KCwagon Posted September 18, 2011 Share Posted September 18, 2011 (edited) That's because the Impreza one is a completely different design. You need the one above mate I wasn't responding to the picture. That's the one I have on my car. Yes I realize it is the same. Notice he said 04-05 STi. UH, OK....mate......... Edited September 18, 2011 by KCwagon Link to comment Share on other sites More sharing options...
ama0787 Posted September 18, 2011 Share Posted September 18, 2011 Do the sit switchs illumination match or legacy interior illumination? TIA, Anthony Link to comment Share on other sites More sharing options...
Scooby2.5 Posted September 18, 2011 Share Posted September 18, 2011 It just has one orange LED on the auto/maual switch that is rarely on. It matches way better as a stock switch than the aftermarket ones that you get with the DCCDpro. http://legacygt.com/forums/showthread.php/dccd-control-install-location-156507.html Link to comment Share on other sites More sharing options...
ama0787 Posted September 19, 2011 Share Posted September 19, 2011 But the orange doesnt match our interior? For some reason i thought the sti's had same red lighting as us. Do they have a different color interior lighting? TIA, Anthony Link to comment Share on other sites More sharing options...
Kaos22B Posted September 19, 2011 Share Posted September 19, 2011 UH, OK....mate......... Link to comment Share on other sites More sharing options...
KCwagon Posted September 19, 2011 Share Posted September 19, 2011 Link to comment Share on other sites More sharing options...
Scooby2.5 Posted September 19, 2011 Share Posted September 19, 2011 But the orange doesnt match our interior? For some reason i thought the sti's had same red lighting as us. Do they have a different color interior lighting? TIA, Anthony Yes it does. The orange LED that lights up when you go to manual or are in auto and its working is the same as the orange light that lights up on the rear defroster button, defrost button for windshield and heated mirrors, and windshield wiper heater button. Also on the STI the same kind of thing. Any of the buttons you toggle on or off for certain features has a little round LED window on them that glows orange when on. Link to comment Share on other sites More sharing options...
ama0787 Posted September 19, 2011 Share Posted September 19, 2011 (edited) Looks like I'll be using the 08 sit transmission I have and a spec b rear diff. Does this mean I have to use the spec b rear axles? Also can I use a 4eat driveshaft or does it have to be the spec b driveshaft also? If I can use the auto driveshaft is it thte same exact part as the spec b driveshaft or is the spec b stronger or better for some reason. Seems like I could get a auto driveshaft cheaper than I could get a spec b shaft. TIA, Anthony Edited September 19, 2011 by ama0787 Link to comment Share on other sites More sharing options...
KCwagon Posted September 19, 2011 Share Posted September 19, 2011 Looks like I'll be using the 08 sit transmission I have and a spec b rear diff. Does this mean I have to use the spec b rear axles? Also can I use a 4eat driveshaft or does it have to be the spec b driveshaft also? If I can use the auto driveshaft is it thte same exact part as the spec b driveshaft or is the spec b stronger or better for some reason. Seems like I could get a auto driveshaft cheaper than I could get a spec b shaft. TIA, Anthony 1) You will need to use Spec B axles (because it is an R180) 2) I have seen both the Automatic and Spec B driveshafts and they appear to be the same in terms of size/appearance. I would use the Automatic, given the difference in cost. Link to comment Share on other sites More sharing options...
ama0787 Posted September 28, 2011 Share Posted September 28, 2011 how about clutch master and slave cylinders? Also as far as clutch and flywheel go is the standard sti stuff good enough for how much hp? TIA, Anthony Link to comment Share on other sites More sharing options...
KCwagon Posted September 28, 2011 Share Posted September 28, 2011 how about clutch master and slave cylinders? Also as far as clutch and flywheel go is the standard sti stuff good enough for how much hp? TIA, Anthony Clutch master cylinder is fine..you will need a slave cylinder for the 6 speed. Your existing clutch line will work. The stock STI clutch and flywheel is pretty strong, but stage 3 will challenge it a bit. I have an 08 Spec B transmission, r160 out of a WRX and a Clutchmasters fx300/STI flywheel. It is a pretty good set-up. The fx300 is either on or off though. An STI clutch will give you smoother engagement and good up to 280 HP/TQ. The torque number is what I would be more concerned with as far as clutch slippage. Link to comment Share on other sites More sharing options...
CTATV Posted October 15, 2011 Share Posted October 15, 2011 starting my 6 speed swap after I lost 5th gear on Tuesday in my 5 speed. Already picked up an 07 STi transmissiion with shifter linkage, flywheel, clutch slave cyl, and R180 rear end. I ordered the DCCDPro controler. Just hunting down the driveshaft and axles now. I was told also that any 97 to 04 Legacy driveshaft will work as well... Anybody else confirm or deny this? I am assuming I will have to fork out the dough for brand new rear 07-09 spec.b axles so I want to try and find a used driveshaft rather than paying 700 bucks for a brand new one. Also will be doing Group N tranny and engine mounts as well as an ACT Street clutch with stock flywheel. The tranny and R180 came off an STi that had been rear ended and only had 39k miles on them Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 15, 2011 Share Posted October 15, 2011 I purchased mine off ebay. 2006 2.5i 4EAT shaft from a Legacy Sedan. Worked perfect in my Outback XT 6 speed swap. Check Ebay, there were a lot on there from 75-150 bucks when I did mine Link to comment Share on other sites More sharing options...
CTATV Posted October 15, 2011 Share Posted October 15, 2011 Nice, thanks! Link to comment Share on other sites More sharing options...
ama0787 Posted October 16, 2011 Share Posted October 16, 2011 (edited) Are the sti & specB slave cylinders the same? If they are not will either work? Also that diff mounting bracket that i was confused about is usually reffered to as a pinion brace or mount TIA, Anthony Edited October 16, 2011 by ama0787 Link to comment Share on other sites More sharing options...
ama0787 Posted October 16, 2011 Share Posted October 16, 2011 Hammer down, I have seen other talk about you modding the Subaru Momo 5 speed shifter and making it work in your 6-speed swap. I only saw you mention the autozone knob in your thread. If you did do this could you tell me about it and if possible show me some pictures. I definately plan on going this route i love my shift knob and will find away to use it. TIA, Anthony Link to comment Share on other sites More sharing options...
ama0787 Posted October 16, 2011 Share Posted October 16, 2011 Groff are you sure you options match right? The spec b r180 is a 3.54 from my research as is the 06 sti r180 meaning that they have the 1.1:1 tranny where the 04-05 sti has the 1:1 tranny with a 3.9 r180 Do you think this info is correct or incorrect? If it is correct i believe your options need adjusted. Seems like you have the sti years and 1.1:1 vs 1:1 reversed if i am not mistaken. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted October 16, 2011 Share Posted October 16, 2011 (edited) Looks like I'll be using the 08 sit transmission I have and a spec b rear diff. Does this mean I have to use the spec b rear axles? Also can I use a 4eat driveshaft or does it have to be the spec b driveshaft also? If I can use the auto driveshaft is it thte same exact part as the spec b driveshaft or is the spec b stronger or better for some reason. Seems like I could get a auto driveshaft cheaper than I could get a spec b shaft. TIA, Anthony Anthony, this is what I am talking about, (in another thread) all of these questions have been answered. Read through the threads, take some notes and then post up any more questions you have, and we will be glad to answer them. I read through all of them and it ended up the only real question I had was the driveshaft issue. My car is an outback XT, and the length of the shaft I got out of a 2006 4EAT 2.5i sedan didn't seem correct in comparison with hammer downs custom shaft. The threads clearly state you can use a 4EAT shaft in place of the spec b or the custom shaft. Thats why I purchased the 4EAT shaft. I was only unclear on the lengths and whether it would work in an Outback XT. It did in fact bolt right up with no issues even on my outback XT. Edited October 16, 2011 by Scooby2.5 Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted October 16, 2011 Author Share Posted October 16, 2011 Sorry, but I mod the STi shifting linkage. It's 3/8" to short for it to be centered in the center console. Maybe you can mod your shifting knob like I did with the Auto Zone knob. You do need a 6MT shifter from a Spec.B or STi. 5MT shifter wont work. There's no reverse lockout knob. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Guest Posted October 16, 2011 Share Posted October 16, 2011 Yep, 04-05 sti have 1:1 tranny, while 06+ have 1:1.1 Final is 3.9 either way. Link to comment Share on other sites More sharing options...
ama0787 Posted October 16, 2011 Share Posted October 16, 2011 Do you know the threaded shaft size of the 6speed shifter? Also does the reverse lock out slide up into shift knob? TIA, Anthony Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 16, 2011 Share Posted October 16, 2011 M12x1.25 And yes, the collar slides up into the shift knob. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
NSFW Posted October 17, 2011 Share Posted October 17, 2011 Yep, 04-05 sti have 1:1 tranny, while 06+ have 1:1.1 Final is 3.9 either way. Depends what you mean by "final," though... The front diffs are all 3.9:1 but the rear diffs for the 1.1:1 transmissions are are 3.54:1. Link to comment Share on other sites More sharing options...
Guest Posted October 17, 2011 Share Posted October 17, 2011 Final means final. Reduction between the current gear and the wheels (all of them). Of course STI 06+ rear diffs are 3.54:1. 3.54545455:1 to be exact 04-05 rear diffs are straight 3.9:1. Link to comment Share on other sites More sharing options...
ama0787 Posted October 17, 2011 Share Posted October 17, 2011 So should thee be two different holes drilled? One to allow the collar to slip up into and the other too thread on to the shifter shaft? Any ideas o modding the lock out so it does not slide into shift knob? Ive only been in one sit recently and should have looked closer the only other reference I have is my supra which has a 6 speed with lock out that goes up into the shift knob but I think looking at it can't get me past ideas Link to comment Share on other sites More sharing options...
