fredrik94087 Posted November 6, 2013 Share Posted November 6, 2013 For reference, this is mine. 20x9.5+38 245/35/20 all around. Top is front and bottom is rear. Given that you're doing 265's, it's a hard fit. http://img.tapatalk.com/d/13/11/06/hu5e2aby.jpg Thanks for the reference. You see how it is out a bit in front and on 245's. I did a test fit with 255's 9.5 +40. A 245 would have fit better. 255 is the min I want to go. I had 245's and they weren't enough. But, that was on a 17x8 wheel and maybe I didn't have a wide enough wheel...dunno:iam: "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted November 7, 2013 Share Posted November 7, 2013 Has anyone seen the youtube video of the 2015 WRX concept? Do those wheels not look exactly like the SSR GT V03 pic I posted earlier? "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
TeriyakiBBS Posted November 7, 2013 Share Posted November 7, 2013 http://i131.photobucket.com/albums/p318/FLCLgibson1968/null_zpsb7028cff.png Link to comment Share on other sites More sharing options...
fredrik94087 Posted November 8, 2013 Share Posted November 8, 2013 http://i131.photobucket.com/albums/p318/FLCLgibson1968/null_zpsb7028cff.png I like the RE a lot. But, I don't think that is an RE. Which BBS wheel is it? "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
TeriyakiBBS Posted November 8, 2013 Share Posted November 8, 2013 Bbs ck Link to comment Share on other sites More sharing options...
Fenrir1 Posted November 8, 2013 Share Posted November 8, 2013 Not so!! I used the S203 for the basis of the look I was going for: http://i4.photobucket.com/albums/y124/PatagonianGT/STiBBSRE.jpg http://i4.photobucket.com/albums/y124/PatagonianGT/DSCN4011.jpg http://i4.photobucket.com/albums/y124/PatagonianGT/Wet.jpg what rims are these? i want! Link to comment Share on other sites More sharing options...
Hanger Posted November 8, 2013 Share Posted November 8, 2013 Rota formula mesh 18x8 +48 Sent from my Xperia Z ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Drift Motion Posted November 12, 2013 Share Posted November 12, 2013 http://i131.photobucket.com/albums/p318/FLCLgibson1968/null_zpsb7028cff.png z32 caliper? Link to comment Share on other sites More sharing options...
fredrik94087 Posted November 12, 2013 Share Posted November 12, 2013 Size: 17x9<LI style="DISPLAY: block" id=frontOffset95>Offset: 45mm <LI style="DISPLAY: block" id=frontBackSpacing95>Backspacing: 6.73"Bolt Pattern: 5-100Rec. Tire Size: 245/40-17 but I would go 255/45/17Weight: 15.65lbs.Finish: Special Brilliant Coating<LI style="DISPLAY: block" id=frontConstruction95>Construction: 1pc. Gravity Cast w/ MAT Technology <LI style="DISPLAY: block" id=frontFinishWar95>Finish Warranty: 1 YearManufactured in JapanIt comes up for BRZ fitment "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Drift Motion Posted November 13, 2013 Share Posted November 13, 2013 offset might be too high to clear struts... I know ppl running 9 +42 was close already Link to comment Share on other sites More sharing options...
Hanger Posted November 13, 2013 Share Posted November 13, 2013 I'd never get enkei anymore after bending mine on the freeway Sent from my Xperia Z ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
fredrik94087 Posted November 13, 2013 Share Posted November 13, 2013 (edited) offset might be too high to clear struts... I know ppl running 9 +42 was close already I was thinking worst case 5mm hubcentric spacers with nuts that thin down and go past the wheel holes. The other option is +35 and that is going to stick out too much. Hanger: Were you running 18's? What tires size and profile? I ran a 245/45/18 on a gtc01 no problem Edited November 13, 2013 by fredrik94087 "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
joeblow Posted November 13, 2013 Share Posted November 13, 2013 I'd never get enkei anymore after bending mine on the freeway Sent from my Xperia Z To be fair, that probably would have cracked a Rota or shattered an XXR. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
.Catalyst. Posted November 13, 2013 Share Posted November 13, 2013 I'd never get enkei anymore after bending mine on the freeway Sent from my Xperia Z I'd much prefer that to a break or crack. Good wheels bend and don't break. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
Hanger Posted November 13, 2013 Share Posted November 13, 2013 I was thinking worst case 5mm hubcentric spacers with nuts that thin down and go past the wheel holes. The other option is +35 and that is going to stick out too much. Hanger: Were you running 18's? What tires size and profile? I ran a 245/45/18 on a gtc01 no problem I had 18" on my 4th gen. Was running 235/40/18 on 18x9.5 ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
fredrik94087 Posted November 13, 2013 Share Posted November 13, 2013 ^^^ on a 17x9, I'd run a 255/50 or a 245/45. I'd have a bit more sidewall for cushion. Thanks for the pic and advice. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted November 13, 2013 Share Posted November 13, 2013 I ordered a set of the 17x9 +45. Should be here next week. Will feed-back. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Rattsl Posted November 13, 2013 Share Posted November 13, 2013 Is a 5mm spacer a bad idea? Front and back? Link to comment Share on other sites More sharing options...
fredrik94087 Posted November 13, 2013 Share Posted November 13, 2013 You'll get answers on both sides of the fence. But, if you do them, they should be hub-centric and from a reputable manufacturer. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
JonnyWachter Posted November 13, 2013 Share Posted November 13, 2013 I'm not saying it's a good idea, but I have had generic 5mm spacers on the rear with stock studs for a year now... Link to comment Share on other sites More sharing options...
Hanger Posted November 14, 2013 Share Posted November 14, 2013 There are no hubcentric 5mm spacers as far as i know of ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
SubieChik Posted November 14, 2013 Share Posted November 14, 2013 I'm not saying it's a good idea, but I have had generic 5mm spacers on the rear with stock studs for a year now... I had 5mm spacers for like a week....then when I realized how much thread my lug nut was actually holding onto, I removed them Link to comment Share on other sites More sharing options...
Rattsl Posted November 14, 2013 Share Posted November 14, 2013 I had 5mm spacers for like a week....then when I realized how much thread my lug nut was actually holding onto, I removed them That's what I wanted to know. I'm iffy about it...so, I wanted to see the consensus on it. Link to comment Share on other sites More sharing options...
TcDavis Posted November 14, 2013 Share Posted November 14, 2013 Just get longer wheel studs Link to comment Share on other sites More sharing options...
SubieChik Posted November 14, 2013 Share Posted November 14, 2013 Extended studs if I remember correctly cost about $150 for all 4 and they are a pain in the butt to put on....well the rears. I'd rather get bolt on spacers....or wheels the size that I want lol. Link to comment Share on other sites More sharing options...
