Zues Marine Posted August 27, 2013 Share Posted August 27, 2013 How's that exhaust Comin along brah? Hehehe Sent from my MB886 using Tapatalk 4 Beta Link to comment Share on other sites More sharing options...
Max626 Posted September 14, 2013 Share Posted September 14, 2013 Are the inner/outter tie rods interchangeable on both side? When i look up a set it doesn't state if its Left or Right Link to comment Share on other sites More sharing options...
Sludgeroo Posted November 11, 2013 Share Posted November 11, 2013 Could there be a direct correlation to sway bar endlink getting worn quicker than not if the cv joint is busted? Sent from my VS980 4G using Tapatalk Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 11, 2013 Share Posted November 11, 2013 Nope. Not at all. Link to comment Share on other sites More sharing options...
Sludgeroo Posted November 13, 2013 Share Posted November 13, 2013 Thanks. Need to get on here more Sent from my VS980 4G using Tapatalk Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 13, 2013 Share Posted November 13, 2013 For real Link to comment Share on other sites More sharing options...
Zues Marine Posted November 14, 2013 Share Posted November 14, 2013 hurrrd dat. Link to comment Share on other sites More sharing options...
Sludgeroo Posted November 14, 2013 Share Posted November 14, 2013 Lol. You guys Sent from my VS980 4G using Tapatalk Link to comment Share on other sites More sharing options...
Sludgeroo Posted November 15, 2013 Share Posted November 15, 2013 So do any of you gentlemen have a good idea of where I can get new hardware for front endlinks. They aren't gonna come apart and the new links didn't come with hardware Sent from my VS980 4G using Tapatalk Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 15, 2013 Moderators Share Posted November 15, 2013 Ace hardware has a good selection of auto grade nuts / bolts. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Sludgeroo Posted November 15, 2013 Share Posted November 15, 2013 Cool, I just wasn't sure if they needed to be shouldered bolts or if I just need to match them Sent from my VS980 4G using Tapatalk Link to comment Share on other sites More sharing options...
Dangerzone3 Posted January 5, 2014 Share Posted January 5, 2014 I'm not sure if this was answered before in the thread. After putting 04 sti struts and springs on , would the back have a sag like with the wrx suspension?? Link to comment Share on other sites More sharing options...
Kennyfvholla Posted January 5, 2014 Share Posted January 5, 2014 Only if you have a wagon, it might look like it's sagging because the strut/spring combo is shorter than the factory LGT strut/spring. The STi only has a spring rate of 10 lbs/in more than the LGT wagon, but is 70 lbs more than a sedan. If you have a wagon, get 3/8th's inch spacers just in case. Link to comment Share on other sites More sharing options...
Zues Marine Posted January 5, 2014 Share Posted January 5, 2014 Only if you have a wagon, it might look like it's sagging because the strut/spring combo is shorter than the factory LGT strut/spring.. also, the wheel arches are different in front and back on all second gens, a potential 'ass-sag' on any combo without some spacers.. usually 3/8" Link to comment Share on other sites More sharing options...
Sludgeroo Posted January 5, 2014 Share Posted January 5, 2014 At least with those spring rates and 3/8 spacers at normal static stance it will sit lower in the front geometry wise, but visually, will look even. With that said, it seems under acceleration the suspension geometry would have a neutral feel. Sent from my VS980 4G using Tapatalk Link to comment Share on other sites More sharing options...
Dangerzone3 Posted January 5, 2014 Share Posted January 5, 2014 Do you guys know roughly how much those spacers go for and if I will require one specifically for the legacy or if a generic one can fit on it? Link to comment Share on other sites More sharing options...
Sludgeroo Posted January 5, 2014 Share Posted January 5, 2014 Paranoidfabrications.com Sent from my VS980 4G using Tapatalk Link to comment Share on other sites More sharing options...
Dangerzone3 Posted January 5, 2014 Share Posted January 5, 2014 Paranoidfabrications.com Sent from my VS980 4G using Tapatalk That name implies a lot of confidence . Hahaha. Thanks I'll take a look. Link to comment Share on other sites More sharing options...
Sludgeroo Posted January 5, 2014 Share Posted January 5, 2014 Goofy name, but have good, cheap, kinda problem solving parts for subaru. Sent from my VS980 4G using Tapatalk Link to comment Share on other sites More sharing options...
Zues Marine Posted January 5, 2014 Share Posted January 5, 2014 you could also make them out of MDF pretty easily if you're savvy enough Link to comment Share on other sites More sharing options...
Dangerzone3 Posted January 5, 2014 Share Posted January 5, 2014 I'm assuming I would have to get longer studs though right?? Unless they have spacers that the top-hat bolts into and then the spacer has it's own studs that go into the chassis. Link to comment Share on other sites More sharing options...
Sludgeroo Posted January 5, 2014 Share Posted January 5, 2014 I'm assuming I would have to get longer studs though right?? Unless they have spacers that the top-hat bolts into and then the spacer has it's own studs that go into the chassis. They sell studs too Sent from my VS980 4G using Tapatalk Link to comment Share on other sites More sharing options...
Sludgeroo Posted January 5, 2014 Share Posted January 5, 2014 you could also make them out of MDF pretty easily if you're savvy enough Hey mister, some of us don't have a CNC mill laying around...... Or washers lolz Sent from my VS980 4G using Tapatalk Link to comment Share on other sites More sharing options...
Dangerzone3 Posted January 5, 2014 Share Posted January 5, 2014 They sell studs too Sent from my VS980 4G using Tapatalk That's convenient The studs are listed for 02-07 legacy. I'm assuming they would work with a 97 too though right? Link to comment Share on other sites More sharing options...
Kennyfvholla Posted January 5, 2014 Share Posted January 5, 2014 You only need studs for larger-than-3/8ths spacers. I bought that size from them for the STi suspension I put on my wagon. They make a great product. Link to comment Share on other sites More sharing options...
