Bochim Posted October 22, 2013 Share Posted October 22, 2013 Nice car. Been looking into doing something similar with mine. Sounds like alot of work and $$$$. Thank you for all the info, lots to think about. Link to comment Share on other sites More sharing options...
Hops Posted May 17, 2014 Author Share Posted May 17, 2014 Koyo radiator decided to fail on me. I hardly even drive the car! Hopefully RallySport Direct and/or Koyo are willing to take care of this for me. http://i111.photobucket.com/albums/n121/JDMChizad/LGT%20build/D37EBD64-BA33-426D-8FC9-766DC9B16614.jpg Buy my cars! Link to comment Share on other sites More sharing options...
KBGRIZZLY64 Posted May 17, 2014 Share Posted May 17, 2014 Oh wow that's something you don't see very often Sent from my HTC6525LVW using Tapatalk Priorities change when car parts come into the equation Link to comment Share on other sites More sharing options...
SBT Posted May 17, 2014 Share Posted May 17, 2014 I've never seen a Koyo fail before. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
m sprank Posted May 19, 2014 Share Posted May 19, 2014 Could be more to the story. Technically there is no warranty. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 19, 2014 Share Posted May 19, 2014 Could be more to the story. that's what I'm thinking...are we sure the radiator is not getting over pressurized ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Hops Posted May 19, 2014 Author Share Posted May 19, 2014 What would cause it to over-pressurize? Radiator is out and I can't see any problems so I'm going to see if there could be something else causing the leak. Might have it pressure tested. Bought some DEI Titanium wrap for my header as well. Buy my cars! Link to comment Share on other sites More sharing options...
Max Capacity Posted May 19, 2014 Share Posted May 19, 2014 HG leak ? I'm just guessing, trying to help figure out what may have happened. Those things don't normally fail. But also, nothing is perfect. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Hops Posted May 19, 2014 Author Share Posted May 19, 2014 That would suck... I've had enough fun with head gaskets on my Outback! It would be a reason to build internals, though. Buy my cars! Link to comment Share on other sites More sharing options...
m sprank Posted May 19, 2014 Share Posted May 19, 2014 Hopefully no zip ties through the core holding other accessories. That could easily cause a leak. Technically rad should not over pressurize as the cap is supposed to go first. Link to comment Share on other sites More sharing options...
Hops Posted May 19, 2014 Author Share Posted May 19, 2014 Nope Buy my cars! Link to comment Share on other sites More sharing options...
doccrowley Posted May 20, 2014 Share Posted May 20, 2014 Did you save the anti-freeze? If so, have the hydrocarbon test done to.see if hg failure. Link to comment Share on other sites More sharing options...
Hops Posted May 20, 2014 Author Share Posted May 20, 2014 I did. Where do you get the test done? Buy my cars! Link to comment Share on other sites More sharing options...
doccrowley Posted May 20, 2014 Share Posted May 20, 2014 Metric did the test for me, but that was almost 2 years ago. Link to comment Share on other sites More sharing options...
benena Posted May 21, 2014 Share Posted May 21, 2014 Oh yeah and here's a short vid from today. Expected my iPhone to flip sideways for the engine shot, but didn't happen. So deal with it. I'll get some vids on the dyno next week. http://i111.photobucket.com/albums/n121/JDMChizad/th_a25253b3.jpg How did you get that stromung to fit so high? Link to comment Share on other sites More sharing options...
Hops Posted May 21, 2014 Author Share Posted May 21, 2014 Polyurethane bushings Buy my cars! Link to comment Share on other sites More sharing options...
Hops Posted May 22, 2014 Author Share Posted May 22, 2014 Just had the radiator tested... No leaks. Buy my cars! Link to comment Share on other sites More sharing options...
KBGRIZZLY64 Posted May 22, 2014 Share Posted May 22, 2014 May the search begin Sent from my HTC6525LVW using Tapatalk Priorities change when car parts come into the equation Link to comment Share on other sites More sharing options...
Hops Posted May 22, 2014 Author Share Posted May 22, 2014 Yep. So exciting. Buy my cars! Link to comment Share on other sites More sharing options...
mwiener2 Posted May 23, 2014 Share Posted May 23, 2014 nicked hose from the caps to the overflow bottle My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Hops Posted May 23, 2014 Author Share Posted May 23, 2014 Nope. It's coming from the bottom. Just orderd the hard line that runs from the thermostat to the oil filter housing. That piece was right up against my manifold so I'm wondering if that may have cracked it. When I pulled that piece off along with the elbow hoses, one of the hoses had a small hole in it. I'm hoping that's the problem and I didn't do it by using force to pull it off. I also heat-wrapped the manifold. I still need to take out the uppipe and wrap it as well. Buy my cars! Link to comment Share on other sites More sharing options...
Max Capacity Posted May 23, 2014 Share Posted May 23, 2014 Coolant crossover tube. They should be replaced when the engine is rebuilt. I did the hoses on both ends too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
doccrowley Posted May 23, 2014 Share Posted May 23, 2014 If it weren't summer, you should just build the motor. I've got a donor SB just waiting for somebody to pick it up.... Needs #1 rod/piston, possibly cylinder bore. 15K Metric build, just like Christians other builds. Make me an offer I can't refuse. And, good news that the radiator is good! I thought it was your head gaskets cause it came and went and came back. I hope it is not. Link to comment Share on other sites More sharing options...
Hops Posted May 23, 2014 Author Share Posted May 23, 2014 Find out soon... That hard line will be here next week. I would like that short block... Buy my cars! Link to comment Share on other sites More sharing options...
PimpFro Posted May 24, 2014 Share Posted May 24, 2014 same here Pure Adrenaline Attached... To A License Plate Link to comment Share on other sites More sharing options...
