Setnev Posted March 3, 2017 Share Posted March 3, 2017 what does fully built entail? my sti makes 650 I consider that fully built....but i have as much done as possible. Just curious on what your plans are i guess i am building a ej25d at work i want to do oem turbo/boost build no swaps but the ecu/engine management seems to be my hurdle. Block was in good shape with no issues so I just tore it down to inspect and clean everything. I did a leak down test on the heads and had tore them down to inspect and clean them. I figured with the low mileage on the block and heads that everything should be good to go as is. I didn't need to go out and invest hundreds of dollars on new pistons, rings, bearings, etc because they all looked good and had good tolerances in all the journals. It's not built for performance, just rebuilt using mostly original equipment. I wanted to go through the engine for piece of mind because, prior to not knowing the true mileage on the motor, I was just assuming what others told me was correct. The Ej25D will take boost, just not a lot due to being open deck and lack of tuning on the ECU. If you stay below 6-8 psi, engine management shouldn't be an issue, just throw on some bigger injectors and get yourself a standalone wideband and meter to monitor AFR at the exhaust so you don't have detonation in the cylinders. Link to comment Share on other sites More sharing options...
PNW_AWD Posted March 6, 2017 Share Posted March 6, 2017 Block was in good shape with no issues so I just tore it down to inspect and clean everything. I did a leak down test on the heads and had tore them down to inspect and clean them. I figured with the low mileage on the block and heads that everything should be good to go as is. I didn't need to go out and invest hundreds of dollars on new pistons, rings, bearings, etc because they all looked good and had good tolerances in all the journals. It's not built for performance, just rebuilt using mostly original equipment. I wanted to go through the engine for piece of mind because, prior to not knowing the true mileage on the motor, I was just assuming what others told me was correct. The Ej25D will take boost, just not a lot due to being open deck and lack of tuning on the ECU. If you stay below 6-8 psi, engine management shouldn't be an issue, just throw on some bigger injectors and get yourself a standalone wideband and meter to monitor AFR at the exhaust so you don't have detonation in the cylinders. Ya not a fan of "should be's" guuess i have to pin in a AEM Link to comment Share on other sites More sharing options...
twisty Posted March 8, 2017 Share Posted March 8, 2017 my 96 outback parts car is about to roll over the 303k mark. smokes a bit on start up, gone in about 30 sec usually. rattles a ton, but still makes it up hills and through mud and sand. Link to comment Share on other sites More sharing options...
friedkin Posted March 12, 2017 Share Posted March 12, 2017 my 96 legacy sedan has 270k kilometers it is almost 160k miles... Link to comment Share on other sites More sharing options...
twisty Posted April 12, 2017 Share Posted April 12, 2017 http://i66.tinypic.com/1040040.jpg Link to comment Share on other sites More sharing options...
doublechaz Posted April 13, 2017 Share Posted April 13, 2017 Too bad you missed the 202 on the trip. 303s were a big thing when these cars were new. Link to comment Share on other sites More sharing options...
choover1101 Posted April 13, 2017 Share Posted April 13, 2017 I palindromed today as well, sadly I missed the pic by 2 miles as well. 232234 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
twisty Posted April 13, 2017 Share Posted April 13, 2017 Too bad you missed the 202 on the trip. 303s were a big thing when these cars were new. ya, the last reset put the 100's digit half off, and i couldnt get pulled over soon enough to get the two to stay. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted April 13, 2017 Share Posted April 13, 2017 Approaching 154k miles. Link to comment Share on other sites More sharing options...
Loafers Posted April 17, 2017 Share Posted April 17, 2017 370,000km on her second motor. Link to comment Share on other sites More sharing options...
Setnev Posted April 18, 2017 Share Posted April 18, 2017 Just made it to 147k on the body and 250 on the rebuilt motor of Land Shark (blue outback) Link to comment Share on other sites More sharing options...
Sublimejoe Posted May 1, 2017 Share Posted May 1, 2017 Just picked up a pretty clean second gen with 318k on original motor Link to comment Share on other sites More sharing options...
wish Posted May 1, 2017 Share Posted May 1, 2017 201,5xx Link to comment Share on other sites More sharing options...
SBT Posted May 2, 2017 Share Posted May 2, 2017 103K and change on the 98 BD GT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Setnev Posted May 8, 2017 Share Posted May 8, 2017 Motor just had it's millennial point reached. Almost to 1100 miles on the new motor. Moving accelerated that milestone. Just over 750 miles in 2 weeks. Link to comment Share on other sites More sharing options...
doublechaz Posted May 8, 2017 Share Posted May 8, 2017 +100. Drove over the pass to Clarkdale for fun and to look at my gauges that are now sorta mounted to the dash. Waiting on mouser... Link to comment Share on other sites More sharing options...
stevenva Posted May 17, 2017 Share Posted May 17, 2017 1996 Legacy L 368030 Miles. R.I.P. 4eat failure. I figure I got my moneys worth. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
doublechaz Posted May 17, 2017 Share Posted May 17, 2017 Looks like mouser finally delivered parts I can use. I guess I can't put off all the soldering any longer. Link to comment Share on other sites More sharing options...
Enc7 Posted May 18, 2017 Share Posted May 18, 2017 Just bought a 98 Legacy L sedan with 109,891 miles on it. Link to comment Share on other sites More sharing options...
Setnev Posted May 24, 2017 Share Posted May 24, 2017 2100 miles on new motor, 149k on the chassis Link to comment Share on other sites More sharing options...
doublechaz Posted May 25, 2017 Share Posted May 25, 2017 275k Link to comment Share on other sites More sharing options...
Subiegirl99 Posted May 28, 2017 Share Posted May 28, 2017 146,563 on the dash, but it's a 99 Legacy with the quirky speedometer/odometer that only works sometimes. Probably really has over 200,000. Still purrs like a newborn kitten Link to comment Share on other sites More sharing options...
doublechaz Posted May 29, 2017 Share Posted May 29, 2017 That's about how many miles mine had when I bought it about 12 years ago. Mine is still my solid daily at 275k although I did break a 5MT and swap for another. (My fault) Link to comment Share on other sites More sharing options...
travisvanw Posted October 16, 2017 Share Posted October 16, 2017 98 legacy gt. 225,000 miles. Pretty sure I just blew a head gasket. Link to comment Share on other sites More sharing options...
doublechaz Posted October 16, 2017 Share Posted October 16, 2017 95 Legacy L wagon. 283k. Link to comment Share on other sites More sharing options...
