babybaluga32 Posted February 26, 2011 Share Posted February 26, 2011 My youtube channel- http://www.youtube.com/user/atomicrider4?feature=mhum So ,,,,,,,,,,,,,,,,,,, Turbo td04l-13t@12psi RRFPR WRX 440 top feeds PWR front mount intercooler Suspension 04 Wrx struts with 04 STI Springs Exhaust 2.5 Vibrant resonator and muffler(1046) Catless ............................................................................. Engine Phase 1 ej22e block Phase 2 port and polished sohc heads ej22t pistons ACL Race main and rod bearings WRX oil pump ej22e water pump (exact same as ej22t, but the 22T has a second output port. Phase 1 water pumps are dinky!) <li>Tranny 5mt swap ...........................................................This is my muffler. and my piston breaking. [ame=http://www.youtube.com/watch?v=khx_p_6PJFQ]Y[/ame] Link to comment Share on other sites More sharing options...
Zues Marine Posted February 26, 2011 Share Posted February 26, 2011 best muffler ever!! Link to comment Share on other sites More sharing options...
2000_LegacyOutback Posted February 26, 2011 Share Posted February 26, 2011 sounds amazing Link to comment Share on other sites More sharing options...
babybaluga32 Posted February 26, 2011 Author Share Posted February 26, 2011 So I ordered a gasket set for a SOHC 2.2. But I got what I believe to be DOHC 2.2. Besides the exhaust manifold gaskets not working, will I run into any other problems? Link to comment Share on other sites More sharing options...
Baddog Posted February 26, 2011 Share Posted February 26, 2011 No such thing as a DOHC 2.2. You mean dual port heads. Anyways I am not sure how to answer your question after that since I am not sure. But for the most part the engines stayed the same throughout the years. Link to comment Share on other sites More sharing options...
babybaluga32 Posted February 27, 2011 Author Share Posted February 27, 2011 What heads can I use without getting a piggyback or standalone? That will fit my phase 2 intake mani Link to comment Share on other sites More sharing options...
Baddog Posted February 27, 2011 Share Posted February 27, 2011 I think in 99 you can use the DOHC heads from the EJ25D or EJ251? Have to do some research of your own but if you could those would be your options. EJ251 is a SOHC motor (RS2.5 Motor) and EJ25D is GT/Outback motor and 98 RS 2.5 Motor Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 1, 2011 Author Share Posted March 1, 2011 So I have officially givin up on my phase 2 block. I honed the shit out of it and it wouldnt get a 'lump' out. I have a phase 1 22e. Thrust is in #3 instead of #5 1)What else is different? 2)Will I have problems with my gasket set for a 99? 3)Can I use my Phase 2 heads? Link to comment Share on other sites More sharing options...
Snydas_99legacy Posted March 1, 2011 Share Posted March 1, 2011 Use the phase 2 block and darton sleeve it lol.. Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 2, 2011 Author Share Posted March 2, 2011 Jeepers! They are expensive! ____________________________ I got my clutch today I also ordered ACL race bearings 52mm in #3 And ported one of my heads. It looks SEXYYY! (I haven't even started to rebuild my head)Puke on my face. Im not looking forward to it! Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 2, 2011 Author Share Posted March 2, 2011 2) no you wont, they are the same. all the gaskets for the heads changed. 3) yes. Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 2, 2011 Author Share Posted March 2, 2011 I still cant find ej22t rings that actually fit, they are all 1.2x1.5, there is a ton of gap on the top ring (haven't measured it yet), but I have the old ones and they are significantly bigger Link to comment Share on other sites More sharing options...
subikid90 Posted March 2, 2011 Share Posted March 2, 2011 Did you try the dealership for the rings? They have to have something somewhere. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 4, 2011 Author Share Posted March 4, 2011 I dont know if anybody else has done this but it looks alot better without it IMO. http://img145.imageshack.us/img145/9130/hlight.jpg http://img3.imageshack.us/img3/5135/hlight2.jpg Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 4, 2011 Author Share Posted March 4, 2011 To porta the dirty heads!!! Top in progress, bottom stock. http://img268.imageshack.us/img268/9174/poorta.jpg Link to comment Share on other sites More sharing options...
98-lgt Posted March 4, 2011 Share Posted March 4, 2011 How did you get the yellow out of the headlight? Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 9, 2011 Author Share Posted March 9, 2011 I am putting the block back together and dont have any idea what im doing. Other than what the manual says... ANY SUGGESTIONS????????!!! Please! Link to comment Share on other sites More sharing options...
suby_guy86 Posted March 10, 2011 Share Posted March 10, 2011 same on the headlight question!!!! how without breaking anything? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted March 10, 2011 I Donated Share Posted March 10, 2011 pre heat your oven to about 300 degrees. put a wet towel or a piece of wood on the rack, and bake the headlight housing for a few minutes. this will soften the weather seal / glue they use to hold the lense on. You will be able to peel it off after the glue is soft. Thats how you get inside the housing to remove the reflector...or even paint the inside if you want to. The reasoning behind the towel / wood is so the metal doesn't burn the plastic housing. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 10, 2011 Author Share Posted March 10, 2011 ^ Thats a step beyond what I did. I took a dremel and cut out a space for the light to fall out underneath it. and it just pops off really easily. Then put clear silicone in the hole. Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 11, 2011 Author Share Posted March 11, 2011 Im going to Portland for the weekend so it wont be done till later next week. http://img846.imageshack.us/img846/3296/engina.jpg Link to comment Share on other sites More sharing options...
subikid90 Posted March 11, 2011 Share Posted March 11, 2011 whatcha doing in portland lol? Looks like it is almost done. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 14, 2011 Author Share Posted March 14, 2011 This little bastard got tapped and I cant get the bolt to stay in. What can I do? Could I cut a line in the middle of the bolt about half an inch and put something in it so it is slightly wider? http://img859.imageshack.us/img859/5379/photovn.jpg Link to comment Share on other sites More sharing options...
subikid90 Posted March 15, 2011 Share Posted March 15, 2011 Find a bigger bolt that will fit. Who tapped it? Ask them what tap they used. Looks like probably m12x1.25 or something close. Take the bolt that is suppose to fit to a hardware store and buy all the thread sizes for the bolt, the 1.25 part, then step up to the next size, the m12 parts, and buy all the threads for it. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 15, 2011 Author Share Posted March 15, 2011 I tapped it. That is what size I used. I bought a couple bolts today, but none worked. Ill give it another whirl. Thanks [/img] Link to comment Share on other sites More sharing options...
