tori24 Posted January 2, 2011 Share Posted January 2, 2011 Be warned! LGT nudity, once started you won't stop until you go completely naked how did you manage to cover up the holes from where the oval subaru emblem is? Link to comment Share on other sites More sharing options...
cs2425 Posted February 14, 2011 Share Posted February 14, 2011 Hey guys I'm having some issues getting all of the residue/"ghosting" removed when debadging. I used goo gone and a 100% cotton t shirt. I even used a credit card on a small area to try and scrape it off and it's not doing anything. Here's a pic: http://www.milehighbuilt.com/debadge.jpg Any suggestions? '06 LGT Link to comment Share on other sites More sharing options...
bronconia Posted February 15, 2011 Share Posted February 15, 2011 I was having the same problems...ended up going with a hairdryer for a while, then more rubbing, hair dryer, rubbing...I never could get it completely off. It got to the point where you could BARELY see it (mostly in direct sunlight), but it was still there. Ended up going to a local car detail place and gave the guy 20 bucks to bust out the heavy duty buffer. Link to comment Share on other sites More sharing options...
BAC5.2 Posted February 15, 2011 Share Posted February 15, 2011 Go to the auto parts store and get a Clay Bar. Then spend a few hours scrubbing. It takes a while, but it's totally worth it. I spent the better part of a day washing, clay'ing, drying, and waxing my car. It was totally worth it, and it looked better than new. The whole car glowed when I was done. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
cs2425 Posted February 15, 2011 Share Posted February 15, 2011 Nice, thanks guys. I'll try the clay bar. If not, $20 isn't bad for buffering. I soaked and scrubbed for a solid 20 min and didn't see much of a difference. I have time tomorrow to do it so I will put some more work into it. Thanks again. Link to comment Share on other sites More sharing options...
Texan Posted March 18, 2011 Share Posted March 18, 2011 I am in CA and mine had the PZEV badge. I wanted that off. I have done this on previous cars, and works well. Get a hair dryer, or heat gun on the lowest setting and hold at least 18" away. Just heat a little to get the adhesive a little warm. Take some fishing line, put on leather gloves so you don't cut your skin, and "floss" slowly back and forth under the badge. It will come off. Once all the badges are off, you'll need the hair dryer again. Get the adhesive warm again, and roll it off with your thumb. It will come off in little balls. If you get an area that just won't come off, try a very small amount of Goo Gone. I have done that on 3 prior cars, including a black Mazda, and no harm to the clear coat. Then I use a cleaner wax, and wax the entire area smooth. Then I wash, really more to get any possible leftover of Goo Gone off of there, and of there is any residual adhesive, dirt will stick to it and you can get it off. Or run your fingers over the area and feel for adhesive. I usually do this in the garage or shade. Link to comment Share on other sites More sharing options...
mm347 Posted October 1, 2011 Share Posted October 1, 2011 In the past I managed with floss (mint flavored lol), goo gone, and clay bar. Link to comment Share on other sites More sharing options...
boymk123 Posted October 3, 2011 Share Posted October 3, 2011 pull it off first with pliers, try not to hit the trunk, then goo-gone the gunk, and buff it off with wax, done, less than 10 mins Link to comment Share on other sites More sharing options...
leggylife22 Posted May 6, 2012 Share Posted May 6, 2012 I think if you lower the 2.5GT to the corner of the trunk lid, it might look okay. Or get rid of the 2.5 and keep just the GT. I debaged everything except the Subaru emblem in the middle and the gt and it looks good Link to comment Share on other sites More sharing options...
Socalturbo Posted June 28, 2012 Share Posted June 28, 2012 My cars an 06 RGP, if i were to debadge it now, would the oultine in the paint be possible to remove do to the sun exposure? Link to comment Share on other sites More sharing options...
kulcha Posted July 10, 2012 Share Posted July 10, 2012 I just debaged my 05 GRP yesterday. Drove home in the sun from work (45 minutes) so when I got home I used some fishing line to pull them off. Goof Off removed the majority of the adhesive, and was left with slight ghosting. Purchased Meguiar's Smooth Surface Clay Kit (~20$) and repeated the process several times followed by a Meguiar's rub on wax. Currently I can not see any blemishes or ghosting from the badges despite removing them ~7 years later. Took some elbow grease, but if the paint is in decent shape I believe you should be fine. Link to comment Share on other sites More sharing options...
__Zeus__ Posted July 12, 2012 Share Posted July 12, 2012 I just debaged my 05 GRP yesterday. Drove home in the sun from work (45 minutes) so when I got home I used some fishing line to pull them off. Goof Off removed the majority of the adhesive, and was left with slight ghosting. Purchased Meguiar's Smooth Surface Clay Kit (~20$) and repeated the process several times followed by a Meguiar's rub on wax. Currently I can not see any blemishes or ghosting from the badges despite removing them ~7 years later. Took some elbow grease, but if the paint is in decent shape I believe you should be fine. Good to know. I was going to do my 05 and was wondering... now I know. I'm doing it. Thanks. Link to comment Share on other sites More sharing options...
freebengrad Posted January 27, 2013 Share Posted January 27, 2013 http://img560.imageshack.us/img560/7499/img2282o.jpg came out perfect Link to comment Share on other sites More sharing options...
Joe pa Posted February 22, 2013 Share Posted February 22, 2013 Think I may do this, I've been leary cause I didn't want to see any ghosting. Link to comment Share on other sites More sharing options...
Lawson Posted April 20, 2013 Share Posted April 20, 2013 Datass not too bad for a cell pic... no ghosting at all. goo gone, simple green then wax, taadaa! Link to comment Share on other sites More sharing options...
zepplinluvr2 Posted June 5, 2013 Share Posted June 5, 2013 I wanna know where to get that JDM Legacy Badge. Link to comment Share on other sites More sharing options...
CrazyKyu Posted October 8, 2013 Share Posted October 8, 2013 Just removed the lettering from my 05. Didn't need any fishing line or floss just pulled em off by hand. The LEGACY and 2.5GT came off great, but the SUBARU glue was hard and took a bit more work. Actually got some blisters while rubbing off the tacky stuff. Finished it off with some clay and it looks great. Link to comment Share on other sites More sharing options...
05 Legacy GT Posted November 9, 2013 Share Posted November 9, 2013 Just de badged my trunk today. Love the clean look!! Link to comment Share on other sites More sharing options...
stublast Posted May 17, 2016 Share Posted May 17, 2016 Just did my 10 LGT, a steam iron, dental floss, and WD40 with an old cotton T-shirt did the trick. Thank you guys! Link to comment Share on other sites More sharing options...
Legaroo Posted September 12, 2016 Share Posted September 12, 2016 Never thought to use fishing line! Can't wait to get at this tomorrow! Link to comment Share on other sites More sharing options...
JustCallMeNick Posted September 25, 2016 Share Posted September 25, 2016 Dang kids and their debadging! In my day you, you left the badge on the car, and you liked it! Haha when I bought my Legacy I actually had to pay $50 to buy a new one to put back ON the car haha. I was annoyed. Link to comment Share on other sites More sharing options...
