89fc3s Posted September 13, 2012 Share Posted September 13, 2012 Any difference between a V7 STi and '04 STi trans? Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted September 13, 2012 Author Share Posted September 13, 2012 IIRC gearing & synchros. 06- up as update synchros. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
89fc3s Posted September 14, 2012 Share Posted September 14, 2012 I meant like when it comes to swapping it, sorry Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted September 14, 2012 Author Share Posted September 14, 2012 IIRC Need to remove axle stubs. Replace the 04 axle seals with 05 axle seals. Their is a RH & LH seal.Then you can use the stock Legacy front axles. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
89fc3s Posted September 14, 2012 Share Posted September 14, 2012 what about rear diff and axles? Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted September 14, 2012 Author Share Posted September 14, 2012 Re read post 1 & thread. Everything is there. In short, Pick a rear diff, R160 or R 180 that matches the final drive of your 6MT. 04 STi 6MT's is 3:90. R160 reuses stock GT rear axles. R180 needs 07-09 Spec.B rear axles & rear diff mount. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
89fc3s Posted September 14, 2012 Share Posted September 14, 2012 Thank you Link to comment Share on other sites More sharing options...
CTATV Posted September 14, 2012 Share Posted September 14, 2012 ^ I agree. I would add the front LSD and the DCCD to the spec b tranny. That would be nice! I think someone posted in one of the threads that it wouldnt be too hard to add the center diff and the DCCD controller to the spec b tranny. The LDS front would be a little more involved but could be done as well. I just swapped in an 07 STi tranny from a wrecked STi... why fool with the spec.b tranny when there are tons more STi's out there. Link to comment Share on other sites More sharing options...
NSFW Posted September 16, 2012 Share Posted September 16, 2012 Spec B 6MT has better gear ratios for a DD or a drag car. If the front or center diffs are easy to upgrade then why not? (Note that I have no idea what it takes to actually do those upgrades....) Link to comment Share on other sites More sharing options...
gordata Posted September 19, 2012 Share Posted September 19, 2012 How hard would it be to swap the center diff to a dccd unit? I bet the from LSD is more of a improvement... Sent from my SPH-L710 using Tapatalk 2 Link to comment Share on other sites More sharing options...
TurboLag23 Posted September 19, 2012 Share Posted September 19, 2012 Approximately how much did this cost, when all the parts were added up??? Link to comment Share on other sites More sharing options...
TurboLag23 Posted September 26, 2012 Share Posted September 26, 2012 I just swapped in an 07 STi tranny from a wrecked STi... why fool with the spec.b tranny when there are tons more STi's out there. What was the total cost on your transmission swap, all-told?? Also, just a general question: how hard would it be to convert an automatic car to a manual?? What "extra" work would go into this?? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 26, 2012 Moderators Share Posted September 26, 2012 What was the total cost on your transmission swap, all-told?? Also, just a general question: how hard would it be to convert an automatic car to a manual?? What "extra" work would go into this?? I think all of those questions are in the "if you have to ask....." category "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
NSFW Posted September 26, 2012 Share Posted September 26, 2012 I just copy/pasted some pricing info into post #2 in this thread (from #32), so it will be easier to spot. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted September 28, 2012 Share Posted September 28, 2012 Link to comment Share on other sites More sharing options...
NSFW Posted September 28, 2012 Share Posted September 28, 2012 (edited) Yeah, wrong thread. I just moved it. Edited September 28, 2012 by NSFW got home to a real computer Link to comment Share on other sites More sharing options...
ama0787 Posted October 28, 2012 Share Posted October 28, 2012 Did i read a post earlier right saying that 08 and up sti shifter and linkage can be used when doing a 6 speed swap with no modification to rod length etc.. ? In other words either buy a spec b short shift kit or just use the factory 08 adn up sti shift linkage and handle? TIA, Anthony Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 28, 2012 Share Posted October 28, 2012 I believe this is correct. search my user name for information in the 6 speed threads on the stay cp and rod length. Link to comment Share on other sites More sharing options...
snowdrift86 Posted November 4, 2012 Share Posted November 4, 2012 So for some reason my swap with an 04 trans wasn't very simple as far as front axles go. Swapping just the seals did nothing for me. the axles dont slide in far enough to lock in and it leaks. come to find out the retainers that preload the front diff are different. seal slides in from the back so i had to unscrew them to change them. never recalled reading about that. so now im trying to figure out how to resolve this problem... Link to comment Share on other sites More sharing options...
snowdrift86 Posted November 4, 2012 Share Posted November 4, 2012 Well crap. Disregard previous post. Found the answer. Sorry Link to comment Share on other sites More sharing options...
NSFW Posted November 4, 2012 Share Posted November 4, 2012 What was the answer? Link to comment Share on other sites More sharing options...
HellShadow70 Posted November 7, 2012 Share Posted November 7, 2012 My Friend And i have done a project were we got a 04 forester xt engine and tranny in a 98 legacy gt. the car ran good but the speedometer was not working. now we have installed a 04 sti 6 speed in it, all we are waiting for is the custom drive shaft. so we need help to make the speedometer and the tranny work. if anyone has a diagram we would appreciate. thanks Link to comment Share on other sites More sharing options...
snowdrift86 Posted November 8, 2012 Share Posted November 8, 2012 The answer was i needed two replace the retainers for the front diff as well as the seals. Got them ordered now just playing to waiting game :|! lol Link to comment Share on other sites More sharing options...
TurboLag23 Posted November 17, 2012 Share Posted November 17, 2012 You need to read through NSFW's thread, hammerdown's thread and groff's thread (this one). Your answers are there. Hubs cant be swapped and axles cant be converted. Also there is a thread for converting an Auto.... Can you point me towards that auto conversion thread please??? Thanks Link to comment Share on other sites More sharing options...
kleinerbastler Posted December 2, 2012 Share Posted December 2, 2012 Hello, i read the whole thread. But my brain is now confused .I have the 3.0 H6 MY06 with 6MT, so i just have to change the transmission and add a DCCDpro controller - the driveshaft will fit to the "new" transmission? Is there any difference between the LH und RH transmissions - so i can install RH tranny to LH car? Thanks Link to comment Share on other sites More sharing options...
