Don't all spec B's have a 6 speed?
O really? What makes the Spec B different from the GT besides the 6MT? Why does it need another gear? I know what I want in 4 yrs...
So spec B owners can call their cars special.
6 sp and 5sp seems to be about the same. I thought I should of got the Spec B for the 6sp so it would have a lower cruising rpm on the highway, but from what I understand the rpm between 6sp LGT and 5sp LGT are within a hundred or so rpms i think? EPA also rates the specB with 2mpg less than the 5mt in city and 1mpg less on highway.
Compared to the 5MT LGT's, SpecB's has VDC, Bilsten suspension, different fabric for interior, navigation, 6speed trans, and the plastic specB emblem on the trunk :lol:
Nice, thanks guys. I was a little perplexed when I saw this...
Bbc84-don't forget the aluminum suspension components too.
Just like it says, Spec B has aluminum arms and links to reduce weight. They are identical to the ones on LGT just made from aluminum.
6spd is way smoother than the 5mt (i had an 06gt, now have an 08specb...very happy). Slightly shorter shifts as well and maybe better gear ratios (?) but not sure. Car doesnt feel much faster but definately more enjoyable to drive.
6mt is smoother than 5mt
6mt is much more robust than 5mt (handles more power)
Spec.B has inverted struts and Bilstein suspension components
Spec.B has Torsen LSD in the back
Spec.B has 18" wheels and comes stock with pretty good tires
Spec.B has alcantara seat inserts
Spec.B has navigation with the manual transmission (not sure if you can get that with the new ones, but in 07 you couldnt)
Hope that sums it up
awesome, i like the stock 18" wheels
You forgot VDC as well as the memory seats.
Spec.B has 6MT
Spec.B has inverted Bilstein struts/shocks
Spec.B has aluminum control arms, tailing arms, upper links, rear "forward" links, and rear sub-frame support arm
Spec.B has Torsen rear LSD (R180)
Spec.B has 18" wheels and Summer RE050 tires
Spec.B has alcantara seat inserts w/ memory seats
Spec.B has VDC
Spec.B has chrome insert rocker panels
Keep it factual rather than subjective?
