jackfortune Posted February 21, 2012 Share Posted February 21, 2012 The ride is firm and solid. I have about 600 miles on my new setup....Bilstein HD's/pinks. This is the way the car should have come from the factory....but owner/drivers in this country are not used to a firm ride like this....customer surveys indicated the vehicle would not be widely accepted with the original ride engineered for the car (the JDM version). Very rough roads here in Maine, a real test for any suspension. You definitely feel the road more, but the ride tends to smooth out with speed. Handling is superb. Very noticeable improvement in handling and feel when traversing the twisting up and downs on the reverse crown secondaries. Transitions are very smooth....glued to the road.... Another neat aspect is that the car is completely level when done with the right pinks...none of the rear sagging experienced with other setups. No need for rear spring spacers.... Link to comment Share on other sites More sharing options...
TheDon427 Posted February 22, 2012 Share Posted February 22, 2012 Did you go with sedan fronts and wagon rears? I really want to get a set of Pinks for my '08 Spec.B but can't find a straight answer as to which ones are the best option. Some say they sag, others say get wagon springs for the rear, others say they don't sag at all... I'd consider coilovers but I barely have 20k miles, I'd hate to get rid of the stock Bilsteins when they have such little mileage on them. Not to mention the headaches associated with coilovers. Link to comment Share on other sites More sharing options...
jackfortune Posted February 22, 2012 Share Posted February 22, 2012 2006 LGT.....replaced the stock front struts with Bilstein HD's (probably stiffer than the stock Bilsteins)....order the pinks through EDO: http://shop.edoperformance.com/sti-pink-springs-frontrear-legacy-bspec-p-9387.html (for your vehicle) After reviewing the pinks chart, I ordered this set as recommended by EDO: http://shop.edoperformance.com/sti-pink-springs-frontrear-legacy-p-9386.html (for my 2006 LGT non-SpecB) replaced my front mounts with SpecB.....used stock rear mounts....replaced all other parts with new stock hardware and absorbers..... installation came out perfectly level without using rear shims....cannot say how your SpecB level would come out....but assume it would be the same...a slight lowering all around for my LGT.... Recommend this setup to anyone for a street car....perfectly stable....no lean in corners....good transitions.... Link to comment Share on other sites More sharing options...
ej25_TS Posted March 1, 2012 Share Posted March 1, 2012 Might be a dumb question but springs for a 2006 sedan GT is the same for a 2.5 non turbo sedan? Aboput to order but just want to be 100%. thanks Link to comment Share on other sites More sharing options...
N.sane Posted March 1, 2012 Share Posted March 1, 2012 Might be a dumb question but springs for a 2006 sedan GT is the same for a 2.5 non turbo sedan? Aboput to order but just want to be 100%. thanks 4th generation Legacy GT and 2.5i can use the same suspension mods, except for front sway bar and front underbody braces. So yes, springs are ok Link to comment Share on other sites More sharing options...
W.K.S. Posted March 1, 2012 Share Posted March 1, 2012 Does anyone have experience with the Bilstein/Swift combo? I would love to see a picture of them on a GT. Also is there anything i need besides the spec b tophats when ordering the Bilsteins? (Set on the bilsteins for struts now just picking springs.) Link to comment Share on other sites More sharing options...
katalyst Posted March 1, 2012 Share Posted March 1, 2012 i've seen that combo before on a sedan. the wheel gap looks good, but the rear tends to sag a bit, i'd recommend the rear shim plates Link to comment Share on other sites More sharing options...
subaru1657615622 Posted March 1, 2012 Share Posted March 1, 2012 I'm new user here, nice to meet you guys!! I am looking for a lowering springs for my 2005 legacy wagon 2.5i I have already upgraded the wheels from 16" to 18", is that okay to only change lowering springs to drop a.1.5"? Thanks a lot!! Link to comment Share on other sites More sharing options...
peteyjr Posted March 2, 2012 Share Posted March 2, 2012 You should be fine with 18's and a 1.5 " drop but it may depend on tire choice. I ran 225/45/18 without rubbing on low Swifts (approx 2 " drop) . but since they were on stock shocks they wore out and eventually I got some rubbing on the inner plastic wheel liner. Link to comment Share on other sites More sharing options...
ripcurl Posted March 3, 2012 Share Posted March 3, 2012 Looking for a low cost strut/spring combo to replace my stock setup. My LGT is a DD, I don't track it and am looking for a mild drop. Will the KYB struts and Epic Springs be a good combo? Link to comment Share on other sites More sharing options...
BoostWagon Posted March 5, 2012 Share Posted March 5, 2012 Looking for a low cost strut/spring combo to replace my stock setup. My LGT is a DD, I don't track it and am looking for a mild drop. Will the KYB struts and Epic Springs be a good combo? Another DD here, based in New England. Havng my Konis and Epics installed this Thursday, I opted for the adjustability of the Konis with our widely variable roads. Probably wont tweak them often, just figure ut what setting I like best and leave it there most of the time.  Never researched the KYB cost but the Konis can be had for less than $500 right now for all 4. Link to comment Share on other sites More sharing options...
Norm Peterson Posted March 6, 2012 Share Posted March 6, 2012 If the adjusters aren't difficult to get to, it's maybe a five minute job to reset them on the occasions where your passenger(s) might not have as much tolerance for a firm-ish ride as you. You can fab up a much better adjustment tool from a short length of 1" x 1/8" steel strip than the plastic knob thing that Koni ships with them.  Norm Link to comment Share on other sites More sharing options...
Bonafide P Posted March 6, 2012 Share Posted March 6, 2012 Looking for a low cost strut/spring combo to replace my stock setup. My LGT is a DD, I don't track it and am looking for a mild drop. Will the KYB struts and Epic Springs be a good combo? I'm thinking of the same set up. Let me know how it is, im scared of dragging my y pipe! [spt] Link to comment Share on other sites More sharing options...
jav2.5 Posted March 6, 2012 Share Posted March 6, 2012 So if I just change springs, and leave everything else stock, i should be OK? I have different set of 17's, but will be using the same tires on stock rims from my 09 2.5i. Rallitek springs are the ones I'm thinking......I am mostly on the highway, no city driving. Link to comment Share on other sites More sharing options...
ej25_TS Posted March 7, 2012 Share Posted March 7, 2012 I noticed some of you are running saggy butt spacers. I just picked up some S-techs that I'm going to ride for the next season or two before I get Coils. Are these worth getting? Link to comment Share on other sites More sharing options...
Zac88 Posted March 17, 2012 Share Posted March 17, 2012 Are their any springs well suited for the GR2? I have a hard time spending $800 on bilsteins for just a DD Link to comment Share on other sites More sharing options...
KBGRIZZLY64 Posted March 20, 2012 Share Posted March 20, 2012 I put tein lowering springs on my lgt with stock struts. Springs lowered 1.5 front and 1.4 in rear. My camber was over a degree negative on front and rear had to buy camber kits for front and rear went with whiteline rear camber kit and some generic bolt front camber kit. Also noticed that my lower inner control arm bushing was torn so replaced those with perrin 0 caster positive steering bushings. Handles much better in the corners but ride is significantly uncomfortable. Looking into replacing struts... Newbie question, how to post pictures? Priorities change when car parts come into the equation Link to comment Share on other sites More sharing options...
TheDon427 Posted March 22, 2012 Share Posted March 22, 2012 http://www.imageshack.com http://www.photobucket.com etc. Also, s-techs are known to be terrible. You should look into different springs. Link to comment Share on other sites More sharing options...
KBGRIZZLY64 Posted March 22, 2012 Share Posted March 22, 2012 Got the springs off craigslist for $120 and I think they arent half bad worth the money I paid for them. Priorities change when car parts come into the equation Link to comment Share on other sites More sharing options...
KBGRIZZLY64 Posted March 22, 2012 Share Posted March 22, 2012 http://i1245.photobucket.com/albums/gg586/kbgrizzly64/SCOOB2.jpg Priorities change when car parts come into the equation Link to comment Share on other sites More sharing options...
scobaru5 Posted March 25, 2012 Share Posted March 25, 2012 is there a list of what the spring rates of some of these aftermarket springs are? Link to comment Share on other sites More sharing options...
scoobydoobie Posted March 25, 2012 Share Posted March 25, 2012 is there a list of what the spring rates of some of these aftermarket springs are? Here you go: http://legacygt.com/forums/showpost.php?p=2627431&postcount=19 Link to comment Share on other sites More sharing options...
blklgt Posted March 26, 2012 Share Posted March 26, 2012 since cobb springs are no longer available it looks like swifts are my only option for an 1.5 drop..are konis the best mate for swifts? Link to comment Share on other sites More sharing options...
peteyjr Posted March 27, 2012 Share Posted March 27, 2012 Remember it was pointed out that Swifts were originally designed with the JDM Bilsteins (or something like that) so the drop with Koni's will be more like 2-2.5 " (at least up front) Link to comment Share on other sites More sharing options...
blklgt Posted March 27, 2012 Share Posted March 27, 2012 Then I would have to get spec b top hats right. Is there another spring option for that drop? Link to comment Share on other sites More sharing options...
