hadvw Posted February 15, 2012 Share Posted February 15, 2012 Oddly it was this Canadian who turned me on to American engines, nothing to do with Texas. I didn't mean that - I meant that they'll let you pass smog/emissions with a V8 in your car.. Trying that in CA would be way too expensive to even try to pass smog Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted February 15, 2012 Share Posted February 15, 2012 If, say, you had to fit a bigger throttle body on your swap, what would you do to get it to work? Thoughts much appreciated [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
frank_ster Posted February 16, 2012 Author Share Posted February 16, 2012 uh .. well i would just up the boost but if i had to .. i would probably just wire it to a gm type throttle body it might work. if not take the servo and attach it to the throttle body you want to have through some complicated system of levers strings and cogs Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted February 16, 2012 Share Posted February 16, 2012 Ooohhh I like the idea of getting a GM throttle body and/or pedal sensor to work cross platform. Will add that to the 'to do when feeling like a tired zombie' list. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
frank_ster Posted February 16, 2012 Author Share Posted February 16, 2012 You would be surprised to what is interchangeable between manufacturers I'm using a 14$ gm crank sensor for the subie computer Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
frank_ster Posted February 18, 2012 Author Share Posted February 18, 2012 so i'm thinking about going to a dyno next week, but i would only be doing it for your amusement. so send me money and i'll go and pm the donators the dyno sheets ! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
StoplightAssassin Posted February 21, 2012 Share Posted February 21, 2012 You have any logs? You can use virtual dyno for free. http://www.bradbarnhill.com/projects/VirtualDyno/ Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted February 21, 2012 Share Posted February 21, 2012 Where's the fun in using the street and wind to load the car in reality, when you can use artificial loading instead [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
frank_ster Posted February 21, 2012 Author Share Posted February 21, 2012 like i said i don't need dyno .. the numbers are for you guys only. i can easily tune on the street and pulling heavy trailers Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
frank_ster Posted April 7, 2012 Author Share Posted April 7, 2012 so went to the drags last night. with a best time of 13.7 @99 mph with 5 lbs boost. and pretty lame launch due to shitty traction at the track. i did raise the boost to 14 lbs but my tranny didn't like that 3rd gear shift was a bit slow.and 4th didnt grab at all. but i think the subau map sensor poped off so tranny wasn't getting full pressure. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Max Capacity Posted April 7, 2012 Share Posted April 7, 2012 I'm still amazed by this car and what you've done with it. Thanks for the update. Be sure and let us know how fast it is... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
frank_ster Posted April 8, 2012 Author Share Posted April 8, 2012 bihsoccer14 came up from VT i took him for a run the car actually spun the 4 wheels shifting into 2nd just to give you an idea of traction conditions. and my ice tires. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ehsnils Posted April 13, 2012 Share Posted April 13, 2012 Now I have found another engine project source for you: http://www.boxeer.com/ Link to comment Share on other sites More sharing options...
frank_ster Posted April 13, 2012 Author Share Posted April 13, 2012 ^ nice !!! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
CTATV Posted April 13, 2012 Share Posted April 13, 2012 so went to the drags last night. with a best time of 13.7 @99 mph with 5 lbs boost. and pretty lame launch due to shitty traction at the track. i did raise the boost to 14 lbs but my tranny didn't like that 3rd gear shift was a bit slow.and 4th didnt grab at all. but i think the subau map sensor poped off so tranny wasn't getting full pressure. I'm sure it's in the thread somewhere, but what kind of tranny are you running? Link to comment Share on other sites More sharing options...
Leviman Posted April 13, 2012 Share Posted April 13, 2012 Now I have found another engine project source for you: http://www.boxeer.com/ I wonder if you cranked the boost and fuel up on one of those things (like the diesel truck guys do) how much power you could make? it's already making about 250 ft lbs of torque from a 2.0l engine! Link to comment Share on other sites More sharing options...
frank_ster Posted April 14, 2012 Author Share Posted April 14, 2012 I'm sure it's in the thread somewhere, but what kind of tranny are you running? stock subaru 5 speed auto Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
frank_ster Posted April 14, 2012 Author Share Posted April 14, 2012 I wonder if you cranked the boost and fuel up on one of those things (like the diesel truck guys do) how much power you could make? it's already making about 250 ft lbs of torque from a 2.0l engine! 300 hp easy. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ehsnils Posted April 15, 2012 Share Posted April 15, 2012 I wonder if you cranked the boost and fuel up on one of those things (like the diesel truck guys do) how much power you could make? it's already making about 250 ft lbs of torque from a 2.0l engine! There's already a box available that claims to turn up the torque from 350Nm to 420Nm. And I suspect that you can get more than that from it, but at the cost of reliability and fuel consumption. Link to comment Share on other sites More sharing options...
frank_ster Posted May 10, 2012 Author Share Posted May 10, 2012 update just turned 180 000 kms and its been great on gas. i calibrated the maf to show very close to spot on instant and avg fuel economy . the center diff bushings are also holding up fine! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Lanaue Posted May 24, 2012 Share Posted May 24, 2012 subiescribe Link to comment Share on other sites More sharing options...
1454 Posted May 24, 2012 Share Posted May 24, 2012 update just turned 180 000 kms and its been great on gas. i calibrated the maf to show very close to spot on instant and avg fuel economy . the center diff bushings are also holding up fine! 25.2 MPG, that isn't bad at all. I'm currently averaging like 22-23 mixed driving. I was getting 27 hwy mainly last year. But I'm sure you have atleast double the power than I do. Me=envious. Link to comment Share on other sites More sharing options...
frank_ster Posted May 24, 2012 Author Share Posted May 24, 2012 it was bad as shit on gas for a while. i kept advancing the ignition timming and it kept getting worse and worse. i went up to 46 deg advance now i'm running 23-25 and wow what a difference. i wonder what the subie motors would do if you retarded the timming a shit load to 23-25 deg in cruse areas Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
fahr_side Posted May 24, 2012 Share Posted May 24, 2012 it was bad as shit on gas for a while. i kept advancing the ignition timming and it kept getting worse and worse. i went up to 46 deg advance now i'm running 23-25 and wow what a difference. i wonder what the subie motors would do if you retarded the timming a shit load to 23-25 deg in cruse areas I know someone who runs timing in cruise in the 35* range. It runs great, but the EGTs are high. I believe Subaru runs in the 40~* range in cruise to help emissions and keep EGTs down. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
frank_ster Posted May 24, 2012 Author Share Posted May 24, 2012 ok so set it to 30 and see what mpg's you get ! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
