Mega Users seabass07 Posted February 20, 2012 Mega Users Share Posted February 20, 2012 I haven't found one, but realistically it should be like any other 07. Everything's the same except for the transmission and suspension, right? Regardless, we've seen the maps hes running on and he should be hitting 15+ psi. I don't think a vf46 would require drastically different wastegate control than a vf40. Just tweaks I think. Edit* I just compared the stock wastegate maps for my 05 and the 07 specB. The numbers should be similar at WOT. However I didn't know the 07+ ecu's map boost to requested torque instead of throttle plate angle. Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 Yeah, I meant any other 07/08 SpecB OR LGT, sorry. I've been told in another thread that the VF46 has a different restrictor pill from the VF40. Who knows.... maybe someone just popped in the wrong restrictor. Could be as simple as that. Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 Well I just ref lashed with the stock rom. My CEL is constant, cruise light and the SI-mode letter is blinking on my dash? Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 Did you remember to unplug the green connector? Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 20, 2012 Mega Users Share Posted February 20, 2012 Hmmm. that's scary. Figure out what the cel's are with learning view. If they weren't there before, then someone must have disabled them. I hope it's nothing major. or it's the green plug like iNVAR said. Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 Yeah I turned my key to off, unplugged the connectors, turned my key to on until the seatbelt chime stopped, turned on my car. I let it run for like 30 seconds and turned it off, then let it sit for about a min and restarted and it was still on/blinking Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 Do what SB says. Pull the CEL codes with LV. Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 Here is what I am getting.... a whole bunch. Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 6 Temp codes: P2016 TGV IM runner 1 pos sensor low P2021 TGV IM runner 2 pos sensor low P2008 TGV IM runner 1 circuit open P2011 TGV IM runner 2 circuit open P2431 Sec Air Pump circuit range/per P2433 Sec air pump circuit high there are also 6 memorized that have those first 4 and last 1 and also this: P1491 PCV (BLOWBY) FUNCTION PROBLEM Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 Just realized something interesting. Your LV engine speed rows are crazy... 12000 RPM? I've seen that before on someone else's thread too. Get the newest version of LV. See if that helps. http://www.romraider.com/forum/viewtopic.php?f=32&t=7397 Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 I have learning view 6a which is the latest I am seeing on romraider whoops just saw you posted the newest Here is a screenshot: Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 Still strange that your CEL would be on though.... wtf. Assuming you got the right ROM and your car is an 07 Spec B, and ECUFlash succeeded and verified, this shouldn't be happening. Hmm.... Unless there actually is something wrong with the car. Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 ECUflash said it succeeded. Would possibly driving the car clear the CEL's? This is the rom I downloaded off of romraider: 2007 USDM Subaru Legacy GT spec.B MT A2UG000L 4B12785007 Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 No, I don't believe that CEL will clear from driving. ROM looks right, matches your other one. Argh... Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 Well I just searched for the P2011 code on the site and everything I am seeing is that people get this code when they do the TGV deletes? God I am so frustrated with this already. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 20, 2012 Mega Users Share Posted February 20, 2012 Just realized something interesting. Your LV engine speed rows are crazy... 12000 RPM? Well it is a spec B. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 20, 2012 Mega Users Share Posted February 20, 2012 I think now would be a good time to talk to that seller again. Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 The previous owner(s) haven't replied to you? Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 Open up the ROM that you saved prior to flashing... the one you were running originally. and check the Check Engine Codes to see if they were disabled compared to this one. Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 I talked to the seller I bought it off of. He had no clue anything was changed (tune or any hardware performance wise) Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 Oh, and according to another LGT poster, your load and RPM ranges (5.00+ load and 12000 RPM) are actually right... comes from Subaru that way. I wonder why.... Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 Well every code that is thrown on the LV is OFF on the rom I pulled Link to comment Share on other sites More sharing options...
iNVAR Posted February 20, 2012 Share Posted February 20, 2012 Which.... is not a good sign. Someone disabled them on purpose. Whether for a good purpose (they did some sort of mod that required it) or a bad one (something's broken) is to be determined. Either way, you need to get to the bottom of this. Are you the second or third owner? Link to comment Share on other sites More sharing options...
Hepy117 Posted February 20, 2012 Author Share Posted February 20, 2012 Well I am going to try and get a hold of the original owner and see what I can find out. Anyone know any Russians from East Brunswick, NJ? Here is the link to the original posting: http://bestcarsunder1000.com/subaru-legacy-167/ Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 20, 2012 Mega Users Share Posted February 20, 2012 Why, you need to off a guy? Link to comment Share on other sites More sharing options...
