specialB Posted July 28, 2009 Share Posted July 28, 2009 I wanna get a front and rear set for my LGT. Anything other than cobb I can go with thats quality?? Link to comment Share on other sites More sharing options...
johnboi85 Posted July 28, 2009 Share Posted July 28, 2009 i'm ordering my whitelines today from jsc. Link to comment Share on other sites More sharing options...
CapnJack Posted July 28, 2009 Share Posted July 28, 2009 AVO and Perrins are also good. There is alot of controversy about what size on front and rear (22mm vs 25mm) to run however. I'm still on the fence what sizes I want to run when I purchase mine. You may want to look into new end links too. The stock ones tend to be the weak point when you upgrade the bars. Also if you are doing a rear sway bar, you may want to look into the reinforcement bracket as the subframe becomes a weak point as well. This all depends on what sized bar you get and how hard you drive your car. Link to comment Share on other sites More sharing options...
peteyjr Posted July 28, 2009 Share Posted July 28, 2009 You can get away with just the rear (AVO only makes a rear bar). Reinforcement bracket a must . AVO and progress bars come with them. Overall for the $ Whitelines and Progress bars are the best bang for the buck. Link to comment Share on other sites More sharing options...
Bolksey85 Posted July 29, 2009 Share Posted July 29, 2009 If you get Perrin's from Fred Beans, they come with the bracket for the rear mounts. I'll be (hopefully) ordering 22mm's F+R from them this week. Link to comment Share on other sites More sharing options...
Th3Franz Posted July 29, 2009 Share Posted July 29, 2009 Whitelines are good. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
thebootyhouse Posted July 29, 2009 Share Posted July 29, 2009 If you absolutely can't find a used set of Cobb bars, I think the ZeroSports bars are of comparable quality and tubular construction. Link to comment Share on other sites More sharing options...
scoobydoobie Posted July 29, 2009 Share Posted July 29, 2009 Rallitek to add to your confusion Link to comment Share on other sites More sharing options...
CDN 2.5i Posted July 29, 2009 Share Posted July 29, 2009 If you get Perrin's from Fred Beans, they come with the bracket for the rear mounts. I'll be (hopefully) ordering 22mm's F+R from them this week. Got my Perrin bar from Fred Beans - they should be able to hook you up with a sale price Link to comment Share on other sites More sharing options...
fonts Posted July 29, 2009 Share Posted July 29, 2009 Very happy with my Cobb bars. Link to comment Share on other sites More sharing options...
captainhook Posted July 29, 2009 Share Posted July 29, 2009 22mm Perrin bars/endlinks F+R. They work perfectly, can't complain about anything except being dumb enough not to get a 25mm bar in the front. +1 on deal from Fred Bean. Link to comment Share on other sites More sharing options...
Bolksey85 Posted July 30, 2009 Share Posted July 30, 2009 Got my Perrin bar from Fred Beans - they should be able to hook you up with a sale price What did you pay for yours out of curiosity? Link to comment Share on other sites More sharing options...
vinnig Posted July 30, 2009 Share Posted July 30, 2009 Go for Perrins with endlinks from Fred Beans. Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted July 30, 2009 Share Posted July 30, 2009 Whiteline adjustables, they work beautifully on the street and AutoXing. Cobb no longer makes sways for our car. Link to comment Share on other sites More sharing options...
CDN 2.5i Posted July 30, 2009 Share Posted July 30, 2009 Bolksey85: pm sent Link to comment Share on other sites More sharing options...
Throttlejockey Posted July 31, 2009 Share Posted July 31, 2009 Just installed my rear Perrin 22mm sway. I think I should do the front also. 22mm or 25? Don't want a harsh ride. Link to comment Share on other sites More sharing options...
Bolksey85 Posted July 31, 2009 Share Posted July 31, 2009 If you want it to stay neutral, go with a 22F. If you want a little more understeer, get the 25mm. Link to comment Share on other sites More sharing options...
peteyjr Posted July 31, 2009 Share Posted July 31, 2009 if you want it to stay neutral, go with a 22f. If you want a little more understeer, get the 25mm. + 1 Link to comment Share on other sites More sharing options...
Throttlejockey Posted July 31, 2009 Share Posted July 31, 2009 Thanks guys, 22 it is. Link to comment Share on other sites More sharing options...
specialB Posted July 31, 2009 Author Share Posted July 31, 2009 I think I'm convinced to go with the Perrin setup from fredbeans, I like ordering from them. So I don't get why the larger 25mm front bar gives more understeer?? Shouldn't it make the ride stiffer and in turn track better around corners with a more stable feel? I feel like the 22's would let the front end dive more around corners.. Link to comment Share on other sites More sharing options...
Throttlejockey Posted August 1, 2009 Share Posted August 1, 2009 Mine is pretty good with just the 22 rear, so I imagine it's going to be real good with the front 22. They have 2 settings and mine is at the softest. Link to comment Share on other sites More sharing options...
Bolksey85 Posted August 1, 2009 Share Posted August 1, 2009 I think I'm convinced to go with the Perrin setup from fredbeans, I like ordering from them. So I don't get why the larger 25mm front bar gives more understeer?? Shouldn't it make the ride stiffer and in turn track better around corners with a more stable feel? I feel like the 22's would let the front end dive more around corners.. It's the opposite. A larger rear bar causes the rear end to want to "step out" if you will under a hard, aggressive turn. The ride really dosen't change because ride quality isn't affected like it is with springs or struts. What's affected is how the chassis reacts when put into a turn. Link to comment Share on other sites More sharing options...
Bolksey85 Posted August 1, 2009 Share Posted August 1, 2009 Damn bills. I couldn't order my bars today like I wanted. Oh, well. I'll be getting a commission check next week along with a regular pay check () so that will cover it nicely. Plus after that, I work a Saturday so that means a little more in the next so I can get them on as well! Link to comment Share on other sites More sharing options...
specialB Posted August 1, 2009 Author Share Posted August 1, 2009 ok sooo i just put together my shopping cart on fredbeans for the front and rear perrin 22mm bars and front and rear endlinks. im looking at about 5 and a half for the price tag, is that decent or did someone get a better deal?? please respond quick i wanna buybuybuy! haha Link to comment Share on other sites More sharing options...
Bolksey85 Posted August 1, 2009 Share Posted August 1, 2009 Beans pricing is about as good as it gets. Perrin is running a 13% off sale on their website and FB is within $5 of that. Just with you being in NY, you might get it quicker depending on where Perrin is located. Plus FB has awesome customer service. Click on the shopping cart and check out, son! Link to comment Share on other sites More sharing options...
