Mega Users seabass07 Posted August 19, 2013 Mega Users Share Posted August 19, 2013 With ecu flash ? What version of ecu flash ? I'll have to check the laptop. I know its an older version. But it works flawlessly and always has. Are you using the tactrix drivers? Link to comment Share on other sites More sharing options...
frank_ster Posted August 20, 2013 Share Posted August 20, 2013 well i have both drivers installed. i use both free ssm and ecuflash regularly when i have the vag comm cable installed ecufash wants a licence key. i dont remember the exact specifics i'll need to try again and take some screen caps Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
jekasbalto Posted August 23, 2013 Share Posted August 23, 2013 All I really wanted to do was change the timing advance... stock is 15-16 wanted to make it 21... Link to comment Share on other sites More sharing options...
frank_ster Posted August 23, 2013 Share Posted August 23, 2013 ^ do you know the repercussions of that ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
fishbone Posted August 23, 2013 Share Posted August 23, 2013 He will, once the muffler bearings seize and the piston springs melt. Link to comment Share on other sites More sharing options...
jekasbalto Posted August 23, 2013 Share Posted August 23, 2013 ^ do you know the repercussions of that ? Yes of course! mpg lower and car will be a little more agressive... done it on bunch of car no prob! Link to comment Share on other sites More sharing options...
frank_ster Posted August 23, 2013 Share Posted August 23, 2013 uh .. you know its running like 46 deg just above idle right ? and you don't think subaru tried to optimize already ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted August 23, 2013 I Donated Too Share Posted August 23, 2013 Yes of course! mpg lower and car will be a little more agressive... done it on bunch of car no prob! http://www.journaldugeek.com/files/2013/04/batman_is_shocked.jpg Link to comment Share on other sites More sharing options...
fishbone Posted August 24, 2013 Share Posted August 24, 2013 I hope it's a troll. Link to comment Share on other sites More sharing options...
jekasbalto Posted August 24, 2013 Share Posted August 24, 2013 Well... you can say whatever... I've said what I've done before Link to comment Share on other sites More sharing options...
frank_ster Posted August 24, 2013 Share Posted August 24, 2013 well get a tatrix cable.. its ~200$ and maybe get another motor .. not that i / we want to be douchbags but we are all searching for more torque and fuel economy. the ignition is dynamically controled via ecm and knock sensor. and its operating on the edge of knock lready. if you advance the timming the ecm will take away what you added and take it away from everywhere else also. on some naturally aspirated engines if you switch to higher octain gas you can increase the timming and get some more torque as you say but this is default running higher octain. and these engines break ring lands stock. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
jekasbalto Posted August 24, 2013 Share Posted August 24, 2013 Well on impreza 2.0r engine ej204 same as mine it showed a huge improvement... runnnin fine for 2 month now! Becides I am in Europe right now and here they dont have 87-89-91(93) only 95-98... So the octane is abviously higher here... Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted August 24, 2013 Mega Users Share Posted August 24, 2013 The octane is on a different scale there, not actually higher. So...yea. Good luck with that. Link to comment Share on other sites More sharing options...
hadvw Posted August 24, 2013 Share Posted August 24, 2013 Well on impreza 2.0r engine ej204 same as mine it showed a huge improvement... runnnin fine for 2 month now! Becides I am in Europe right now and here they dont have 87-89-91(93) only 95-98... So the octane is abviously higher here... (because there's no facepalm icon) Link to comment Share on other sites More sharing options...
fishbone Posted August 26, 2013 Share Posted August 26, 2013 jekasbalto, like you've already been told, Europe uses a different scale for octane rating. Here in the US it's a ratio of MON/RON, which results to AKI or anti-knock index. In Europe, they post the RON value at the pump. The octane rating is more or less comparable there to what it is here; you should not rely on the fact that somehow octane is higher in Europe. It is not. In my homecountry the octane that is at the pump is typically 91, 95, 98 and sometimes you'll see 100. These are equivalent, more or less to our 87, 89, 91 and 93. http://en.wikipedia.org/wiki/Octane_rating Also, you fail to grasp several complexities as to why just messing with the timing advance is not only not recommended, but downright dangerous. You are being stubborn in your own ways and this will lead to issues down the road. Take a breather and take time to learn what is involved in getting a safe and healthy tune going. Well on impreza 2.0r engine ej204 The Legacy does not run that engine. Different ballgame altogether. It's like saying you've done it on Honda engines before so it should obviously work on all engines known to man. Do you have any idea how many new-to-Subaru guys reach for intakes and exhausts and do nothing else to this car because it worked on their Hondas before? Link to comment Share on other sites More sharing options...
frank_ster Posted August 26, 2013 Share Posted August 26, 2013 ^ i think europe has 2.0 n/a legacy .. and 2.0 turbo legacy. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
gimpydingo Posted August 27, 2013 Share Posted August 27, 2013 Can I use this with a vag-com on my 07? I have the tactrix for logging, etc... since the vag-com doens't work with 07+. Will it work with FreeSSM? Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted August 27, 2013 Mega Users Share Posted August 27, 2013 Should work fine. Just no flashing with ecuflash. Link to comment Share on other sites More sharing options...
gimpydingo Posted August 27, 2013 Share Posted August 27, 2013 Cool! Yeah no plans to attempt a flash with the vag Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted March 19, 2014 Author Share Posted March 19, 2014 I just worked with a customer via phone to get FreeSSM working on his Windows 8 laptop. Had him try the Tactrix OpenPort 2.0 cable for the heck of it. It worked! Using FreeSSM version 1.2.5. Pulled codes and allowed for both Clear Memory functions, no drama. Now I'm upset I sold my 2.0 cable. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
fishbone Posted March 19, 2014 Share Posted March 19, 2014 So sad the guy dropped development. Link to comment Share on other sites More sharing options...
Archi Posted April 30, 2014 Share Posted April 30, 2014 ClimberD, please explain how did you get 2.0 open port to work? Mine is not showing as any com port at all (kind of how it supposed to be) respectively ssm saying no com port device. Link to comment Share on other sites More sharing options...
firehawk618 Posted May 15, 2014 Share Posted May 15, 2014 I just worked with a customer via phone to get FreeSSM working on his Windows 8 laptop. Had him try the Tactrix OpenPort 2.0 cable for the heck of it. It worked! Using FreeSSM version 1.2.5. Pulled codes and allowed for both Clear Memory functions, no drama. Now I'm upset I sold my 2.0 cable. Are you able to increase line pressures with this software / cable combo? I ask because I feel my 1>2 shift under light to medium throttle is too long and slow. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted May 15, 2014 Mega Users Share Posted May 15, 2014 No. Link to comment Share on other sites More sharing options...
fishbone Posted May 15, 2014 Share Posted May 15, 2014 Are you able to increase line pressures with this software / cable combo? I ask because I feel my 1>2 shift under light to medium throttle is too long and slow. Welcome to 5EAT ownership Link to comment Share on other sites More sharing options...
