DirtyDan Posted September 22, 2011 Share Posted September 22, 2011 You can always go back. The additives are the same in either type of oil, the difference is in how the base oil is produced. Dino oil is refined from crude oil, synthetic is made in a chemical plant. Link to comment Share on other sites More sharing options...
LegacyLove88 Posted September 22, 2011 Share Posted September 22, 2011 Sorry about that double post, but thanks for the info. I think I'm going to stick to synthetic and see how it goes. Link to comment Share on other sites More sharing options...
boymk123 Posted September 22, 2011 Share Posted September 22, 2011 synthetic won't cause loose oil pressure, I had an oil pressure gage on my GT and I monitored it Link to comment Share on other sites More sharing options...
05LacyGT Posted September 23, 2011 Share Posted September 23, 2011 still torn myself at wanting to put high mileage Mobil 1 in my 05 LGT or not. it seems to be a very heated debate among supporters of each side. i ran mobil1 in my truck with a k&n oil filter and never once had an issue. my loyalty lies in it, but my checkbook wouldn't agree with turbo issues if i use the wrong stuff. still need to see if the mesh filter is in the banjo bolt too. Link to comment Share on other sites More sharing options...
panicrev Posted September 26, 2011 Share Posted September 26, 2011 i have a 132,000 mile gt and i switched to royal purple 2800 miles ago right after i bought it. i'm certain it was changed with cheap "jiffy lube" oil before. had one of those static cling oil change reminder stickers on the inside of the windshield. no leaks or consumption since the switch. 5w30 weight. i religiously change my oil at every 3000 miles even with synthetic... just my $.02 Link to comment Share on other sites More sharing options...
bmx045 Posted September 26, 2011 Share Posted September 26, 2011 i have a 132,000 mile gt and i switched to royal purple 2800 miles ago right after i bought it. i'm certain it was changed with cheap "jiffy lube" oil before. had one of those static cling oil change reminder stickers on the inside of the windshield. no leaks or consumption since the switch. 5w30 weight. i religiously change my oil at every 3000 miles even with synthetic... just my $.02 Royal purple? it turns into water after a couple thousand miles Link to comment Share on other sites More sharing options...
panicrev Posted September 26, 2011 Share Posted September 26, 2011 you might want to check your supplier...i sell the stuff and it's still erlllll Link to comment Share on other sites More sharing options...
DirtyDan Posted September 27, 2011 Share Posted September 27, 2011 When I got my car it had Royal Purple in it, I changed it out as soon as I got home. It's your money, but because of the dye used in Royal Purple to color it purple, it reacts to ultraviolet light and turns dark very quickly. I sold the stuff the first few years after it was first introduced and all their products were synthetic. Then in 1994 they started using a blended based oil in their standard motor oil but didn't drop the price. When it was full synthetic you could run it 10,000 mile between changes, with a filter change at 5000 miles. After they changed it, about 4500 miles and your gas mileage would start going down, indicating the oil was thickening due to oxidation (which also means the ph was going down-getting more acidic). As far as I know, their racing products are still full synthetic, but unless they went back to the original formula, the street oils aren't. I ran their racing products in motorcycles, and my race cars and they were great. My opinion, if I'm spending the money for a synthetic oil, it needs to last 5000 miles between changes. If not, just run a good dino oil. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted September 28, 2011 Share Posted September 28, 2011 Good post ^^^^^^^^ Link to comment Share on other sites More sharing options...
ibr_adam09 Posted September 28, 2011 Share Posted September 28, 2011 2005 gt with 108k went synthetic at 95k, never burnt a drop between castrol and mobil 1. Stage 2 since 100k Link to comment Share on other sites More sharing options...
panicrev Posted September 28, 2011 Share Posted September 28, 2011 the label on the quarts i sell say 100% synthetic... Link to comment Share on other sites More sharing options...
NORULZleggy Posted September 28, 2011 Share Posted September 28, 2011 It just cracks me up how people believe the hype about the oil, high mile oil, and this and that. I have 180k on my corolla and use Amsoil and no high mile oil. Now mobile one is good stuff, But I am amsoil till I die. Check it out. http://www.raceoildirect.com Link to comment Share on other sites More sharing options...
boymk123 Posted September 28, 2011 Share Posted September 28, 2011 It just cracks me up how people believe the hype about the oil, high mile oil, and this and that. I have 180k on my corolla and use Amsoil and no high mile oil. Now mobile one is good stuff, But I am amsoil till I die. Check it out. http://www.raceoildirect.com http://gifsforum.com/images/gif/troll%20face/grand/troll_face_gif.gif excuse me, what did you say you have there? how the f would you compare a corolla with a turbo subie? you crack me up Link to comment Share on other sites More sharing options...
Max Capacity Posted September 28, 2011 Share Posted September 28, 2011 http://gifsforum.com/images/gif/troll%20face/grand/troll_face_gif.gif excuse me, what did you say you have there? how the f would you compare a corolla with a turbo subie? you crack me up Hey, my 1992 Honda Civic went 216,000 miles on cheap oil from Wal Mart and Fram filters. I'm sure that's why my 05 is doing fine on the same diet. So it must be true. Most of us know how good Amsoil is. That's why my 09 Spec B has it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
boymk123 Posted September 28, 2011 Share Posted September 28, 2011 that wasnt what I meant, read my highlight Originally Posted by NORULZleggy It just cracks me up how people believe the hype about the oil, my corolla use Amsoil , mobile one is good stuff, But I am amsoil till I die. Link to comment Share on other sites More sharing options...
bmx045 Posted September 28, 2011 Share Posted September 28, 2011 oil does matter, but amsoil in a corolla is hilarious. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 28, 2011 Share Posted September 28, 2011 oil does matter, but amsoil in a corolla is hilarious. Surly you can't be suggesting that the corolla isn't worth the cost of the Amsoil...now that would be funny... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rao Posted September 28, 2011 Share Posted September 28, 2011 Where can I find some more information about this Amsoil, is it better than other motor oils? Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Max Capacity Posted September 28, 2011 Share Posted September 28, 2011 Where can I find some more information about this Amsoil, is it better than other motor oils? Looks to me like some buddy is trolling...lol 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
panicrev Posted September 28, 2011 Share Posted September 28, 2011 i use synthetic in everything...my lawnmower, powerwasher, etc. Link to comment Share on other sites More sharing options...
DirtyDan Posted September 28, 2011 Share Posted September 28, 2011 the label on the quarts i sell say 100% synthetic... I just checked their MSDS sheets and it says synthetic base oil. They used to say base oil with full synthetic additives. Leading you to think it was full synthetic. I have a long history with those people and it ended badly. So, use what you want, but I don't trust them to stand behind their products. I had customers loose expensive bearing in different kinds of equipment and R.P. refused to acknowledge that it was anything to do with their oil. Customers had run Mobil synthetics for years without a problem before trying R.P. Link to comment Share on other sites More sharing options...
panicrev Posted September 29, 2011 Share Posted September 29, 2011 ok, duly noted. thanks. Link to comment Share on other sites More sharing options...
cseagle08 Posted October 1, 2011 Share Posted October 1, 2011 Since it's had conventional in it since the beginning I'd stick with that. hella cheaper!! Cars ran non-synthetic motor oil for what, near 100 years? That being said I have synthetic in everything I own... Link to comment Share on other sites More sharing options...
biketowork Posted October 2, 2011 Share Posted October 2, 2011 If you make the switch, pay attention to oil use. I found that mine used a lot more synthetic than it did dino oil when I tried to make the switch. Now, I'm back on dino oil and I haven't noticed hardly any use. On my next Subaru, I'm going to make the switch earlier. Link to comment Share on other sites More sharing options...
bmx045 Posted October 3, 2011 Share Posted October 3, 2011 the 2.5i engines will run fine on nearly anything. I even put mobil 1 in mine when I had it Link to comment Share on other sites More sharing options...
