iNVAR Posted March 25, 2012 Share Posted March 25, 2012 Okay, so let me make sure I'm clear on where you stand right now. I get mixed up between your thread and a million other ones asking about their tunes lol. You went back to a stock tune, and disabled the CEL. You haven't touched anything on that stock tune, correct? And you've tried swapping in a known good TMIC, and it was still underboosting, correct? hmm.... Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted March 25, 2012 Mega Users Share Posted March 25, 2012 It's the exact same problem as before, but with the stock tune, the max wastegate is lower. He's still hitting max wgdc from td trying to compensate. Link to comment Share on other sites More sharing options...
Hepy117 Posted March 25, 2012 Author Share Posted March 25, 2012 Correct this is the stock tune besides CEL's shutoff. Link to comment Share on other sites More sharing options...
iNVAR Posted March 25, 2012 Share Posted March 25, 2012 Yeah, then what seabass said. If you're unable to achieve stock boost pressure using the stock map using stock hardware on your car, something is wrong. Do you have another boost gauge that can confirm the pressure readings too? I'm sure they're right, but it'd be nice to have a secondary to confirm. Link to comment Share on other sites More sharing options...
Hepy117 Posted March 25, 2012 Author Share Posted March 25, 2012 I dont have a gauge. Just my tactrix cable. When i get back from DC i am goin to change out the TB hose and BPV and see if one of those is the problem Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted March 25, 2012 Mega Users Share Posted March 25, 2012 So I'm more confused by your recent learningview. All of the sudden your 40+ fuel trim is at +4? That means the ecu is adding fuel because it is getting more air than expected...yet you can't hit your targets even at max wgdc on stock everything? Once again, digging for ideas, but are you still on the stock air filter? Link to comment Share on other sites More sharing options...
Hepy117 Posted March 25, 2012 Author Share Posted March 25, 2012 K&n drop in. Here is a more recent learnin view (yesterday) all trims are then than 3% https://docs.google.com/file/preview?id=0B6yb7dV8je9mYUhBY1NBTjdSOVNrT3NGZHhiaEdCQQ&pli=1 Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted March 25, 2012 Mega Users Share Posted March 25, 2012 The k&n could explain the +4. I'd keep an eye on that in future lv's. Link to comment Share on other sites More sharing options...
bmx045 Posted March 25, 2012 Share Posted March 25, 2012 wtf elevation are you at???? it may take a while for the trims to settle in but the filter *shouldn't* cause too much issue. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted March 25, 2012 Mega Users Share Posted March 25, 2012 4% definitely seems excessive for just a filter. I think mine was off around 2% with an afe drop in. Link to comment Share on other sites More sharing options...
Hepy117 Posted March 25, 2012 Author Share Posted March 25, 2012 Well i jus moved last saturday. I went from 500ft above to 1000ft Link to comment Share on other sites More sharing options...
Hepy117 Posted March 25, 2012 Author Share Posted March 25, 2012 Check out that new lv i just posted. 40+ was less than 1% Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted March 25, 2012 Mega Users Share Posted March 25, 2012 Did you reset your ecu between those lv's by any chance? Link to comment Share on other sites More sharing options...
Hepy117 Posted March 25, 2012 Author Share Posted March 25, 2012 I believe so but don't mark my words Link to comment Share on other sites More sharing options...
bmx045 Posted March 25, 2012 Share Posted March 25, 2012 fwiw- the stock airbox has a 10mm mount bolt on the top left hand corner of the box, i had that bolt removed and my trims were +6 and then -1.2 in the c and d ranges. I plugged it with tape and now they're improved to 2% or so. i also had a small vac leak in injector 3 that i fixed....WOT afr's are ~11.3 Link to comment Share on other sites More sharing options...
Hepy117 Posted March 25, 2012 Author Share Posted March 25, 2012 Ill have to check that when i get back home. By top left of the box do you mean looking at it from the top down ( so the bolt will actually be towards the rear passenger side) or if you were looking at it straight on in the front? Link to comment Share on other sites More sharing options...
bmx045 Posted March 25, 2012 Share Posted March 25, 2012 from front theres only one top corner bolt Link to comment Share on other sites More sharing options...
Hepy117 Posted March 25, 2012 Author Share Posted March 25, 2012 Gotcha. Sorry i dont have it in front of me so was trying to think where it was n nothing came to mind. I figured once i popped the hood i'd see it Link to comment Share on other sites More sharing options...
Hepy117 Posted April 4, 2012 Author Share Posted April 4, 2012 Well I replaced my TB coupler this afternoon with a stock one. I found one thing that was wrong with my old one, the end of it was cut off (didn't notice until I saw the one I replaced it with). Still can only get 10.8psi. But it definitely feels better than with the old TB. God I am getting annoyed with this. Here is a log/LV.romraiderlog_20120403_193645.csv Link to comment Share on other sites More sharing options...
iNVAR Posted April 4, 2012 Share Posted April 4, 2012 Uhm you're missing engine speed and throttle position. Sort of important. Take off final fueling base. I don't know why you're logging that. Take off target boost. You don't need that because you already have boost error. Link to comment Share on other sites More sharing options...
Hepy117 Posted April 4, 2012 Author Share Posted April 4, 2012 I know it was just a quick log on my way home from work. I think I may have the problem figured out. After thinking about it, any kind of vac leak would result in a higher or lower fuel trim. After speaking with a member of another forum, he led me to look into a pre-turbo exhaust leak (manifolds, cross pipe, up pipe). Now I just need to find someone in the area with jacks/jack stands/car lift so I can get underneath and check it out. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted April 4, 2012 Mega Users Share Posted April 4, 2012 If you have an exhaust leak big enough to cause this, you will HEAR it. I have a pre-turbo exhaust leak and it it quite loud. But I'm still hitting my targets with TD raising WGDC a bit. Link to comment Share on other sites More sharing options...
Hepy117 Posted April 4, 2012 Author Share Posted April 4, 2012 I don't have a loud whistle. I am not sure if I have one or not because it has sounded like this from the day I bought it. It is more noticeable now however because when I bought it it had a CAI. I since then have gone back to stock intake. This is my last straw. I don't know what else would be the problem. If this isn't it I am going to say screw it and leave it the way it is. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted April 4, 2012 Mega Users Share Posted April 4, 2012 Mine isn't a whistle. It sounds like loud engine noise under the hood. It's still worth a try to check everything out. Link to comment Share on other sites More sharing options...
Hepy117 Posted April 4, 2012 Author Share Posted April 4, 2012 Yeah I am going to check this out. I am hoping this is it. That's what mine kinda sounds like. Did you have to raise your WGDC or TD to get it to get to stock boost levels? Link to comment Share on other sites More sharing options...
