bbarnhill Posted August 6, 2012 Author Share Posted August 6, 2012 Yep ... Ill add it asap. Copied this info to my desktop and Ill add it later got to run to work Link to comment Share on other sites More sharing options...
joeleodee Posted December 13, 2012 Share Posted December 13, 2012 This software has been an invaluable tool while I work to tune my own vehicle. However, I was wondering if anyone else has run into this issue. It seems that I've been out logging while it has been very windy. Logs themselves look clean, but some of the dyno plots just look erratic. The car is not knocking so it's not like it pulls timing. The road is perfectly flat where I take the car so the only thing I can think of to cause plots that look like the following is big gusts of wind. Anyone else have graphs that look like this? The datalog is provided. And yes, I know I'm leaning a bit up top, and that is currently being addressed. romraiderlog_20121212_120752.csv Link to comment Share on other sites More sharing options...
iNVAR Posted December 13, 2012 Share Posted December 13, 2012 maybe don't use absolute timestamps. Link to comment Share on other sites More sharing options...
technicalgarage Posted December 13, 2012 Share Posted December 13, 2012 Like iNVAR says, I'm pretty sure the issue is due to the timestamp format. Switching to the "normal" time counter will probably fix that. Link to comment Share on other sites More sharing options...
joeleodee Posted December 13, 2012 Share Posted December 13, 2012 All my dyno plots don't necessarily look like this, but now that you mention it, most are somewhat squiggly. This one is just the most extreme. I'll try that out. Thanks. Link to comment Share on other sites More sharing options...
joeleodee Posted December 13, 2012 Share Posted December 13, 2012 Yep, that worked. I found a datalog from previous runs that had a normal timestamp, copied and pasted, and the line smoothed out. Numbers were a bit off, but just did it to test out. I'll run with the standard timestamp from now on. Link to comment Share on other sites More sharing options...
bbarnhill Posted December 13, 2012 Author Share Posted December 13, 2012 is there a difference in absolute time stamps in RR? Anyone got an example so I can may be get to the bottom of this issue? Link to comment Share on other sites More sharing options...
joeleodee Posted December 14, 2012 Share Posted December 14, 2012 I don't really know exactly what you're asking, but in my post above (#227), my datalog shows the absolute timestamp (which can be selected in romraider when you log to file). The following datalog I took today using the default timestamp. One thing of interest is that my numbers seem low. Only 278 whp is about 10whp more than my stg2 tune, but my engine load is about .5 g/rev higher and my airflow is 80 g/s higher. MafV is also up from about 4.3 to 4.6v. This was all recorded on flat roads. Some of my logs before using the absolute timestamp showed 300+ whp not even to redline which I would expect from this setup.  I do appreciate that the developer of this software is showing an interest in trying to provide an answer to these little quirks. romraiderlog_20121213_191020.csv Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted December 14, 2012 Share Posted December 14, 2012 I doubt your wagon weights 3560 with you in it+the stuff in your car. Link to comment Share on other sites More sharing options...
iNVAR Posted December 14, 2012 Share Posted December 14, 2012 Turn on fast polling in RR. Your sample rate of 250ms could be much improved upon... You could be doing about 70ms instead. Link to comment Share on other sites More sharing options...
joeleodee Posted December 14, 2012 Share Posted December 14, 2012 I doubt your wagon weights 3560 with you in it+the stuff in your car. Do you think higher or lower? I actually have a sedan limited which reports a curb weight of 3365. I'm 175 and figure mabe 20 pounds of junk in my car. Turn on fast polling in RR. Your sample rate of 250ms could be much improved upon... You could be doing about 70ms instead. I'll try that and report back. Thanks. Link to comment Share on other sites More sharing options...
Kastley85891 Posted December 30, 2012 Share Posted December 30, 2012 Great tool, used it for many a tune. Thanks Brad Link to comment Share on other sites More sharing options...
bbarnhill Posted January 5, 2013 Author Share Posted January 5, 2013 Joeleodee: dont use fast polling in RR Ive proven its flawed in its sampling. Others have seen it too. I cant get them to understand that there is a problem but Im sure you will be able to notice it when you graph it and there are spikes in virtual dyno. The RPM values and time values do not match up or something. I can show you if you try it and get some weird anomalies. I spent hours tracking this issue down and proving it. Kastley85891: WHY THANK YOU!!! Glad it helps you out as that is what I created it for. I wanted the community to be able to tune easier and so I created this tool to help the whole community out. Im glad you thinks its worthy of the praise. Ill keep making it better if I ever get time away from this home construction my GF is 'letting' me do. Link to comment Share on other sites More sharing options...
cryo Posted January 5, 2013 Share Posted January 5, 2013 Edited for not doing more research before asking a simple question.  Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community  cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
iNVAR Posted January 5, 2013 Share Posted January 5, 2013 Joeleodee: dont use fast polling in RR Ive proven its flawed in its sampling. Others have seen it too. I cant get them to understand that there is a problem but Im sure you will be able to notice it when you graph it and there are spikes in virtual dyno. The RPM values and time values do not match up or something. I can show you if you try it and get some weird anomalies. I spent hours tracking this issue down and proving it. I know the phenomenon you're referring to. I noticed it back in August 2011. http://legacygt.com/forums/showthread.php/hows-my-lvi-168185.html?p=3520285#post3520285 Supposedly it happens even with fast polling switched off, but because the sampling rate is that much lower, it's not as apparent. Link to comment Share on other sites More sharing options...
iNVAR Posted January 5, 2013 Share Posted January 5, 2013 Err, cryo, isn't that what the profiles are for? I have my vehicle proconfigured and I just load my runs up and that's it. Link to comment Share on other sites More sharing options...
cryo Posted January 5, 2013 Share Posted January 5, 2013 Im sure it is, i really should have looked into it more before asking, i guess i didnt spend enough time tinkering.  Thanks Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community  cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
cryo Posted January 5, 2013 Share Posted January 5, 2013 I know the phenomenon you're referring to. I noticed it back in August 2011. http://legacygt.com/forums/showthread.php/hows-my-lvi-168185.html?p=3520285#post3520285 Supposedly it happens even with fast polling switched off, but because the sampling rate is that much lower, it's not as apparent. I have seen this as well, you really have to look at the data and dump out what doesnt "look" right. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community  cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
RooTBeeR Posted January 5, 2013 Share Posted January 5, 2013 HEY! I found you on here too! Â however I have no way to log this car yet. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
bbarnhill Posted January 8, 2013 Author Share Posted January 8, 2013 RooTBeeR ... i see you on here too!!! Link to comment Share on other sites More sharing options...
JMLegacy Posted September 9, 2013 Share Posted September 9, 2013 New update out. Fixes the annoying "File already opened in excel" bug, amongst other things. Link to comment Share on other sites More sharing options...
adosdrummer Posted September 9, 2013 Share Posted September 9, 2013 VD has been such a good tuning tool with the data analyzer graphs. Next update though I would love to be able to use more than one file on the analyzer at once. Link to comment Share on other sites More sharing options...
