fishbone Posted February 22, 2011 Share Posted February 22, 2011 Nobody has gone that route that I know of because a more efficient and safe way to shed temp is adding a cooler and possibly using a better ATF, namely synthetics. The TCM has not been cracked to day. Again, torque lock-up is used to increase fuel efficiency, it is not a behavior that has been set up as a way to mitigate temperature rise. It is not something that should be engaged at WOT or under significant load, because you WILL break shit. There's no conspiracy, the stock TC lock-up clutch and the converter in general can't take it. Now, addressing your question does the 5EAT unlock the TC between shifts? Or keep it locked? Torque lock-up is the exception, not the rule. It is not engaged when going through gears and in D mode daily driving, will only be engaged once the transmission is in 5th gear. Link to comment Share on other sites More sharing options...
xero287 Posted February 22, 2011 Share Posted February 22, 2011 Wow this is a great thread. So basically If i have the Perrin LWCP a catless invida dp and a catless up pipe but stock catback, I would need just a tranny cooler correct (looking at the 4454)? I get that the vb mod would help but is it absolutely needed? I'm just a spirited driver so it's not like I duct tape the throttle to the floor Link to comment Share on other sites More sharing options...
fishbone Posted February 22, 2011 Share Posted February 22, 2011 How much of a need it is, up to you, how you drive it and especially how the car is behaving at WOT. Link to comment Share on other sites More sharing options...
xero287 Posted February 22, 2011 Share Posted February 22, 2011 Well, the car is usually great at WOT especially since i have the tranny mount. I'm just trying to play it safe even though I know anything could blow for any reason Link to comment Share on other sites More sharing options...
