frank_ster Posted December 12, 2014 Share Posted December 12, 2014 Please start a thread about your cruise control issue in the 4th gen foum Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
snow05gtRI Posted December 12, 2014 Share Posted December 12, 2014 there's been a few threads on it, and no one has come to any conclusions. others have the same issue. i guess knowing your car does it when on the lift is a small piece added to the puzzle. sorry to derail the thread... Link to comment Share on other sites More sharing options...
Subie63 Posted December 12, 2014 Share Posted December 12, 2014 My problem is pretty much exactly what Snow's is. When I engage the cruise it works for varying amounts of time but is jerky. Then abruptly it stops working and "cruise" starts flashing on the dash. Even though it's kinda dangerous, I have popped it in neut. and shut the ignition off for a second and immediately restarted the car and the flashing "cruise" goes away. And I have purposely made it flash and then immediately park the car and hook up my code scanner to the vehicle just to find no trouble codes. I have read that if any of the wheel speed sensors were replaced with anything but OEM units, it will cause the cruise control to go haywire. I was wondering if this could be the problem and if there was a way of finding this out with the FreeSSM software. I just purchased the car almost exactly a year ago and I love it! But this little issue is driving me nuts. And I'm kinda cheap, so I am looking for anything to keep from taking it to the dealer. Link to comment Share on other sites More sharing options...
frank_ster Posted December 12, 2014 Share Posted December 12, 2014 Well if the abs sensor makes the abs happy inwouldnt understand why not the cruise. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Lassiv Posted January 18, 2015 Share Posted January 18, 2015 Any other software check values and reset tcu than FreeSSM? FreeSMS develoment is stopped i think I founded 1.25 version in google. Have any newer versions or newer software to 5eat checking and reset? (legacygt 2.0 -04). Can i do any linepressure changes or something like that with FreeSSM? I have vag-com cabel, can i use that all changes that 5eat. I read somewhere that DONT USE vag-com cabel to flash motor ecu (mcu). Any topic to 5eat line pressure changes or something like that? I just buy that car i think is best to start reset that tcu and look what happens after couple weeks. Link to comment Share on other sites More sharing options...
frank_ster Posted January 19, 2015 Share Posted January 19, 2015 no there is not much you can do to the 5 eat with software. the only modifications you can do is valve body modification, or install aftermarket control Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
fishbone Posted January 20, 2015 Share Posted January 20, 2015 Having said that, frank_ster, what parameters have been people playing with in FreeSSM and have seen success? I see a bunch of stuff in there but I don't know what works and if the changes stick until a battery disconnect, or they reset by themselves after a few drive cycles. Link to comment Share on other sites More sharing options...
frank_ster Posted January 21, 2015 Share Posted January 21, 2015 None work on the 5eat Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
fishbone Posted January 21, 2015 Share Posted January 21, 2015 Thanks for crushing my spirit, hope and dreams. Link to comment Share on other sites More sharing options...
hadvw Posted January 21, 2015 Share Posted January 21, 2015 Having said that, frank_ster, what parameters have been people playing with in FreeSSM and have seen success? I see a bunch of stuff in there but I don't know what works and if the changes stick until a battery disconnect, or they reset by themselves after a few drive cycles. I've used FreeSSM to adjust the idle speed a few times - that works. Tried altering the center diff line pressure, didn't work.. Link to comment Share on other sites More sharing options...
legacyshawn Posted April 13, 2015 Share Posted April 13, 2015 I have not been able to use 2.0 with free ssm and free ssm doesn't work with 08+ cars Well crap, anyway to reset the tcu on 08+? I just bought a cheapo kkl vag-com cable from ebay to reset my TCU, besides having weird drivers on a mini disc, it worked! And more over, it worked on my 2008 3.0R. But as stated before, the 08+ 5EAT's won't let you adjust anything but the center diff clutch. I monitored ATF temps and a bunch of ECU sensors. It was cool too see the O2 sensors sensing "rich" on idle and the cam positioning change under load. Anyways, I needed to reset my TCU and it did what I needed it to for $9. Link to comment Share on other sites More sharing options...
hadvw Posted April 13, 2015 Share Posted April 13, 2015 I just bought a cheapo kkl vag-com cable from ebay to reset my TCU, besides having weird drivers on a mini disc, it worked! And more over, it worked on my 2008 3.0R. But as stated before, the 08+ 5EAT's won't let you adjust anything but the center diff clutch. Be happy - I couldn't even adjust the center diff clutch with my '05 5EAT. Oh, the option was there, but when I tried to change it, nothing happened, or maybe even an error.. I forget exactly which. Link to comment Share on other sites More sharing options...
frank_ster Posted April 13, 2015 Share Posted April 13, 2015 ^ yea the free ssm does nothing but reset older tcu's Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
SnafuBE Posted April 24, 2015 Share Posted April 24, 2015 http://developer.berlios.de/projects/freessm/ Website seems to be down or defunct Link to comment Share on other sites More sharing options...
hadvw Posted April 24, 2015 Share Posted April 24, 2015 Well, it does let you adjust idle +-250 rpm until next ECU reset, which I've used a few times in a pinch. OTOH, I think ecuflash lets you adjust that in your tune.. Link to comment Share on other sites More sharing options...
frank_ster Posted April 25, 2015 Share Posted April 25, 2015 Yes. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted April 25, 2015 Mega Users Share Posted April 25, 2015 Website seems to be down or defunct Well that's sad. Not surprising though. It hasn't been supported, ever. Probably gave up on an old project. Link to comment Share on other sites More sharing options...
SnafuBE Posted April 27, 2015 Share Posted April 27, 2015 Well that's sad. Not surprising though. It hasn't been supported, ever. Probably gave up on an old project. lol...probably bought a civic (just kidding) I found another locale for the download and will give it a try once the cable arrives. I am mainly looking to read codes/sensors and log data...trouble code diagnostics would be nice too Link to comment Share on other sites More sharing options...
frank_ster Posted April 29, 2015 Share Posted April 29, 2015 Your car has built in code reader , To datalog you use rom raider Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
SnafuBE Posted April 30, 2015 Share Posted April 30, 2015 Thank you frank_ster. I am going to give it a go this weekend. Link to comment Share on other sites More sharing options...
amp583 Posted November 1, 2017 Share Posted November 1, 2017 2008 LGT 5EAT I replaced my VB, got FreeSSm to work and connect properly to my reset memory 2. I believe it was successful but i still have hard shifts between 2-3 primarily and down from 2 to 1. Occasionally 3-4 sticks as well. Did I not properly reset my TCU? Link to comment Share on other sites More sharing options...
snow05gtRI Posted November 1, 2017 Share Posted November 1, 2017 how many miles? I think it takes a good while to relearn. Link to comment Share on other sites More sharing options...
amp583 Posted November 1, 2017 Share Posted November 1, 2017 how many miles? I think it takes a good while to relearn. Probably not enough. Only 80 or so tops since the Vb was replaced and tcu reset. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
amp583 Posted January 25, 2018 Share Posted January 25, 2018 Can someone give me a guide to reset the TCU? I've searched but nothing is comprehensive enough from start to finish. I've also read things like memory loading the TCU during the dial swipe. Looking to clear "memory 2"... Are these my steps: 1. Key ignition to ON - not started 2. Read TCU with FreeSSm 3. Click 'Clear Memory 2' 4. Wait... 5. Turn key to off? 6. Turn key to on -- wait for the dial red swipe to finish 7. Start car 8. Drive at 10-12% throttle angle while manually shifting gears? Link to comment Share on other sites More sharing options...
