Penguin Posted September 2, 2009 Share Posted September 2, 2009 So like the tittle says I determined the top speed of my Tundra today. The governor kills the fun at about 108mph from the look of things. I also found out (at the same time) that elementary school kids can run a lot faster than you would think given the proper motivation to cross the street more quickly. Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted September 3, 2009 Share Posted September 3, 2009 Not bad for a rectangle with wheels Link to comment Share on other sites More sharing options...
Penguin Posted September 3, 2009 Author Share Posted September 3, 2009 Not bad for a rectangle with wheels The sad part is that the engine has so much more. It's not even working hard at that speed. Link to comment Share on other sites More sharing options...
Penguin Posted September 3, 2009 Author Share Posted September 3, 2009 I also determined that kindergarten teachers are not amused by big smokey burnouts near crosswalks. Humorless bitches. Link to comment Share on other sites More sharing options...
mikeislord Posted September 3, 2009 Share Posted September 3, 2009 I also found out (at the same time) that elementary school kids can run a lot faster than you would think given the proper motivation to cross the street more quickly. Too bad. You could have given us a review of your brush guard too. Link to comment Share on other sites More sharing options...
-TT- Posted September 3, 2009 Share Posted September 3, 2009 what's the difference between a truck bed full of dead babies and a truck bed full of bowling balls? one is easier to empty with a pitchfork. Link to comment Share on other sites More sharing options...
Regal05LGT Posted September 3, 2009 Share Posted September 3, 2009 Too bad. You could have given us a review of your brush guard too. That's great stuff Link to comment Share on other sites More sharing options...
Penguin Posted September 3, 2009 Author Share Posted September 3, 2009 Too bad. You could have given us a review of your brush guard too. I don't have one installed yet! Besides brush guards are useless........ what one really needs is a 190lb replacement bumper/front end made from 3/16's steel plate with tube reinforcement with an integrated bull bar. In fact I have an ARB catalog on order for just such a part. With that a person should be able to mow down deer, antelope, and errant seven year old's without so much as even a mild dent! Link to comment Share on other sites More sharing options...
rao Posted September 3, 2009 Share Posted September 3, 2009 I am certain that the speed limiter can be changed to a more appropriate number without too much effort. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Penguin Posted September 3, 2009 Author Share Posted September 3, 2009 I am certain that the speed limiter can be changed to a more appropriate number without too much effort. Probably, but the tires wouldn't be safe at higher speeds, at least not the A/T tires I prefer to run on a truck. I really really want to swap in the AWD Torsen transfer case from a Land Cruiser 200 into the Tundra. I read a write up on it, and not only does it work but the bolt pattern to the frame is the same, the units are externally the same size, and the control unit is pretty easy to convert over. The only real wrenching involves changing the output flanges for the axles as the Tundra uses a 3/4 ton size flange for the drive shafts. Then of course I would supercharge it, and put on a long travel suspension with bypass shocks. Because I "need" a 504hp AWD rally truck to tool around in. You don't have about $8K you could give me do you? Link to comment Share on other sites More sharing options...
rao Posted September 3, 2009 Share Posted September 3, 2009 Depends on the interest rate and collateral Sounds like fun. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
StoplightAssassin Posted September 3, 2009 Share Posted September 3, 2009 I'm guessing the latest gen Tundra with a 5.6? My buddy has one...it gots teh powaaaa! Link to comment Share on other sites More sharing options...
PGT Posted September 3, 2009 Share Posted September 3, 2009 I drove a new Sequoia on the autobahn between Stuttgart and France (strasbourg) back in May. I concur with the 'has a lot more to go' sentiment when the governor kicks in at 108mph. Still, 3 tons of metal moving at triple digits was enough to get most people to move right. Link to comment Share on other sites More sharing options...
Penguin Posted September 3, 2009 Author Share Posted September 3, 2009 I'm guessing the latest gen Tundra with a 5.6? My buddy has one...it gots teh powaaaa! Ahem.... it's a 5.7L.... Link to comment Share on other sites More sharing options...
Penguin Posted September 3, 2009 Author Share Posted September 3, 2009 I drove a new Sequoia on the autobahn between Stuttgart and France (strasbourg) back in May. I concur with the 'has a lot more to go' sentiment when the governor kicks in at 108mph. Still, 3 tons of metal moving at triple digits was enough to get most people to move right. I didn't even know the Sequoia was offered in the European market. Was it owned by a US military service member and just imported while they are stationed in Germany? Link to comment Share on other sites More sharing options...
Guest Posted September 3, 2009 Share Posted September 3, 2009 I drove a new Sequoia on the autobahn between Stuttgart and France (strasbourg) back in May. I concur with the 'has a lot more to go' sentiment when the governor kicks in at 108mph. Still, 3 tons of metal moving at triple digits was enough to get most people to move right. Generally people in Europe move to the right regardless of the size of the approaching vehicle... Link to comment Share on other sites More sharing options...
pillboy Posted September 3, 2009 Share Posted September 3, 2009 Generally people in Europe move to the right regardless of the size of the approaching vehicle... Generally...I take those that don't are tourists? Most likely ugly Americans? It is still ugly. Link to comment Share on other sites More sharing options...
dtmenace Posted September 3, 2009 Share Posted September 3, 2009 the same way only ugly americans would be cruising @ triple digits on the autobahn in a f*ckin' sequoia! i can only assume that pgt was also consuming a hamburger & talking on his cell phone while doing it ... U-S-A! - U-S-A! & the arb bar is sweet but be careful how you option it, the integrated winch box & fog light stations will collect lots of "messy bits" when plowing through your local cross walk Link to comment Share on other sites More sharing options...
Penguin Posted September 3, 2009 Author Share Posted September 3, 2009 Ah but the ARB is designed to deflect objects down and away from the front of the vehicle or underneath if it is a centered up hit. Those Australians don't screw around when it comes to running over kangaroos, dingos, emus, and Aboriginals! There is much research and engineering put into this! Link to comment Share on other sites More sharing options...
John M Posted September 3, 2009 Share Posted September 3, 2009 Yeah, Toyota trucks and the 4Runner have stopped at 108 for at least 15 years now. It wasn't an issue on my brother's old 96 until he added the supercharger. The Tundra has to have a killer top end. Guys are getting stock Dodges to 140 (GPS) after using a programmer to ditch the limiter. Link to comment Share on other sites More sharing options...
Penguin Posted September 3, 2009 Author Share Posted September 3, 2009 Yeah, Toyota trucks and the 4Runner have stopped at 108 for at least 15 years now. It wasn't an issue on my brother's old 96 until he added the supercharger. The Tundra has to have a killer top end. Guys are getting stock Dodges to 140 (GPS) after using a programmer to ditch the limiter. Honestly running any faster than 108 or so on light truck tires is pretty inadvisable anyway. Link to comment Share on other sites More sharing options...
LegGTLT Posted September 3, 2009 Share Posted September 3, 2009 My dad's Silverado can do 109 mph. WHAT NOW?!!?!?!? Please PM joeleodee For All Site Questions. He is the acting Admin and can resolve anything related to LegacyGT.com Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted September 3, 2009 Share Posted September 3, 2009 Link to comment Share on other sites More sharing options...
dtmenace Posted September 3, 2009 Share Posted September 3, 2009 My dad's Silverado can do 109 mph. WHAT NOW?!!?!?!? yeah, while cruising the mall for HS chicks, right? Link to comment Share on other sites More sharing options...
SLegacy99 Posted September 3, 2009 Share Posted September 3, 2009 Good to know that I can beat you in a race of speed. Link to comment Share on other sites More sharing options...
