Compilation of cheap and/or free Legacy Mods
Hey thought it would be a cool idea to start a compilation of cheap and/or free mods that can be done to our cars for those looking to tinker but lacking the budget for buying stuff to put on their car.
Right now starting with a list. People can post ones i haven't thought of or listed and any pictures and/or links to threads related to said mods would be great. Will eventually compile pics and links for all mods I can would be a great little resource for us with minimal expendable income or just a fan of DIY mods...
Remove 3rd brake light bulb on cars with spoilers
(read post #7) http://legacygt.com/forums/showthread.php?t=1768&highlight=3rd+brake+light
Disable Seatbelt Chime
- Seatbelt clicking method http://legacygt.com/forums/showthread.php?t=6210
- Unplugging driver seat sensor plug http://legacygt.com/forums/showthread.php?t=52672
- Buckle hack method http://legacygt.com/forums/showthread.php?t=62304
grounding nav/dvd screen to use in motion
(super thread on nav/dvd hacking) http://legacygt.com/forums/showthread.php?t=36342
(writeup on in motion enable) http://legacygt.com/forums/showthread.php?t=63678
DIY front lip (have to buy garage door trim)
http://legacygt.com/forums/showthread.php?t=47461
Replacing Seat heater backlights
http://legacygt.com/forums/showthread.php?t=82414
HOGZAUST
http://legacygt.com/forums/showthread.php?t=35764&highlight=hogzaust+hogmeat
Tucked Exhaust mod
http://legacygt.com/forums/showthread.php?t=59679
Cleaning Exhaust Tips
http://legacygt.com/forums/showthread.php?t=16286
Gutting CAT in UP (up pipe ) &DP (down pipe)
Only 05 and 06 LGTs have a cat in the UP. the UP Cat only helps when car is cold so 07+ they got rid of it
(Gutting UP) http://www.legacygt.com/forums/showthread.php?t=58332
(Gutting DP)
Grill (modifying stock)
(walk through with pics) http://legacygt.com/forums/showthread.php?p=1191120#post1191120
(another by BDII) http://legacygt.com/forums/showthread.php?t=74132
(2008 grill by dmross) http://www.legacygt.com/forums/showthread.php?t=82815
Front Bumper Mesh
(Walk Through with pics) http://legacygt.com/forums/showthread.php?t=61843
TMIC (Top Mount Intercooler) mesh protection
http://legacygt.com/forums/showthread.php?t=2291
http://www.legacygt.com/forums/showthread.php?t=91606
DIY open induction cover (for air intake)
http://legacygt.com/forums/showthread.php?t=61782
Trunk Vent for better subwoofer sound
http://legacygt.com/forums/showthread.php?t=62893&highlight=Pipe
DIY Short Throw Shifter (STS)
http://www.legacygt.com/forums/showthread.php?t=11039
Disable DRL (daytime running lights)
http://legacygt.com/forums/showthread.php?t=2117
- Make fog lights run as DRL - http://legacygt.com/forums/showthread.php?t=42877
Blacking Out Headlights
http://legacygt.com/forums/showthread.php?t=17817
Clearing Headlights (removing amber in corners)
http://www.legacygt.com/forums/showthread.php?t=3737
Fully independent fog lights
http://legacygt.com/forums/showthread.php?t=35066
Rear Tail Light Mod
http://www.legacygt.com/forums/showthread.php?t=9109&highlight=tail+light
Brighter tail lights
http://legacygt.com/forums/showthread.php?t=33311
Unlock all doors one click (hack)
http://legacygt.com/forums/showthread.php?t=2972
Gas Cap Mod (so cap doesnt scratch paint)
http://legacygt.com/forums/showthread.php?t=61836
Flush mount for Escort Radar Smart Cord
4/5 EAT http://legacygt.com/forums/showthread.php?t=11100
5/6 MT http://legacygt.com/forums/showthrea...rt+Flush+Mount
Map lights come on with dome lights
http://legacygt.com/forums/showthread.php?t=23139
Cheap AP (Access Port) dash mounting
http://legacygt.com/forums/showthread.php?t=63342
Cabin Air Filter
http://www.legacygt.com/forums/showt...bin+filtration
Debadging
- Debadging trunk (excluding scoobie oval) http://legacygt.com/forums/showthread.php?t=1175
- New colored Subaru Star Badgehttp://legacygt.com/forums/showthread.php?t=58516
Removing Pin striping installed by dealers
http://legacygt.com/forums/showthread.php?t=30406
Remove Cabin AC (smelly feet) smell
http://legacygt.com/forums/showthread.php?t=64635
Jazzy Aux-in Mod for 05/06 radios
http://www.legacygt.com/forums/showthread.php?t=18504
Turn on/off red gauge rings and/or gauge sweep
http://legacygt.com/forums/showthread.php?t=84975
Changing your Oil (not really a MOD but good thing to DIY and save money...
http://www.legacygt.com/forums/showthread.php?t=1540
Custom Badging and De-Badging
http://legacygt.com/forums/showthread.php?t=76676
Painting stock wheels
http://legacygt.com/forums/showthread.php?t=82945
DIY grilles - paint, mesh
http://legacygt.com/forums/showthread.php?t=86186
Im sure theres a bunch more feel free to contribute i will continue to update the top post here with links pics etc..
Edited by Tide
  • Replies 411
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Wouldn't it be even better to replace the cat with a straight pipe?
The expansion/contraction that the cat chamber does will cause some unnecessary turbulence that decreases power.
Other cheap fixes are to check out so that all manifolds and joints are aligned and that no gaskets intrude into the airflow. Same for exhaust pipe - check that all joints are aligned.
A K&N airfilter is also a relatively cheap modification.
And try to figure out details that actually have an impact on drag. E.g. that the hood is adjusted right to avoid unnecessary turbulence over the fenders.
Strip out any unnecessary weight is another. - Who needs carpets? :p
It's all about power to weight ratio when it comes to acceleration.
And of course - there are wonderful details to be found at the Home Depot - even if they aren't intended to be for a car.
Replacing bulbs with LED:s is another fix that can go in relatively cheap. But you may want to go for an electronics store instead of the car parts. High intensity LED:s are actually relatively cheap if you buy them at the right place. And you can place them anywhere without having to worry about heat.
jazzymt aux in mod!
got a link possibly?
Also i cant seem to find the DRL unplug walk through. know its around cause I used it the day i got my car home but didnt find it in a search yet.... Im trying to get info for all the ones I have...
Great idea. http://legacygt.com/forums/images/icons/icon14.gif
Great thread. :)
thanks, being in college for another few months ive got this car and Ive had the modding bug with my other toys for years yet I currently have no access to cash so slowly tackling these cheap or free mods is giving me my fix till I get a job this summer... And DIY saving money is always fun money in the bank or not :spin:
Does anyone know if there is a way to get the rear defrost and wiper heaters to stay on until you turn them off with out taking it to the dealer? (i.e. defeat the auto off after 15-20 minutes)
Subscribe... Awesome list!
thanks, if anybody comes across a real good walk through for gutting DP/UP let me know I would like to add that... I have read plenty of punch it out with a screwdriver and clean up with metal brush but if somebody had better walkthrough with pics possibly it would be a great addition as that is a big money saver for going Stage II
For wagon owners:
anybody remove the rear seatbelt assembly that is mounted in the headliner?
I use the wagon cargo area so much that the seat belt gets in the way too much, not sure if I need to remove the whole headliner or if there is an easier way
GREAT resource!!!! Excellent!
OK, I don't think I saw these:
^ Tail-light modification.
http://www.legacygt.com/forums/showthread.php?t=11039&highlight=short+throw
^ "DIY" short-throw shifter.
<-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges
'16 Outback, '16 WRX, 7th Subaru Family
thanks for the support, going to add them now
NP! :D I'll see if I remember anything else from long-ago, too!
