bmx045 Posted May 11, 2011 Share Posted May 11, 2011 Why do you want an ebcs? out of curiosity Link to comment Share on other sites More sharing options...
Ryouske Posted May 11, 2011 Author Share Posted May 11, 2011 I just feel it'd make it easier to control. Link to comment Share on other sites More sharing options...
bmx045 Posted May 11, 2011 Share Posted May 11, 2011 Well once tuned, there's no need to touch the MBC ever again unless you mod and then you'll require a new tune and usually an adjustment of the MBC. Unless AVO is using a funky pseudo ecu to use an ebcs(since the 2.5i doesn't have an ECU capable of managing the factory EBCS), a MBC should be all that's needed to do the job. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 12, 2011 Share Posted May 12, 2011 I would agree but Paul @ AVO tested the theory and he found that the turbo setup behaves differently when cold vs warm on the EJ253. I think he said boost is more linear with the EBCS. I think the ability to adjust "boost gain" on the fly is a reason. If/when I get this kit for my 2.5i I will go with a EBC b/c I will want to monitor boost to combat boost creep Link to comment Share on other sites More sharing options...
bmx045 Posted May 12, 2011 Share Posted May 12, 2011 Hmmm, what kind of fluctuations are we talking about? Fiddling with a boost controller can spell disaster if not done precisely to what corresponds with the tune map. But good point about creep, higher compression engine with a generous amount of flow with low set psi and the wastegate can't divert enough flow as rpms get high. Hmmmm. Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 12, 2011 Share Posted May 12, 2011 You don't map fuel and timing to a particular boost. You build a giant table, and values for fuel and timing are plucked from that table using things like MAF/MAP, RPM, load, etc. So as long as there are definitions for all combinations of those variables, there isnt a "disaster" zone. If there are definitions for it, and those areas are tuned, you can change boost however you want. I'd go EBC. They aren't that expensive, and it's a pretty useful device if you are running a system that does not include boost control. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
bmx045 Posted May 12, 2011 Share Posted May 12, 2011 Interesante. I'm not sure how this kit is setup, with an up/dp or whatnot?, curious to learn how the EBCS would be controlled- user controllable or standalone ECU? Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 12, 2011 Share Posted May 12, 2011 EBCS ≠ EBC. The EBCS is the solenoid. The EBC is the controller. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
bmx045 Posted May 12, 2011 Share Posted May 12, 2011 oh well there you go. bump, I guess the kit arrives today? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted May 12, 2011 Share Posted May 12, 2011 The EBCS is a stand alone system that interacts with the kit and allows for finer tuning and feedback of what is going on under load Link to comment Share on other sites More sharing options...
bmx045 Posted May 12, 2011 Share Posted May 12, 2011 Interesante. Where are these PICSSSS? Link to comment Share on other sites More sharing options...
Ryouske Posted May 12, 2011 Author Share Posted May 12, 2011 Kit is at the shop. Looks like the car is getting dropped off around 4 tonight. I should have pics up tomorrow! Stay tuned! Anyone else as excited as I am? Link to comment Share on other sites More sharing options...
bmx045 Posted May 12, 2011 Share Posted May 12, 2011 I demand pics today. Link to comment Share on other sites More sharing options...
Ryouske Posted May 12, 2011 Author Share Posted May 12, 2011 Well unfortunately I am at work till 1030 just gettin the car there today took a lot of creativity and calling in favors. 2 people to get it there plus one friend who's loaning me their second car. Link to comment Share on other sites More sharing options...
Ryouske Posted May 12, 2011 Author Share Posted May 12, 2011 Car is on it's way to the shop. I will be there tomorrow morning to cover the install. I'll prob stay till about 1pm so look forward to some pics. Link to comment Share on other sites More sharing options...
N.sane Posted May 12, 2011 Share Posted May 12, 2011 Link to comment Share on other sites More sharing options...
Ryouske Posted May 12, 2011 Author Share Posted May 12, 2011 I know I know. Being stuck at work is killing me. Link to comment Share on other sites More sharing options...
Firepuma Posted May 13, 2011 Share Posted May 13, 2011 this is the thread yes? Link to comment Share on other sites More sharing options...
SubaruTim Posted May 13, 2011 Share Posted May 13, 2011 Good luck! Link to comment Share on other sites More sharing options...
Ryouske Posted May 13, 2011 Author Share Posted May 13, 2011 this is the thread yes? For...???? Link to comment Share on other sites More sharing options...
thestratomaster Posted May 13, 2011 Share Posted May 13, 2011 For...???? awesomeness. duh Link to comment Share on other sites More sharing options...
rock2534 Posted May 13, 2011 Share Posted May 13, 2011 Interested to see some pics/vids.....hope this goes well for you. Link to comment Share on other sites More sharing options...
Ryouske Posted May 13, 2011 Author Share Posted May 13, 2011 So somehow ups sent my fmic to a whole other sorting facility and now it won't be here till the 17th. Andrew is going to get as much done as he can this weekend. So unfortunately it's gonna be awhile till I get my car back. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted May 13, 2011 Share Posted May 13, 2011 How disappointing! Try to have fun and salvage the weekend. Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 13, 2011 Share Posted May 13, 2011 So no pics? Dangit. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
