STiSubie109 Posted May 13, 2008 Share Posted May 13, 2008 I called the dealer looking for new rotors for my 05 lgt wagon, they stated that mid-year it changed models and they need my vin to verify. Is there a difference or are they BSing me? Link to comment Share on other sites More sharing options...
HansGT Posted May 13, 2008 Share Posted May 13, 2008 btw...send a PM to thekingofparts. good chance they can beat your dealer on price. Link to comment Share on other sites More sharing options...
Xenonk Posted May 13, 2008 Share Posted May 13, 2008 odd, I doubt it. Keefe Link to comment Share on other sites More sharing options...
magnetic1 Posted May 13, 2008 Share Posted May 13, 2008 Should be the same. We also have coated OE-type rotors on sale. http://www.liteswap.com/merchant2/merchant.mvc?Screen=CTGY&Store_Code=L&Category_Code=LGTSpecial Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
rao Posted May 13, 2008 Share Posted May 13, 2008 That type of dealer needs a vin number to look up washer fluid. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
trailblaze Posted May 13, 2008 Share Posted May 13, 2008 well, i was going to start a new thread about an 05 LGT brake upgrade so i'll throw it in here... whats a good "step up" in front rotors, i am stock and will be that way for a while, maybe if luckly, i'll have a drop in filter and ecu reflash.... but not much more.. i don't think i need the best performance stuff, they seems to be 225 and up for front rotors. anything any cheaper and still better than stock? Link to comment Share on other sites More sharing options...
Opie Posted May 13, 2008 Share Posted May 13, 2008 I called the dealer looking for new rotors for my 05 lgt wagon, they stated that mid-year it changed models and they need my vin to verify. Is there a difference or are they BSing me? There is an updated part # for Front Pads and Rotors on early LGT's...but it replaces the old part numbers...and it's the same part numbers used on every LGT since so it really doesn't matter. But in there defense, the Subaru parts lookup program does ask for a VIN to lookup parts, and many think it won't work without it... Link to comment Share on other sites More sharing options...
Guest Posted May 14, 2008 Share Posted May 14, 2008 But in there defense, the Subaru parts lookup program does ask for a VIN to lookup parts, and many think it won't work without it... Bull. VIN is not necessary. Subarufast allows to select car type and trim manually. No need to know magic codes, all is selectable. For those who want to impress your inept parts guy, the model code for our cars is B13. Link to comment Share on other sites More sharing options...
lgtsoon Posted May 14, 2008 Share Posted May 14, 2008 well, i was going to start a new thread about an 05 LGT brake upgrade so i'll throw it in here... whats a good "step up" in front rotors, i am stock and will be that way for a while, maybe if luckly, i'll have a drop in filter and ecu reflash.... but not much more.. i don't think i need the best performance stuff, they seems to be 225 and up for front rotors. anything any cheaper and still better than stock? just upgrade the pads with stock rotors. i put on hawk hps pads and stock rotors and it made a big difference. Link to comment Share on other sites More sharing options...
STiSubie109 Posted May 15, 2008 Author Share Posted May 15, 2008 A big thanks to king of parts, got new rotors and hawk hps's to put on this weekend!! Link to comment Share on other sites More sharing options...
trailblaze Posted May 15, 2008 Share Posted May 15, 2008 post up about the results! Link to comment Share on other sites More sharing options...
Max Capacity Posted May 16, 2008 Share Posted May 16, 2008 That type of dealer needs a vin number to look up washer fluid. They just want to make sure you own a Subaru. But anyways I'm also in the market for front rotor upgrade but not looking to spend $1300.00 or more for a big brake upgrade. http://www.liteswap.com/merchant2/me...ode=LGTSpecial That link above looks good, any feed back on them ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Irrational Exuberance Posted May 17, 2008 Share Posted May 17, 2008 i thought the midyear model change effected ecu only, hence the cobb 2005 and 2005.5 versions of AP/maps "i like my women the way i like terrorists... ...screaming gods name and ready to explode." http://img255.imageshack.us/img255/5479/troy3nu5.jpg Link to comment Share on other sites More sharing options...
boostsr20 Posted May 17, 2008 Share Posted May 17, 2008 They just want to make sure you own a Subaru. But anyways I'm also in the market for front rotor upgrade but not looking to spend $1300.00 or more for a big brake upgrade. http://www.liteswap.com/merchant2/me...ode=LGTSpecial That link above looks good, any feed back on them ? Great service. So far so good with the product! Link to comment Share on other sites More sharing options...
Opie Posted May 17, 2008 Share Posted May 17, 2008 Bull. VIN is not necessary. Subarufast allows to select car type and trim manually. No need to know magic codes, all is selectable. For those who want to impress your inept parts guy, the model code for our cars is B13. Correct, but it asks for VIN first...most parts people aren't very computer savy and can't figure out how to get past that step. Link to comment Share on other sites More sharing options...
STiSubie109 Posted May 18, 2008 Author Share Posted May 18, 2008 With the new rotors and hawk hps's there is some good bite! braking more solid and pedal feel is firmer. woo hoo! Link to comment Share on other sites More sharing options...
