1-3-2-4 Posted February 3, 2015 Share Posted February 3, 2015 Yeah it sucked big time I had 4 layers on and I still got wet.. I was determined to get it done.. now that I see how it goes it's not so bad.. I started around 3 pm and was done around 10:30 pm snow kept ending up in my shoes getting my socks wet Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 3, 2015 Share Posted February 3, 2015 Wow. You're crazy man! Well you're done now. Now let's cross fingers you won't run into issues with the cruise control . Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 3, 2015 Share Posted February 3, 2015 I gotta replace the abs sensor to see if it's ok Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 3, 2015 Share Posted February 3, 2015 I wasted lots of time on these little suckers because the bolt that was holding broke both times . So I had to drill them out, rethread, etc.. Pain in the butt. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 3, 2015 Share Posted February 3, 2015 Man, doing that in a storm when its 18F outside. Your amazing, new respect. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 3, 2015 Share Posted February 3, 2015 What bolt broke? And yeah max I wanted to be back in my car so I did not care if it snowed or not Link to comment Share on other sites More sharing options...
Max Capacity Posted February 3, 2015 Share Posted February 3, 2015 I think he's talking about the 6mm ABS sensor bolts. You shouldn't need to touch them...unless you screwed something up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 3, 2015 Share Posted February 3, 2015 Yes, the bolt that is holding the abs sensor in place. Actually, you're supposed to pull the abs sensor out when you change wheel bearing according to the fsm. You can also see that in the video that I posted above. They claim that if you don't, you may risk damaging it with the axle hitting it I think while you swap the bearings. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted February 3, 2015 Share Posted February 3, 2015 I left them in and just held the axle when i removed the assembly. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 3, 2015 Share Posted February 3, 2015 I'll probably do that for my third bearing swap cause I don't want to deal with another broken bolt. What a pain.. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 3, 2015 Share Posted February 3, 2015 Oh the abs bolt.. oh yeah it was a little tight coming out.. I put anti seize on it as well as the hub and hub bolts Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 3, 2015 Share Posted February 3, 2015 Man, doing that in a storm when its 18F outside. Your amazing, new respect. I'm glad I did it before things started to melt a bit gotta get myself some toe warmers. Btw two of my lug nuts fell off somewhere had a loose wheel crazy as I used my impact wrench. I don't always go hard with the bolts with the gun due to no control so I normally use my torque wrench for the final. I'm seriously thinking about getting a electronic wrench, because having 4 different torque wrenches is no fun Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 3, 2015 Share Posted February 3, 2015 Oh the abs bolt.. oh yeah it was a little tight coming out.. I put anti seize on it as well as the hub and hub bolts Yeah I also put anti seize on every single bolts too. When I changed my bearing, I also changed every single bushing in the rear suspensions with whiteline stuff. Took a while to do. fwiw, took the car for a spin. Nice and quiet. So far, no cruise control issue with the moog bearing installed on the right rear wheel. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 3, 2015 Share Posted February 3, 2015 I guess that humming sound was the bearing all that time.. I thought it was the run flat tires.. When I pulled the abs code I got a code for the front left as well, I will have to buy a replacement sensor for the right rear.. I don't use cruise control much anyways Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 3, 2015 Share Posted February 3, 2015 Why do you have to change the sensor on the right rear wheel? Did it get damaged? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 3, 2015 Share Posted February 3, 2015 Yes the ball bearings fell out.. did I not post the picture? It's pretty nasty in the video I did I show the sensor it wore away enough that you can see the copper inside Link to comment Share on other sites More sharing options...
xt2005bonbon Posted February 3, 2015 Share Posted February 3, 2015 Oh ok. Got it. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 4, 2015 Share Posted February 4, 2015 It's crazy how the magnetic ring is 100% missing must of been a lot of movement to have the metal ring to separate from the bearing Link to comment Share on other sites More sharing options...
SBT Posted February 4, 2015 Share Posted February 4, 2015 I'm surprised that it didn't shred your outboard CV boot too. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 4, 2015 Share Posted February 4, 2015 It's got a ring around it Link to comment Share on other sites More sharing options...
Nightmaresmk Posted February 4, 2015 Share Posted February 4, 2015 Make sure to use antiseize on your bolt during reassembly. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 4, 2015 Share Posted February 4, 2015 Yep that's taken care of its been good so far next is just to get off these blown struts I have to order the rears Link to comment Share on other sites More sharing options...
Cerebral_1 Posted July 19, 2015 Share Posted July 19, 2015 I've got a question of my own--hoping someone here can help me. I'm doing my driver's side rear HBA this weekend, and am having problems getting the axle nut off! The wheel is off and the parking brake is on and holding the rotor/hub pretty steady...but the axle nut is not budging with a breaker bar/extension (I feel like parts and/or tools are bending if I push hard enough). Unfortunately, I don't have access to an impact. The crimp was notched in pretty solidly to begin with; I couldn't pry it out, but I had to beat the crap out of the crimp, hoping to destroy the part holding on to the axle nut. Maybe that's part of my problem, but some have suggested that it should be possible to remove the axle nut without even messing with the crimp (i.e., the crimp is not meant to hold up to much torque), but it's not budging for me. Any ideas on what to try next? Is there anything else that could be holding it on (besides rust)? Yep, this thing has been soaked in PBB too. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 19, 2015 Share Posted July 19, 2015 I had to use a awl to get the notch out and I used my cordless impact and it came off with ease. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 19, 2015 Share Posted July 19, 2015 I've got a question of my own--hoping someone here can help me. I'm doing my driver's side rear HBA this weekend, and am having problems getting the axle nut off! The wheel is off and the parking brake is on and holding the rotor/hub pretty steady...but the axle nut is not budging with a breaker bar/extension (I feel like parts and/or tools are bending if I push hard enough). Unfortunately, I don't have access to an impact. The crimp was notched in pretty solidly to begin with; I couldn't pry it out, but I had to beat the crap out of the crimp, hoping to destroy the part holding on to the axle nut. Maybe that's part of my problem, but some have suggested that it should be possible to remove the axle nut without even messing with the crimp (i.e., the crimp is not meant to hold up to much torque), but it's not budging for me. Any ideas on what to try next? Is there anything else that could be holding it on (besides rust)? Yep, this thing has been soaked in PBB too. My breaker bar also slightly bent once while trying to get that bolt off. But I just switched it 'the other way' to bend it back straight, if that makes sense... Fairly soft metal I guess. In any case, I gave it more and more torque and the bolt finally came off. Link to comment Share on other sites More sharing options...
