subikid90 Posted March 15, 2011 Share Posted March 15, 2011 Does the tap go in and out smooth? Try using a dye on the bolt to see if it is correct. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 15, 2011 Author Share Posted March 15, 2011 I put the timing belt on and the Z1 and Z2 tooth count is off, but all the marks line up(more or less. Passhead does). The drivers side head is off by half a tooth but it is impossible for it to be lined up perfectly because the sprockets alignment mark is on a tooth and so is the belt.... Im very confused by this. Could Gates have printed half a tooth off? It was really hard to get the drivers head alignment to stay at the top. I think that valves are slightly pushed down? The crankshaft alignment is on the mark. Link to comment Share on other sites More sharing options...
subikid90 Posted March 15, 2011 Share Posted March 15, 2011 Mine was off half a tooth when I used the gate timing belt. I had it where you did and everything runs fine for me. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 16, 2011 Author Share Posted March 16, 2011 Ok cool! Thanks I dropped it down to the right. It lined up with the belt cover gap. http://img16.imageshack.us/img16/165/markoff.jpg Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 16, 2011 Author Share Posted March 16, 2011 http://img838.imageshack.us/img838/3296/engina.jpg Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 17, 2011 Author Share Posted March 17, 2011 Ok so I got it in and drove it about 10 miles. The first problem was it was over heating. Swapped the thermostat and thats fixed. The second and still existing is that 40% of the time when im taking off I can floor it and the rpms hardly move, and it will die. If it manages to not die and I shift it will do the same in every gear. Can the pressure plate be to tight? Im pretty sure I torqued it right. {{{{{{{{{{ It was the ECU being a tard ass, and the clutch not having enough free play. [ame=http://www.youtube.com/watch?v=BD7uxnY9y9Q]skip forward to 1:30[/ame] Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 18, 2011 Author Share Posted March 18, 2011 The overheating is gone. It idles like sh1t, it did before so its nothing new. but it dies when I come to a swift stop and have the clutch in. (it was because I hadnt ground the the pin on the ecu ) Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 19, 2011 Author Share Posted March 19, 2011 vrmmm vrmm I love Youtube HD [ame=http://www.youtube.com/watch?v=nSYV5OG4I6Y]YouTube - Ej22et[/ame] Link to comment Share on other sites More sharing options...
subikid90 Posted March 19, 2011 Share Posted March 19, 2011 Are you still running stock ECU with no engine management?? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 24, 2011 Author Share Posted March 24, 2011 Soo... ive been pulling insanely fouled plugs for the last few days. Turns out my check engine light was out. Swapped in my airbag light and WHHAAAbam! Check engine light was on! It was a P0102.. MAF low voltage Bought MAF cleaner, cleared it and drove. It sounded beautiful for 3 miles, then the CEL came on again, but didnt run or sound bad. Is it bad and just worked for a bit? or do I need to reset my ecu and reclear it? Link to comment Share on other sites More sharing options...
Lookatmyrust Posted March 24, 2011 Share Posted March 24, 2011 try that. unpluged for 30 min. we should figure out how to add a reset button to the ECU and by we i mean someone who is insanly smart with car computers Link to comment Share on other sites More sharing options...
amorgan93 Posted March 24, 2011 Share Posted March 24, 2011 Nice job man glad everything went semi-well in the build. My old legacy had a check engine light for maf and ran like crap until i cleaned it and it ran better but light still stayed on. But it was a 1990 with obd1. Are u just using stock ecu? No piggyback? Link to comment Share on other sites More sharing options...
amorgan93 Posted March 24, 2011 Share Posted March 24, 2011 Oh and btw on youtube select "make available for mobile devices" please so i can watch them. : ) Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 25, 2011 Author Share Posted March 25, 2011 So my light came on again and this time it was P0500 Vehicle Speed Sensor. My speedo isnt hooked up, im not sure if that causes a code or not. The CEL also blinked 5 times maybe 6 and I didnt notice the first Hmmmm I searched everywhere for the phone thing... Couldnt find it. Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 25, 2011 Author Share Posted March 25, 2011 http://img823.imageshack.us/img823/3153/subb.jpg Link to comment Share on other sites More sharing options...
TRSCobra Posted March 25, 2011 Share Posted March 25, 2011 That intercooler is nothing but a paperweight without a hood scoop. Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 25, 2011 Author Share Posted March 25, 2011 It probably heats the air up even more Link to comment Share on other sites More sharing options...
babybaluga32 Posted March 29, 2011 Author Share Posted March 29, 2011 Everytime im on the highway, floor it (gets over 5k but not by much 65mph+) in 5th and then let off the gas, a HUGE flume of white/blueish cloud of smoke comes out. 1st 2nd 3rd going to red line does not do this, I cant speak for 4th. Any ideas? Im scared to ask :/ I have a leak from my tranny that goes directly onto my header, but I dont think it is related. Turbo is not leaking on the outside. Its confusing because 5k is 5k, 65mph or not, 1st or 5th. I should add this was when my maf was dirty and 02's were clogged. fouled plugs too. Dont know if that matters. rich as can be. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted March 29, 2011 Share Posted March 29, 2011 That intercooler is nothing but a paperweight without a hood scoop. +10,000. GT hood scoop ftw. 99 wagon is awesome. Link to comment Share on other sites More sharing options...
babybaluga32 Posted April 7, 2011 Author Share Posted April 7, 2011 Watch it in HD [ame=http://www.youtube.com/watch?v=WCXrJ5pNHhI]YouTube - Subaru ej22et[/ame] Link to comment Share on other sites More sharing options...
amorgan93 Posted April 8, 2011 Share Posted April 8, 2011 so are you using the stock ECU or do you have any engine management? Link to comment Share on other sites More sharing options...
babybaluga32 Posted April 8, 2011 Author Share Posted April 8, 2011 Stock ecu. Just fuel Management as of right now. I may be buying emange blue soon. I dont know what all I need with it though..... connectors wise... Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted April 8, 2011 Share Posted April 8, 2011 Everytime im on the highway, floor it (gets over 5k but not by much 65mph+) in 5th and then let off the gas, a HUGE flume of white/blueish cloud of smoke comes out. 1st 2nd 3rd going to red line does not do this, I cant speak for 4th. Any ideas? Im scared to ask :/ I have a leak from my tranny that goes directly onto my header, but I dont think it is related. Turbo is not leaking on the outside. Its confusing because 5k is 5k, 65mph or not, 1st or 5th. I should add this was when my maf was dirty and 02's were clogged. fouled plugs too. Dont know if that matters. rich as can be. The first issue sounds like an oil leak. Turbo is probably leaking on the inside a little bit. With the second issue, it's better than you're running rich instead of lean, even though you're probably going through gas like crazy. The ECU is probably at the limits of what it can process with that turbocharger on... Link to comment Share on other sites More sharing options...
babybaluga32 Posted April 10, 2011 Author Share Posted April 10, 2011 I took my inlet hose off where it meets my intercooler. It was dripping oil! Am I going to be disappointed in the spooling time of a td04? Is the wastegate at 14 psi or 10? I start boost at 2k right now and dont really want to loose that! Will it bolt right onto my current up and downpipe? Link to comment Share on other sites More sharing options...
babybaluga32 Posted April 13, 2011 Author Share Posted April 13, 2011 A gas 'leak' I walked out to after starting my car. http://img850.imageshack.us/img850/7726/gasss.jpg Link to comment Share on other sites More sharing options...
