dubCleg37 Posted June 9, 2013 Share Posted June 9, 2013 finally got my wheels on the legacy. running s tech springs on stock struts. xxr 527 18x8.75 +35 wrapped in extenza hp 235/40's. Rolled all four renders, light pull in rear. http://i1275.photobucket.com/albums/y446/Wade_Kelly/P6088695_zpsbfd65755.jpg' alt='P6088695_zpsbfd65755.jpg'> http://i1275.photobucket.com/albums/y446/Wade_Kelly/P6088690_zps6c9bc3a9.jpg http://i1275.photobucket.com/albums/y446/Wade_Kelly/P6088683_zps7dd34d6f.jpg Link to comment Share on other sites More sharing options...
guzzimutt Posted June 11, 2013 Share Posted June 11, 2013 nice what else is going on there- I see the FMIC... Link to comment Share on other sites More sharing options...
dubCleg37 Posted June 11, 2013 Share Posted June 11, 2013 nice what else is going on there- I see the FMIC... aem intake, invidia catless up and down pipe. Custom single tip cat back. Cobb ap, protuned at precision tuning. nothing crazy. not passing stage 2 for now. im happy with it. Cant preach enough about how much better single tips sound... Link to comment Share on other sites More sharing options...
.Catalyst. Posted June 12, 2013 Share Posted June 12, 2013 Cant preach enough about how much better single tips sound...Which still doesn't make up for how horrible it looks with an empty cutout since the car designed for dual exits. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
dubCleg37 Posted June 12, 2013 Share Posted June 12, 2013 Which still doesn't make up for how horrible it looks with an empty cutout since the car designed for dual exits. to each there own. But i personally can deal with the empty cut out. hell, i don't see it when I'm driving, but i do hear the enhanced sound... Link to comment Share on other sites More sharing options...
boxkita Posted June 14, 2013 Share Posted June 14, 2013 found this post on another thread, has a list of most spring options and how much they drop a LGT. http://legacygt.com/forums/showpost.php?p=4099297&postcount=25 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
jav2.5 Posted June 18, 2013 Share Posted June 18, 2013 found this post on another thread, has a list of most spring options and how much they drop a LGT. http://legacygt.com/forums/showpost.php?p=4099297&postcount=25 Does anyone know what the Cobb spring rate is? Another question, I have a set of Cobbs sitting here, do I need spacers for the rear, or am I gonna have a saggy a$$? Link to comment Share on other sites More sharing options...
boxkita Posted June 19, 2013 Share Posted June 19, 2013 Does anyone know what the Cobb spring rate is? Another question, I have a set of Cobbs sitting here, do I need spacers for the rear, or am I gonna have a saggy a$$? thot saggy butts were only wagons? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
jav2.5 Posted June 19, 2013 Share Posted June 19, 2013 I thought they were on all Legacys? Link to comment Share on other sites More sharing options...
Firepuma Posted June 19, 2013 Share Posted June 19, 2013 Does anyone know what the Cobb spring rate is? Another question, I have a set of Cobbs sitting here, do I need spacers for the rear, or am I gonna have a saggy a$$? I had had cobbs and there was definitely no need for spacers in the rear. And that was on a wagon. Link to comment Share on other sites More sharing options...
RawrParts Posted June 24, 2013 Share Posted June 24, 2013 I have a OBXT with LGT strut with Tein S tech I notice that the rear is bit soft, bumpy then the front whenever I when over a bump. Im sure the strut are in good condition so should I install a bigger sway bar in the rear? Any suggestion? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted June 24, 2013 Share Posted June 24, 2013 you need a higher spring rate as that is what is taking the brunt of it all on a speed bump. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
bduncs4 Posted June 24, 2013 Share Posted June 24, 2013 Any update from guys/gals that have been running the H&R sports on the stock OEM Legacy GT struts? If so, how many miles are on the struts, and how many miles have you had the H&R's installed? Pics would be great if you have them! Link to comment Share on other sites More sharing options...
chimera Posted June 25, 2013 Share Posted June 25, 2013 (edited) I wouldn't mind chiming in here and asking similar to above, although looking at eibach pro kit with stock struts on a 4th gen LGT wagon, only want subtle drop, say around 1", to give a bit better handling and stance but comfortable enough as a DD and ok to tow with without dumping the arse. Would eibach suit? Anything else better/more cost effective? Also, what part number for eibach pro kit for '07 LGT, I can only find info for the 2010 model and up. Thanks Edited June 25, 2013 by chimera Link to comment Share on other sites More sharing options...
bduncs4 Posted June 25, 2013 Share Posted June 25, 2013 Also, what part number for eibach pro kit for '07 LGT, I can only find info for the 2010 model and up. Thanks I believe you would need to find a used set of eibach's? OR go with the very similar Epic Engineering springs. Link to comment Share on other sites More sharing options...
bduncs4 Posted June 27, 2013 Share Posted June 27, 2013 Any update from guys/gals that have been running the H&R sports on the stock OEM Legacy GT struts? If so, how many miles are on the struts, and how many miles have you had the H&R's installed? Pics would be great if you have them! Link to comment Share on other sites More sharing options...
Ben_08 Posted June 29, 2013 Share Posted June 29, 2013 New to the forum and tuning and need some advice. Just got my 08 LGT a year ago and wasn't planning on modding it until next summer. Found out 3 days ago I need new front struts since one is leaking and figured, what the hell, good time to start toying. Through my research I'm leaning toward Tein Street Basis coilovers. I've read a lot of forums and not too many mention the full coilovers just the springs (H-/S-tech). Any advice or opinions on these coilovers? Also looking at tires so any advice on upgraded daily driver tires would be welcome as well. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted June 29, 2013 Share Posted June 29, 2013 Search for the "cheap coilover thread" They talk about them and others in that price range in that thread. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
idiot4hire Posted June 30, 2013 Share Posted June 30, 2013 Is that the pros and cons thread Link to comment Share on other sites More sharing options...
MiniStiGuy Posted June 30, 2013 Share Posted June 30, 2013 Yeah that's the one. Here is a direct link to it. http://legacygt.com/forums/showthread.php/cheap-coilover-thread-pros-cons-203772.html OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
dubCleg37 Posted June 30, 2013 Share Posted June 30, 2013 New to the forum and tuning and need some advice. Just got my 08 LGT a year ago and wasn't planning on modding it until next summer. Found out 3 days ago I need new front struts since one is leaking and figured, what the hell, good time to start toying. Through my research I'm leaning toward Tein Street Basis coilovers. I've read a lot of forums and not too many mention the full coilovers just the springs (H-/S-tech). Any advice or opinions on these coilovers? Also looking at tires so any advice on upgraded daily driver tires would be welcome as well. I would steer you away from the basis and towards the Megan's or if you are willing to spend a little more, the bc's. just better ride quality and dampening adjustability. Plus, with the teins, you use your old top hats. As far as tires go, I've ran extenza hp's on my last three cars and loved them. I know a lot of people are against toyos, but I have loved them (for the price) Link to comment Share on other sites More sharing options...
Ben_08 Posted June 30, 2013 Share Posted June 30, 2013 Read the thread Mini suggested and am now back in limbo. I am trying to go the cheap route but want a smooth ride with added performance. Just don't know if I want to spend the extra cash for now or wait another year as I originally planned and just get stock struts. As far as tires go, I might just grab some all weather tires and splurge on wheels and tires next year. Link to comment Share on other sites More sharing options...
idiot4hire Posted July 3, 2013 Share Posted July 3, 2013 Read the thread Mini suggested and am now back in limbo. I am trying to go the cheap route but want a smooth ride with added performance. Just don't know if I want to spend the extra cash for now or wait another year as I originally planned and just get stock struts. As far as tires go, I might just grab some all weather tires and splurge on wheels and tires next year. I have bilsteins HDs and stock springs its a good dd setup combined with a RSB. Konis on stock springs would make a great set up for DD Link to comment Share on other sites More sharing options...
sorbus Posted July 11, 2013 Share Posted July 11, 2013 I'm running Tein H.Tech with stock shocks. Runs perfectly - less body roll, better feeling when braking. Excellent DD. Works excellent with Cusco strut bars (top+bottom upper and lower bars are installed). If you're not going offroad you may increase cornering performance with thicker sway bars (start with JDM, then COBB, Perrin and so on): + 2-3 mm will make huge difference on setup listed above. Link to comment Share on other sites More sharing options...
Ben_08 Posted July 11, 2013 Share Posted July 11, 2013 I like idiot's suggestion and am looking at Konis with the stock springs. Still looking at sway bars. Probably throwing this together next week if everything works out. I'm not driving off road but its pretty close with some of these roads in NW Milwaukee. I blame them for my failing stock front struts (54,000 miles). Link to comment Share on other sites More sharing options...
