ClimberDHexMods Posted September 9, 2010 Share Posted September 9, 2010 The driveshaft is en route. I'm about to give up on getting a transmission from Rallispec, they were supposed to get back to me Tuesday, but have just ignored half of my emails and phone calls. Will talk to a local transmission shop this week about putting spec B gears into an STI 6MT. AFAIK Dave is Rallispec, so if he is gone for vacation or is busy, Rallispec can't do much. When I talked with him and then met him, I got the feeling he was a better parts guru than businessman or delegater. Perhaps don't give up just yet. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
sixspeedlegacy Posted September 9, 2010 Share Posted September 9, 2010 I have a 2009 Sti tranny with 15k miles on it, I would entertain selling for the right price but it sounds like you want the 04/05 DCCD front rear split but just throwing it out there. Good luck! Ben Link to comment Share on other sites More sharing options...
NSFW Posted September 10, 2010 Share Posted September 10, 2010 (edited) Thanks, but yeah I'm going for an 04/05. I'm trying to compile the part numbers for the spec B gears. I think this is what Rallispec uses in their 'high speed gear ratios' conversion - the ratios shown on their web site match the spec B ratios shown at cars101.com. Everything but the 2nd drive gear is on opposedforces.com... Drive gears: 2nd: ??? still looking... 3rd: 32275AA590 4th: 32276AA300 5th: 32341AA380 6th: 32337AA060 (pre Dec 07) / 32363AA120 (post Dec 07) Driven gears: 2nd: 32251AA910 3rd/4th: 32254AA630 5th/6th: 32364AA100 Baulk rings: 32614AA111 Reference: http://opposedforces.com/parts/legacy/us_b13/type_12/ Edited September 10, 2010 by NSFW Link to comment Share on other sites More sharing options...
Z0rr0 Posted September 18, 2010 Share Posted September 18, 2010 (edited) Also, a little bit of information for those that get an STi shift linkage. You can buy a 07+ Spec B stay rod and shifter rod so that it puts the shifter in the center of the console opening. You will reuse the STi shift lever and reverse lockout cable as well as the rubber boot thing on the bottom. If you plan on upgrading to an aftermarket shifter and are using the STi shift linkage, only 04-07 STi lever will work as after having a discussion and sending pictures to Tom @ Kartboy, he said that only the 04-07 STi shift lever will work with the STi linkage setup. Part #'s for those that have STi shift linkages and want to center their shifters without cutting/welding/spacing: Spec B Shifter Rod: 35041AG020 Spec B Shifter Stay: 35031AG020 that's cheaper than having the sti ones extended by a shop. im ordering them monday always bothered me after my swap that my shifter wasnt centered. heres the parts from myimportparts.com (chandler subaru superstore in chandler, AZ) Part Number: 35041AG020 ROD CP GEAR SHIFT $20.37 Part Number: 35031AG020 STAY CP GEAR SHIFT $33.38 Edited September 21, 2010 by Z0rr0 Link to comment Share on other sites More sharing options...
NSFW Posted September 22, 2010 Share Posted September 22, 2010 Finally some actual progress... I just paid Silverline Automotive to ship an 04 transmission to Rallispec, to have spec B gears installed. They'll put in the newer style syncros while they have it apart. Link to comment Share on other sites More sharing options...
csperformance Posted September 22, 2010 Share Posted September 22, 2010 How much would the cost be for just the basic swap without all the extras you are adding? Link to comment Share on other sites More sharing options...
NSFW Posted September 22, 2010 Share Posted September 22, 2010 These figures will vary a lot, depending on whether you can / will wait for great deals to pop up in the classifieds, but here's what I'm paying: $3500ish for the trans and diff. $565 for the driveshaft $700ish for the rear axles (I think.... haven't bought them yet) $300ish for a used spec B shift linkage $300ish for the DCCD controller Plus small parts that I haven't added up. Plus whatever you want to spend on a clutch. Someone said they did it for $3000 or so, partly due to a great deal on a transmission and diff. I tried looking for a great deal, but ran out of patience. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted September 22, 2010 Author Share Posted September 22, 2010 How much would the cost be for just the basic swap without all the extras you are adding? Between $3K - $6K Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
PhilT Posted September 23, 2010 Share Posted September 23, 2010 It cost me $6,500 including install, done at Lachute Subaru in June. I didn't really have a choice as the front diff on the 5mt was toast, but I'm sooooo happy I paid the extra to get the 6mt installation, worth every penny. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
sixspeedlegacy Posted September 28, 2010 Share Posted September 28, 2010 I"m confused as to why you are not just using an 07 Spec B transmission? Or even an 07 Sti transmission. You will have the gears and diffs if you wanted LSD and DCCD and the new synchros. You can get brand new 07 STi bare transmissions for 3800 from the dealer(or used to be able to). You seem to be making a lot more work and expense for yourself. Why did you choose to send an 04 to have gears installed? I assume there is a reason I am just curious what it is. Did you get a non working 04 Sti tranny for cheap from Silverline? Thanks Ben Link to comment Share on other sites More sharing options...
NSFW Posted September 28, 2010 Share Posted September 28, 2010 (edited) I want DCCD, an open center diff when DCCD is 'off,' front LSD, 35/65 torque split, and spec B gearing. There's a little bit more info in the 'master swap thread' but that's what it boils down to. Getting all of those in one box is taking some extra work and expense, yes. Edited September 29, 2010 by NSFW forgot to mention from LSD & 35/65 Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted September 28, 2010 Author Share Posted September 28, 2010 And the Spec.B don't have DCCD (like NSFW said) & front LSD. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
NSFW Posted October 4, 2010 Share Posted October 4, 2010 Does the STI flywheel mount with the same bolts as the LGT / 06 WRX flywheel? I'm guessing it does, but I'd hate to be wrong... Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 4, 2010 Share Posted October 4, 2010 Does the STI flywheel mount with the same bolts as the LGT / 06 WRX flywheel? I'm guessing it does, but I'd hate to be wrong... The cranks are the same, so the answer should be yes. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
tsunami Posted October 4, 2010 Share Posted October 4, 2010 Whats the torque split on the 07 spec B? Just wondering. Also, to get dccd, is that something I can add to my transmission? Or would I have to get an sti takeoff? Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted October 4, 2010 Author Share Posted October 4, 2010 Does the STI flywheel mount with the same bolts as the LGT / 06 WRX flywheel? I'm guessing it does, but I'd hate to be wrong... Yes, but get the STi fly wheel bolt. They are hex head bolts. Not the Torx T-50 plus heads. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted October 4, 2010 Author Share Posted October 4, 2010 Whats the torque split on the 07 spec B? Just wondering. Also, to get dccd, is that something I can add to my transmission? Or would I have to get an sti takeoff? If the Cases are the same in that area & the center diff splines . You can add the DCCD, but you would need to do is at least drill a hole in the case for the wires to the DCCD. That can be sealed, so your 6MT don't leak. I would price the different between installing DCCD & Front LSD in the Spec. B 6MT. & buying a use STi 6MT. Then go from there. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
tsunami Posted October 4, 2010 Share Posted October 4, 2010 I see. Thanks Mike, but any idea what the torque split on the stock Spec. B is? Is it biased rear like the sti? Also, the are the gear ratio's the same in the Spec. B 6 vs the Sti 6 speed Link to comment Share on other sites More sharing options...
LuckyBob Posted October 4, 2010 Share Posted October 4, 2010 I see. Thanks Mike, but any idea what the torque split on the stock Spec. B is? Is it biased rear like the sti? Also, the are the gear ratio's the same in the Spec. B 6 vs the Sti 6 speed Take a look at the first two posts in this thread. Link to comment Share on other sites More sharing options...
tsunami Posted October 4, 2010 Share Posted October 4, 2010 Take a look at the first two posts in this thread. Thanks, I don't know how I missed that. Link to comment Share on other sites More sharing options...
NSFW Posted October 6, 2010 Share Posted October 6, 2010 Transmission pics added to post 3. Installation next week! Link to comment Share on other sites More sharing options...
NSFW Posted October 7, 2010 Share Posted October 7, 2010 (edited) ...and I'm 6MTified now. Will update the first page with some more pics later tonight. It took 3 of us 5 hours to pull out the 5MT, driveshaft, diff, and axles.Then we got stalled for a couple days for lack of a clutch fork pivot shaft.Then it took 2 of us 10 hours to put the 6MT and everything back in. Still need to wire up the DCCD controller and put the interior trim back onto the center console, but I've driven 20 miles or so with no trouble. Those of you who have already done this... can you re-use the 5MT shift boot with a 6MT shift lever? I was think it would fit right back in, but I forgot about the reverse lockout ring thing. Can I just pop that off, put the shift boot on, and reassemble the lockout? Huge huge thanks to Easy19 and Citka for all the help. Edited October 21, 2010 by NSFW Link to comment Share on other sites More sharing options...
sumfoo1 Posted October 15, 2010 Share Posted October 15, 2010 What would you have to do for 08+ sti parts ? Link to comment Share on other sites More sharing options...
06wrxlbart Posted October 20, 2010 Share Posted October 20, 2010 Has anyone swapped a 5EAT for a 6 speed on here? Can you put a list together? Link to comment Share on other sites More sharing options...
DRoc7822 Posted October 20, 2010 Share Posted October 20, 2010 Has anyone swapped a 5EAT for a 6 speed on here? Can you put a list together? I think it depends on which 6 Speed your talking about? The Spec B or the STI 6 speed? I think the parts list is on page 1 of this.... Link to comment Share on other sites More sharing options...
