Babybalugas build thread 
My youtube channel- http://www.youtube.com/user/atomicrider4?feature=mhum
So
Turbo
td04l-13t@12psi
RRFPR
WRX 440 top feeds
PWR front mount intercooler
Suspension
04 Wrx struts with 04 STI Springs
Exhaust
2.5 Vibrant resonator and muffler(1046) Catless
Engine
Phase 1 ej22e block
Phase 2 port and polished sohc heads
ej22t pistons
ACL Race main and rod bearings
WRX oil pump
ej22e water pump (exact same as ej22t, but the 22T has a second output port.
Phase 1 water pumps are dinky!)
<li>Tranny
5mt swap
...........................................................This is my muffler. and my piston breaking.
[ame=http://www.youtube.com/watch?v=khx_p_6PJFQ]Y[/ame]
  • Replies 127
  • Created
  • Last Reply
I think in 99 you can use the DOHC heads from the EJ25D or EJ251?
Have to do some research of your own but if you could those would be your options. EJ251 is a SOHC motor (RS2.5 Motor) and EJ25D is GT/Outback motor and 98 RS 2.5 Motor
So I have officially givin up on my phase 2 block.
I honed the shit out of it and it wouldnt get a 'lump' out.
I have a phase 1 22e.
Thrust is in #3 instead of #5 :(
1)What else is different?
2)Will I have problems with my gasket set for a 99?
3)Can I use my Phase 2 heads?
Jeepers! They are expensive!
____________________________
I got my clutch today :)
I also ordered ACL race bearings 52mm in #3
And ported one of my heads. It looks SEXYYY!
(I haven't even started to rebuild my head)Puke on my face. Im not looking forward to it!
  • I Donated
pre heat your oven to about 300 degrees. put a wet towel or a piece of wood on the rack, and bake the headlight housing for a few minutes. this will soften the weather seal / glue they use to hold the lense on. You will be able to peel it off after the glue is soft.
Thats how you get inside the housing to remove the reflector...or even paint the inside if you want to. The reasoning behind the towel / wood is so the metal doesn't burn the plastic housing.
-broknindarkagain
My Current Project - Click Here
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
This little bastard got tapped and I cant get the bolt to stay in.
What can I do?
Could I cut a line in the middle of the bolt about half an inch and put something in it so it is slightly wider?
http://img859.imageshack.us/img859/5379/photovn.jpg
Find a bigger bolt that will fit. Who tapped it? Ask them what tap they used. Looks like probably m12x1.25 or something close.
Take the bolt that is suppose to fit to a hardware store and buy all the thread sizes for the bolt, the 1.25 part, then step up to the next size, the m12 parts, and buy all the threads for it.
