Guest Gitster Posted November 4, 2007 Share Posted November 4, 2007 Link to comment Share on other sites More sharing options...
derffred Posted November 4, 2007 Share Posted November 4, 2007 It totally depends on tire size though, 18X8 wheels will fit fine under stock ride height. No, I know they'll fit... but I'm worried about what will happen to my ground clearance and wheel gaps.. Will it make my car look like Outback? lol Link to comment Share on other sites More sharing options...
oxide Posted November 5, 2007 Share Posted November 5, 2007 No it won't. If you get the right size, your overall diameter will hardly change and the gap should be very little different from stock wheels. Link to comment Share on other sites More sharing options...
scottybuckeye Posted November 5, 2007 Share Posted November 5, 2007 No, I know they'll fit... but I'm worried about what will happen to my ground clearance and wheel gaps.. Will it make my car look like Outback? lol To compare tire sizes, check out http://www.miata.net/garage/tirecalc.html or search for tire calculator. If you go w/ a tire of a larger circumference, you'll get slightly higher ride height and less fender gap (springs are the best way to eliminate fender gap). I have iONS which lower the car about 1" and have summer tires of 235/40/18. This set up creates a good looking stance (and better cornering), but I do get a little tire rub. Good luck! Link to comment Share on other sites More sharing options...
CMyLGT Posted November 5, 2007 Share Posted November 5, 2007 A 235/35/18 tire is actually .1" smaller in overall diameter than the stock tires Link to comment Share on other sites More sharing options...
scottybuckeye Posted November 6, 2007 Share Posted November 6, 2007 A 235/35/18 tire is actually .1" smaller in overall diameter than the stock tires If you were talking to me, I don't have a 235/35/18 tire. Link to comment Share on other sites More sharing options...
CMyLGT Posted November 9, 2007 Share Posted November 9, 2007 No sorry I wasn't talking to you, I was responding to derffred's question about looking like an outback Link to comment Share on other sites More sharing options...
derffred Posted November 9, 2007 Share Posted November 9, 2007 Okay, so I decided to stick with 17x8.. Now I need to figure out the widest tire possible without rubbing (with stock suspension AND with a 1 inch drop for future mods) Link to comment Share on other sites More sharing options...
EL PAALO Posted November 9, 2007 Share Posted November 9, 2007 245/40 17, rolls in back. you'll have minor rubbing up front on the fender liner at full lock. bfg kdw2 is what I was using. Link to comment Share on other sites More sharing options...
derffred Posted November 9, 2007 Share Posted November 9, 2007 245/40 17, rolls in back. you'll have minor rubbing up front on the fender liner at full lock. bfg kdw2 is what I was using. I want absolutely no rub in any condition though Link to comment Share on other sites More sharing options...
Guest Gitster Posted November 9, 2007 Share Posted November 9, 2007 Roll the rears then, you got the resources ;) Link to comment Share on other sites More sharing options...
derffred Posted November 9, 2007 Share Posted November 9, 2007 :spin: I'm such a noob at this wheel/tire thing :spin: Link to comment Share on other sites More sharing options...
zildjiank Posted November 10, 2007 Share Posted November 10, 2007 245/40 17, rolls in back. you'll have minor rubbing up front on the fender liner at full lock. bfg kdw2 is what I was using. Mmm, that is a yummy combo, both size and tire. Go with it. Link to comment Share on other sites More sharing options...
EL PAALO Posted November 10, 2007 Share Posted November 10, 2007 I want absolutely no rub in any condition though then stick with 225/45 17 and you'll have no rubs (assuming you get a proper width/offset). Link to comment Share on other sites More sharing options...
derffred Posted November 10, 2007 Share Posted November 10, 2007 then stick with 225/45 17 and you'll have no rubs (assuming you get a proper width/offset). and that setup would be okay if/when I lower it about an inch? Link to comment Share on other sites More sharing options...
EL PAALO Posted November 10, 2007 Share Posted November 10, 2007 yes. I had sti bbs wheels with 225/45 17 azenis 615 with swift springs and zero rubbing even during autox. Many people have used similar setups with zero problems. Link to comment Share on other sites More sharing options...
scottybuckeye Posted November 21, 2007 Share Posted November 21, 2007 Here are my Rota Tarmac3's in hyperblack with Toyo T1R tires... http://i116.photobucket.com/albums/o19/oftoast/OSUvsWisconsin157small.jpg http://i116.photobucket.com/albums/o19/oftoast/OSUvsWisconsin152small.jpg http://i116.photobucket.com/albums/o19/oftoast/OSUvsWisconsin151small.jpg http://i116.photobucket.com/albums/o19/oftoast/OSUvsWisconsin149small.jpg http://i116.photobucket.com/albums/o19/oftoast/OSUvsWisconsin155small.jpg http://i116.photobucket.com/albums/o19/oftoast/OSUvsWisconsin145small.jpg Link to comment Share on other sites More sharing options...
Guest Gitster Posted November 21, 2007 Share Posted November 21, 2007 Looks great, not sure about the grille though dude. Link to comment Share on other sites More sharing options...
BigInALegacy Posted November 21, 2007 Share Posted November 21, 2007 Yeah, I didn't even notice it. What is it, chrome mesh? I agree, the grill looks a bit off... maybe stick the subie emblem (or an L7, or B4) and it might change the appearance a bit. Rims are sicko though... love hyperblack!! Link to comment Share on other sites More sharing options...
Guest Gitster Posted November 21, 2007 Share Posted November 21, 2007 Hopefully its not finished. He didnt fill in the part where he cut out the wing supports Link to comment Share on other sites More sharing options...
BigInALegacy Posted November 21, 2007 Share Posted November 21, 2007 Oh, that's what that hole is... I noticed that, I just thought it was how the grill was supposed to be. I don't think my '08 has that... not entirely sure though. Link to comment Share on other sites More sharing options...
scottybuckeye Posted November 26, 2007 Share Posted November 26, 2007 Looks great, not sure about the grille though dude. Sorry man, I like it (a lot). Stock grille w/ wings simply looks weak like a fam sedan. Good eye on the cut out on the frame. I spent a lot of time doing the cut-sand-Bondo-sand-paint process and the Bondo quickly cracked and broke off. Maybe I'll fix it in the future, but it's not big enough for me to care anymore. BigIn, the grille is from grilleguy.com and is the aluminum finish. Everyone has black, so... Props on Daft! I'm looking forward to that live sampling album. Saw them at Red Rocks a few months ago. Most sick visual show I've ever been to (been to a lot). Link to comment Share on other sites More sharing options...
legwbrembos Posted November 27, 2007 Share Posted November 27, 2007 http://i214.photobucket.com/albums/cc58/cxcrum/legacyrightrearwheels.jpghttp://i214.photobucket.com/albums/cc58/cxcrum/legacyrightfrontwheel.jpg Link to comment Share on other sites More sharing options...
legwbrembos Posted November 27, 2007 Share Posted November 27, 2007 http://i214.photobucket.com/albums/cc58/cxcrum/legacybrembobrake.jpg Link to comment Share on other sites More sharing options...
whobaru Posted November 28, 2007 Share Posted November 28, 2007 There you are! ^^^ Looks like teh niceness! Can I have ur brakes?! Think snow!! http://i180.photobucket.com/albums/x312/kagenmateer/photobucketsnowsuby.png Link to comment Share on other sites More sharing options...
