RJS5689 Posted December 5, 2008 Share Posted December 5, 2008 Exhaust silencer removal & replacement http://legacygt.com/forums/showthread.php?t=3741 That link doesnt work. I also don't remember seeing it the last time I was in this thread. Does anyone have a working link to it? Link to comment Share on other sites More sharing options...
djkxgo0k Posted December 5, 2008 Share Posted December 5, 2008 Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted December 5, 2008 Share Posted December 5, 2008 Why dont we just hook up leaf blowers to our cars. I think we would have a better time with that. Link to comment Share on other sites More sharing options...
TSiWRX Posted December 5, 2008 Share Posted December 5, 2008 If they "best-offered" that "electric supercharger" for a dollar, I'd get one, and have some fun with it. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted December 5, 2008 Share Posted December 5, 2008 50 beans isnt bad but if it were cheeper. id get it and dyno it just to see if it actually did something. And id try it on several cars. Link to comment Share on other sites More sharing options...
roosien092 Posted January 30, 2009 Share Posted January 30, 2009 link for the exhaust silencer removal still isn't working, can someone pm me directions pls? Link to comment Share on other sites More sharing options...
Guest LGT-NY Posted January 30, 2009 Share Posted January 30, 2009 What happened to the intake silencer removal thread? It says invalid thread. Link to comment Share on other sites More sharing options...
CTATV Posted January 31, 2009 Author Share Posted January 31, 2009 There were some complications (thanks jedi) and it was removed.... Ill figure something out... Link to comment Share on other sites More sharing options...
RedDawg Posted February 6, 2009 Share Posted February 6, 2009 There were some complications (thanks jedi) and it was removed.... Ill figure something out... any update on getting those installs back? Link to comment Share on other sites More sharing options...
CTATV Posted February 6, 2009 Author Share Posted February 6, 2009 Ill get it fixed up by this weekend for you guys... I was on vacation and have been busy with looking for a job but I will make a point to get it done by then... Link to comment Share on other sites More sharing options...
RedDawg Posted February 6, 2009 Share Posted February 6, 2009 Ill get it fixed up by this weekend for you guys... I was on vacation and have been busy with looking for a job but I will make a point to get it done by then... thanks Link to comment Share on other sites More sharing options...
PsycoticClown Posted February 9, 2009 Share Posted February 9, 2009 Ill get it fixed up by this weekend for you guys... I was on vacation and have been busy with looking for a job but I will make a point to get it done by then... Thanks! Link to comment Share on other sites More sharing options...
RJS5689 Posted February 9, 2009 Share Posted February 9, 2009 Ill get it fixed up by this weekend for you guys... I was on vacation and have been busy with looking for a job but I will make a point to get it done by then... Thanks, let us know when they're fixed! Link to comment Share on other sites More sharing options...
ArcTec34 Posted February 9, 2009 Share Posted February 9, 2009 link for the exhaust silencer removal still isn't working, can someone pm me directions pls? how about I just save you the trouble and tell you that it does hurt your car's performance slightly, and is just bad news Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted February 9, 2009 Share Posted February 9, 2009 Are you talking about the resonator? How does removing it hurt your cars performance? Bad news? Link to comment Share on other sites More sharing options...
Studmike Posted February 9, 2009 Share Posted February 9, 2009 thanks, this site would help me alot when i get my leggy hopefully this summer Link to comment Share on other sites More sharing options...
CTATV Posted February 9, 2009 Author Share Posted February 9, 2009 So I can tell all of you about the resonator/silencer right here, until i get a chance to make a new thread. You remove the scoop/triangle thing that takes air from the grill with the visible pop-its. then you remove the airbox from the car. I think you use the clips to open it up, and then take out the cover, followed by the other half of the airbox. dont forget to unplug the MAF sensor or to loosen the clamp on the rubber hose that goes to the airbox. then after you have it all out you will see there is a giant milk jug attached to the bottom of your airbox. remove the popit thing thats holding it on, then pull it off. Now replace airbox/filter/rubber hose, air filter and scoop in reverse order (leaving the hole in the bottom of the airbox open). I have been running my 06 Spec.B this way for 10,000 miles. it wont mess up your fuel mixture, and it wont cause you to suck massive amounts of dirt into your engine. I highly recommend throwing in and AVO panel filter while you have it all open. they are higher flow and can be cleaned multiple times for around 50 bucks... DON'T FORGET TO PLUG THE MAF SENSOR BACK IN BEFORE STARTING OR YOU WILL GET CHECK ENGINE LIGHTS UP THE YING-YANG Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted February 9, 2009 Share Posted February 9, 2009 (edited) Ive done the intake silencer delete and ive had no problems. I put AC wire mesH to keep large particals out. I just finally changed my filter and i noticed that the mesh in the center was ripped out and my filter has peices of the aluminum in it. i wonder why.. any thoughts? Edited February 9, 2009 by F-WDC Spec B Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted February 10, 2009 Share Posted February 10, 2009 You guys are confusing exhaust resonator and intake silencer. Link to comment Share on other sites More sharing options...
CTATV Posted February 10, 2009 Author Share Posted February 10, 2009 Who is? I'm not. They have been asking about the silencer for a while somebody jet called it a resonator Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted February 10, 2009 Share Posted February 10, 2009 Post 83 and 84 I believe, link for the exhaust silencer removal still isn't working, can someone pm me directions pls? What happened to the intake silencer removal thread? It says invalid thread. Link to comment Share on other sites More sharing options...
CTATV Posted February 10, 2009 Author Share Posted February 10, 2009 NY knows the difference I don't k know about the other one... Link to comment Share on other sites More sharing options...
RJS5689 Posted February 10, 2009 Share Posted February 10, 2009 how about I just save you the trouble and tell you that it does hurt your car's performance slightly, and is just bad news Hmmm how so? Can you elaborate more? Link to comment Share on other sites More sharing options...
ArcTec34 Posted February 10, 2009 Share Posted February 10, 2009 Hmmm how so? Can you elaborate more? I'm really busy with midterms, but ill look around for the link and post it later Link to comment Share on other sites More sharing options...
ArcTec34 Posted February 10, 2009 Share Posted February 10, 2009 http://legacygt.com/forums/showthread.php?t=100478&page=3&highlight=intake+resonator start at the end and work back.. Link to comment Share on other sites More sharing options...
