If it is I am going stage 2 next weekend! Link to comment Share on other sites More sharing options...
Hepy117 Posted April 25, 2012 Author Share Posted April 25, 2012 Need some more help! Installed a new BCS known to hold 17psi. Took my car for a drive. Still getting less than 11psi. After reading a post on here, I disconnected the vac hose to the actuator and easily got 17psi. Now on the same posting they said if this happens I have a problem with my bcs (factored this out with a new bcs), pill, or other boost controls. My question is, what are the other boost controllers besides the pill and bcs? Also, is the pill in a 07 spec b the same as the pill in the 05/06's? When looking on the sight I see a listing for those years but not newer. Link to comment Share on other sites More sharing options...
bmx045 Posted April 25, 2012 Share Posted April 25, 2012 the ecu Link to comment Share on other sites More sharing options...
Hepy117 Posted April 25, 2012 Author Share Posted April 25, 2012 As in the map or the actual ecu? Link to comment Share on other sites More sharing options...
bmx045 Posted April 25, 2012 Share Posted April 25, 2012 could be one or the other.... essentially you've mechanically forced 17psi so you know the actuator is okay, you've tried two bcs's with the same result, the only thing controlling that is the ecu and its rom. maybe check the wiring going to the bcs? i figure it would throw a code for an electrical fault Link to comment Share on other sites More sharing options...
Hepy117 Posted April 25, 2012 Author Share Posted April 25, 2012 What would I be looking for in the wiring? Like a stripped wire that is grounding itself out on some metal? Link to comment Share on other sites More sharing options...
bmx045 Posted April 25, 2012 Share Posted April 25, 2012 yea Link to comment Share on other sites More sharing options...
Hepy117 Posted April 25, 2012 Author Share Posted April 25, 2012 Well from what I can see the there are no places that has happened. Most of it is covered by the black conduit. Also is the 07 pill the same size as the 05/06? Link to comment Share on other sites More sharing options...
