whiteknight24 Posted August 15, 2014 Share Posted August 15, 2014 Thanks for the tutorial. I didn't really follow it because I saw it after I replaced my spark plugs. I bought NGK BRK5EIX-11 Iridium plugs. I installed them in an hour with a buddy. Car started right up with check engine light on. However, my intake wasn't completely connected so could I have screwed up my MAF sensor? We cleared the check engine and turned the car off. Starting it back on was trouble but it turned on. No check engine light. We took the plugs out again and cleaned them. I do have oil in the boots. I will be replacing the tube seals and valve covers soon. But now when I'm in drive the rpm's drop to around 400, it almost stalls out. When in park it idles at 800-900rpm's. What do I do?? Link to comment Share on other sites More sharing options...
apexi Posted August 15, 2014 Share Posted August 15, 2014 Sounds like you might have had the same problem I had recently that I mention here http://legacygt.com/forums/showpost.php?p=4901539&postcount=15. Did you disconnect the battery at all? What was the check engine light code? I would try resetting the ecu. Our cars drive funny after you reset the ecu so the problem won't be fixed instantly, but it's a start. And when you say the intake wasn't completely connected, was the maf sensor plugged in? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 18, 2014 Author Share Posted August 18, 2014 Thanks for the tutorial. I didn't really follow it because I saw it after I replaced my spark plugs. I bought NGK BRK5EIX-11 Iridium plugs. I installed them in an hour with a buddy. Car started right up with check engine light on. However, my intake wasn't completely connected so could I have screwed up my MAF sensor? We cleared the check engine and turned the car off. Starting it back on was trouble but it turned on. No check engine light. We took the plugs out again and cleaned them. I do have oil in the boots. I will be replacing the tube seals and valve covers soon. But now when I'm in drive the rpm's drop to around 400, it almost stalls out. When in park it idles at 800-900rpm's. What do I do?? The low RPMS are due to the ECU reset so no problem there it will improve over the next few miles as it learns. Link to comment Share on other sites More sharing options...
whiteknight24 Posted August 22, 2014 Share Posted August 22, 2014 thanks, ya its starting to correct itself on its own. Link to comment Share on other sites More sharing options...
The 2Fiver Posted December 16, 2014 Share Posted December 16, 2014 Great tutorial, job took me an hour and saved hundred$ 'o' dollars. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted December 16, 2014 Author Share Posted December 16, 2014 Great tutorial, job took me an hour and saved hundred$ 'o' dollars. Nice wheels! Link to comment Share on other sites More sharing options...
Trebacz Posted June 11, 2016 Share Posted June 11, 2016 Great article. I used a 3" extension with an swivel. It was the perfect depth for all plugs. Only had to remove the air cleaner stuff on the passenger side. I never touched anything on the battery side to eliminate the computer reset. Link to comment Share on other sites More sharing options...
