mickeyd2005 Posted May 17, 2008 Share Posted May 17, 2008 Can someone log rpm and mph in 4th gear and 5th gear from low speed to high speed at WOT. Log rpm, mph, and throttle. Here's what a 3rd gear WOT log looks like from 20 mph: http://i141.photobucket.com/albums/r69/mickeyd2005/20085eatmphvsrpm.jpg Heat is the problem. The service manual specifies how to raise the IAM by revving the engine in gear with the brakes applied but they limit it to xxx seconds or else damage will occur. The G37 may have the same basic transmission type, but there might be subtle changes that make it different. Even if it was the same, the stock G37 makes about 236 ft-lb of peak torque at the wheels. http://en.wikipedia.org/wiki/Infiniti_G37 And that's at a much higher rpm than the LGT. A stage 1 or 2 LGT will make peak torque between 3000 and 3500 rpm. Peak horsepower isn't the issue. It's high torque at rpm < 3700 rpm. Link to comment Share on other sites More sharing options...
AKLGT Posted May 17, 2008 Share Posted May 17, 2008 yes, what he said ^^^^ it's the torque that kills the tranny on the stg 1/2 5EAT. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
korpsepatrol Posted May 17, 2008 Share Posted May 17, 2008 mickey i will be logging this weekend i hope. I will post them here if need be. 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx Link to comment Share on other sites More sharing options...
z28dreams Posted May 17, 2008 Author Share Posted May 17, 2008 Mickey - really good information. Will tuning the custom maps to keep the boost low below 3500rpm keep these transmissions safe? Anything else we can do besides a tranny cooler? Link to comment Share on other sites More sharing options...
z28dreams Posted May 17, 2008 Author Share Posted May 17, 2008 Just pulled up a G37 torque curve... looks like it makes peak torque right around the 3000rpm range. Even at only 2000rpm it's making around 200 @ the wheels. http://image.automobilemag.com/f/features/news/6696996/0705_c+2008_infiniti_g37+dyno_chart.jpg Link to comment Share on other sites More sharing options...
fishbone Posted May 17, 2008 Share Posted May 17, 2008 So the tranny should be able to take it. Interesting, up until this point everyone was pretty convinced Stage 1 is completely safe on the stock 5EAT ... Link to comment Share on other sites More sharing options...
Jerboa113 Posted May 17, 2008 Share Posted May 17, 2008 I've assumed that it is, I've ran a cobb stage 1 93 map since the car was almost new. No cooler or anything over stock really. I'm not ALWAYS up on it but I do get on it on occasion for extended periods. "The penalty good men pay for indifference to public affairs is to be ruled by evil men." - Plato Link to comment Share on other sites More sharing options...
AKLGT Posted May 17, 2008 Share Posted May 17, 2008 Stg 1 is really pretty safe unless you do something dumb. For example, if you are running an intake without a tune for it, you could be causing some damage. other than that, unless you have a really crappy tune, you should be pretty safe. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
dr_sharp Posted May 18, 2008 Share Posted May 18, 2008 plus an SOA tech at my side (not in the car with me) who could help me put the car back together again should something go terribly wrong. AK Wagon gives me crap because I practically have a personal Subie Tech who has built my LGT and will most likely do the same to the STI. How and where did you get this and how do I get one!!! And I never realized how tall 3rd is on the 5eat lol Link to comment Share on other sites More sharing options...
AKLGT Posted May 18, 2008 Share Posted May 18, 2008 Move to AK.... or you or your spouse work for the local Subie dealer service dept. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
LGTdemon Posted May 23, 2008 Share Posted May 23, 2008 how much is a tranny cooler? and a VB mod? Link to comment Share on other sites More sharing options...
z28dreams Posted May 23, 2008 Author Share Posted May 23, 2008 Tranny coolers seem to be around $50. Labor (if you don't do it yourself) runs around 1 hour - so maybe $50-$100 depending on the mechanic. The VB mod sounds like it's quite expensive. Link to comment Share on other sites More sharing options...
korpsepatrol Posted May 23, 2008 Share Posted May 23, 2008 The tranny cooler is quite a simple install, i am a total noob and was able to bang it out, its easier with two people but yeah just make sure you tighten everything down since i didn't and leaked a bit. Tranny coolers are around 40-50 depending on the size of it. VB mod is quite expensive however it does help preserve your tranny once you start hitting the higher power levels. The install for the vb mod which is being done i believe by toady is not for the light hearted. 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx Link to comment Share on other sites More sharing options...
z28dreams Posted May 23, 2008 Author Share Posted May 23, 2008 korpse - which tranny cooler did you go with? Seems like there are a ton of options people are using.. Hayden's, Trucools, etc. Any reason I should use one over another? Link to comment Share on other sites More sharing options...
korpsepatrol Posted May 23, 2008 Share Posted May 23, 2008 I went with the trucool since its the only one that mentions that it performs well in the cold and by cold i mean -5 temps. My cooler is 4454 Tru-Cool LPD thin, Stacked Plate cooler kit From bulkpart.com. 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx Link to comment Share on other sites More sharing options...
ArcTec34 Posted May 25, 2008 Share Posted May 25, 2008 hmm. i should look into this. Link to comment Share on other sites More sharing options...
AKLGT Posted May 26, 2008 Share Posted May 26, 2008 I use a Hayden and no issues, however my car is garage kept. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
matthewluke60 Posted May 26, 2008 Share Posted May 26, 2008 So throwing down in the middle of this. I've been thinking about a cooler, VB mod, and IPT torque converter.......would getting their torque converter be bad or good for my tranny? I plan to occasionally track the car. Link to comment Share on other sites More sharing options...
ArcTec34 Posted May 26, 2008 Share Posted May 26, 2008 what mods have you done to your car? Link to comment Share on other sites More sharing options...
NuWiz Posted May 26, 2008 Share Posted May 26, 2008 Which is better stacked plate or fin & plate design. I am looking at the TruCool 4452 or the 4543. Also on the 4543 it has 3/8" barbs which I think is a direct fit correct? Thanks Mike Link to comment Share on other sites More sharing options...
z28dreams Posted May 26, 2008 Author Share Posted May 26, 2008 Which is better stacked plate or fin & plate design. I am looking at the TruCool 4452 or the 4543. Also on the 4543 it has 3/8" barbs which I think is a direct fit correct? Thanks Mike I believe fin & plate allows for better air pass-through. (Better for your radiator). However, the 4543 is of course larger physically than the others, so it's probably close to a wash. Link to comment Share on other sites More sharing options...
ArcTec34 Posted May 26, 2008 Share Posted May 26, 2008 im goin for the 4453.. Link to comment Share on other sites More sharing options...
korpsepatrol Posted May 26, 2008 Share Posted May 26, 2008 i believe the 4454 is the largest you can go before you start running into fitment(size issues) and where you could put the darn thing. 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx Link to comment Share on other sites More sharing options...
NuWiz Posted May 26, 2008 Share Posted May 26, 2008 That is the second time the 4453 has come up where can you find it. I figured someone messed up the numbers and ment 4543. Thanks Mike Link to comment Share on other sites More sharing options...
AKLGT Posted May 27, 2008 Share Posted May 27, 2008 So throwing down in the middle of this. I've been thinking about a cooler, VB mod, and IPT torque converter.......would getting their torque converter be bad or good for my tranny? I plan to occasionally track the car. you don't need the TC. Tranny cooler easy. I do recommend the IPT VB mod if you are running a heavy stg 2+ (or more like turbo upgrade) and planning on either tracking the car or beating it to hell. Otherwise, the occassional spirited driving will be fine. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
