iNVAR Posted February 19, 2012 Share Posted February 19, 2012 Ah, so do as seabass says and use 4th. Also, your latest log shows TD being capped out and unable to bring WGDC any higher, and it stays capped out at 15 the entire time. It'd be good if you could find some datalogs from another stock 07 LGT/SpecB and compare. You're not driving downhill, are you? Link to comment Share on other sites More sharing options...
Hepy117 Posted February 19, 2012 Author Share Posted February 19, 2012 That last log was on an on-ramp onto the highway. All other logs were done on a flat. I'll load up my rom and see what I can find out Link to comment Share on other sites More sharing options...
Hepy117 Posted February 19, 2012 Author Share Posted February 19, 2012 Here are some screen shots of my boost target, boost limit, Initial WGDC, and Max WGDC. Let me know if there is something else I should post up. Boost Limit https://docs.google.com/open?id=0B6yb7dV8je9mNDAyN2I5Y2QtOTI1Ni00Y2I0LWJlMjYtOGEzZTAzNGZiNWFk Target Boost https://docs.google.com/open?id=0B6yb7dV8je9mYTgyZjc1ZWUtNTA3MC00MDMzLWE1YmEtMGY2MWI5N2M0NDhi Initial WGDC https://docs.google.com/open?id=0B6yb7dV8je9mNzhmODMzYjMtNDljNC00YzEzLWI5ZDAtNmI1MGIwYjE4NDZj Max WGDC https://docs.google.com/open?id=0B6yb7dV8je9mYmZkMjQyMGMtNWJlZC00OGViLWJjM2QtYTY5OTVkMGUwMmU2 Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 19, 2012 Mega Users Share Posted February 19, 2012 For some reason i cant access those files. Any chance you can attach them? Link to comment Share on other sites More sharing options...
iNVAR Posted February 19, 2012 Share Posted February 19, 2012 Can you open it in ROMRaider and screenshot that please? You're using ECUFlash and I think you're also using Metric (bar) units instead if SI (PSI). You need to use the correct definitions. Link to comment Share on other sites More sharing options...
Hepy117 Posted February 19, 2012 Author Share Posted February 19, 2012 Here they are in SI. Sorry I didn't even notice that ECUflash had them in metric until you said about it. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 19, 2012 Mega Users Share Posted February 19, 2012 Well its not a stock tune afaik. Im comparing it to the stock 07 spec b rom on romraider.com. Link to comment Share on other sites More sharing options...
iNVAR Posted February 19, 2012 Share Posted February 19, 2012 Interesting. I'm at work right now, so couldn't do that myself. Thanks for doing the legwork seabass. 15psi target too. Stock on an 07 calls for what... 13.5 I think? Link to comment Share on other sites More sharing options...
Hepy117 Posted February 19, 2012 Author Share Posted February 19, 2012 Yeah stock is 13.5 for 07. So is it fair to say this is possibly a stage 1? What psi do they usually target for stage 1? Is there anywhere i should tweak according to my logs to help it run a little better? I am going to look at going stage 2 here after i get my tax return. I wanna get a CNT catted dp and then infamous tune (unless i learn more about tuning myself by then) Link to comment Share on other sites More sharing options...
iNVAR Posted February 19, 2012 Share Posted February 19, 2012 Who'd you buy the car from? Why don't you ask them what they did to it? If you're going to go stage 2 soon, I would just leave it alone and get the stage 2 tune from infamous or someone else. UNLESS you intend to do the stage 2 tune yourself... Then now would be a good time to learn how to do stuff. But just bear in mind that after you get everything dialed in stage 1, you're going to have to redo the entire tune with the new parts for stage 2. Almost like doing double work. So it's really just a matter of how much work you want to put into it yourself. Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 The guy i bought the car said it was stock performance wise (had a kartboy sts with bushings, avo control bushings, perrin intake (i took off for stock), and replaced the struts. I am goin to try and contact the guy he bought it off of to try and get some info Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 20, 2012 Mega Users Share Posted February 20, 2012 But thats even worse. Either theres a leak or your actuator is stuck. It explains why the wgdc is so high, but it is still just barely hitting 13psi when the target is 15. Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 Did you flash a different map on? Your logs show different target boost levels from each other and even from the map. Granted, there are compensations involved, but one of your logs shows a target of 13.5, another shows a target of 14.5 and the map shows a target of 15.... Link to comment Share on other sites More sharing options...
Chris GTO TT Posted February 20, 2012 Share Posted February 20, 2012 Just for reference i pulled the stock boost table from my 08 Spec B for you guys. That boost target map doesn't appear to be stock. Let me know if you guys want to look at any stock tables from my 08 and i can screen shot them 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 I didn't flash any maps. I just got my cable a couple weeks ago in hopes of going stage 2 after I receive my tax return. Looks like I am going to have to take a closer look at my turbo and make sure there is nothing wrong. Would it be best to flash the stock rom back onto the car and get rid of this other rom? edit: It seems to me that whoever put this map on was only interested in max output because all the boost target lower than the last 2 max raw torque request columns are all less than 10. Also, you would think that since It's not running a high psi on the lower requested torque I would get good mpg. On the highway, in I mode, cruising at 73mph, I only got 23mpg. I mean I am not complaining because I realized a turbo's awd car isn't going to get great mpg but I see a lot of people get 25mpg on the highway with 5mt. I would think a 6mt would do better. My brother has an 06LGT 5mt and he gets 25mpg going to and from Boston to central PA and I got 22 at best (these were all hand calculated numbers) Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 Well, it makes me wonder what other tables that person tweaked too... Grab a stock ROM and start comparing the tables to see what else the person has done. And get in touch with the previos owner(s) to see if hardware wise anything else was changed that you should be aware of. If the car is stock hardware, then I would go back to stock tune for now, and then start dialing things in myself, perhaps upping the boost and stuff. The reason I suggest this is because unless you have an idea of who made the tune, I would not trust it. But that's just me. As far as fuel economy goes, I don't know... could be a lot of things. Timing, fueling, etc. *shrug* You'll have to look at all the tables. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 20, 2012 Mega Users Share Posted February 20, 2012 Just flash to a stock rom with the same rom id. But since you'll be running significantly less wgdc on the stock rom, you might not even hit 10psi. Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 ^-- What he said. Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 I am going to flash to the stock rom off of romraider and log a run and see what kind of boost I hit. Now my question, if I do only hit let's say 10psi, would that mean a mechanical problem? I checked for unhooked tubes and I didn't see any. Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 It could mean something mechanical, like the WG flapper is leaking, or that you have a boost leak, or that the restrictor pill is the wrong size (or missing), or the WG actuator is too loose. Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 Well lets hope I don't have any of those problems. I am going to flash and run some logs here soon. I'll keep you guys posted. Thanks again everyone for all of your help Link to comment Share on other sites More sharing options...
Chris GTO TT Posted February 20, 2012 Share Posted February 20, 2012 So I've been wondering would the fact that the values are so low in all but the last 2 columns have an effect on his ability to hit the target boost levels? 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 Nope. Last column is last column. That's where he's at when he's WOT. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 20, 2012 Mega Users Share Posted February 20, 2012 And his wgdc numbers in the logs are very high and are pretty close to what the map says. Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 Wish I could find a datalog of a stock 07/08 SpecB and see what their WGDC numbers are like for reference. If you're able to locate one, let me know, but I'm sort of preoccupied right now. Link to comment Share on other sites More sharing options...
