JaeGT Posted March 20, 2010 Share Posted March 20, 2010 I have an 08 Legacy and i just recently put in the mount. the mount will not slide all the way in. there is approximately 1cm gap for the pegs to be flush inside the cubby. Is it safe to drill holes in the further back holes to put the pegs further into? I don't really know what exactly is behind the cubby that might break if i drilled holes... Thanks! Link to comment Share on other sites More sharing options...
ryobi1 Posted April 13, 2010 Author Share Posted April 13, 2010 If the holes in your cubby are a little off, I can custom cut another to match your car. PM me, and I will figure it out. http://www.subarucubbymount.com Link to comment Share on other sites More sharing options...
Dust N bones Posted April 18, 2010 Share Posted April 18, 2010 I see, you set it up differently. What I did was basically just used the front cigarette lighter but instead of the cable dangling in front of the dashboard, I routed it through the cubby and pulled it out on from the bottom of the passenger side center console, where the side plastic meets the carpet area. Usually when the thing doesn't have to charge I just very easily tuck the cable in and under the seat. Can't tell it's there. Out of sight and clean set-up. How did you route the cable through the cubby? Did you have to pull the dash apart? I don't see any holes in the cubby where I can route the wires. Link to comment Share on other sites More sharing options...
Stiffy Posted May 14, 2010 Share Posted May 14, 2010 Holy crap! I was just trying to figure a way to put my Droid windshield mount into the cubby today! I WILL be ordering one very shortly. Link to comment Share on other sites More sharing options...
Stiffy Posted May 14, 2010 Share Posted May 14, 2010 If anyone is interested, the Verizon Droid windshield mount will NOT fit in the cubby hole. However, it has a 17mm ball end that the phone adapter plate attaches to. The OP offers a Garmin suction cup that fits in the cubby with a 17MM ball end. Link to comment Share on other sites More sharing options...
ryobi1 Posted June 2, 2010 Author Share Posted June 2, 2010 I have had quite a few inquires on different phone models. If there is on that you would like to mount, I have a few options on my site http://www.subarucubbymount.com/phone-mounts.html Link to comment Share on other sites More sharing options...
croll326 Posted June 2, 2010 Share Posted June 2, 2010 do you have anything for the APv2? Link to comment Share on other sites More sharing options...
ryobi1 Posted June 7, 2010 Author Share Posted June 7, 2010 I have a couple ideas for the APv2. Arkon makes a flat plate that attaches to the GN014 suction mount. You could then velco that to the back of the APv2. The other idea would be the universal cell phone mount. http://www.subarucubbymount.com/other-phones.html Link to comment Share on other sites More sharing options...
ktm200 Posted June 23, 2010 Share Posted June 23, 2010 Wow very clean set ups. Im in the market for a new gps unit and would like to utilize your mounting solution. Just curious what the largest gps system is that I can fit. I dont mind if it covers the clock, I'd just like it to fill as much of the void as possible. Thanks. Link to comment Share on other sites More sharing options...
mclarenf3 Posted June 24, 2010 Share Posted June 24, 2010 If it's falling outside of the cubby (like most of these do) then you can go all the way up to 7". That will perfectly cover the entire cubby area (including the clock) and should just barely cover the vent area. Link to comment Share on other sites More sharing options...
siim Posted June 27, 2010 Share Posted June 27, 2010 I've been lurking around legacygt for a while and got my idea for navi setup done couple of days ago. Navi unit is Garmin 3700 series. Basically took the entire unit apart, cut necessary holes and wrapped the leftovers with carbon fabric. Update: Did it all over, made the cubby door longer to hide navi completely, also covered vent's again with resin. Second thing changed was clock relocation bracket. http://siim.ignis.ee/auto/16.jpg http://siim.ignis.ee/auto/18.jpg Link to comment Share on other sites More sharing options...
mclarenf3 Posted June 27, 2010 Share Posted June 27, 2010 I really like the fact that you modified it in a way such that you can close the cubby door. I think I'm going to see if that's possible when I do my 5" GPS. I think lots of people who are browsing would appreciate the step by step documentation, so definitely post it if you don't mind. Job well done! Link to comment Share on other sites More sharing options...
ppettit2005 Posted June 29, 2010 Share Posted June 29, 2010 I like it! how exactly did you build this contraption? Link to comment Share on other sites More sharing options...
mclarenf3 Posted June 30, 2010 Share Posted June 30, 2010 Thanks for the documentation. I'll be sure to stay away from Carbon. Link to comment Share on other sites More sharing options...
DrSpeed Posted August 5, 2010 Share Posted August 5, 2010 do you have anything for the APv2? Check it out. (It also holds the G1 when in nav mode.) http://www.subarucubbymount.com/other-phones.html is what I used. Another satisfied customer! BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
malvic Posted August 16, 2010 Share Posted August 16, 2010 Anyone have the 'new design' with an HTC Google Nexus One car mount? Does it fit? I have to original design, but the Nexus One car mount does not fit on this design. Link to comment Share on other sites More sharing options...
ryobi1 Posted January 19, 2011 Author Share Posted January 19, 2011 I just recently made a custom mount for a guy with a Nexus One. He says that it works well. PM me if your interested www.subarucubbymount.com Link to comment Share on other sites More sharing options...
malvic Posted January 19, 2011 Share Posted January 19, 2011 Yep, that would be me. Thanks for working with me to get the design done! Link to comment Share on other sites More sharing options...
jCubed Posted January 20, 2011 Share Posted January 20, 2011 Any mounts for 2010+ Legacy??? I'd love to mount my iPad somewhere! Link to comment Share on other sites More sharing options...
ryobi1 Posted January 20, 2011 Author Share Posted January 20, 2011 If you are willing to meet up, I can take a look at what I can do. I live in Tualatin. I don't have access to a 2010-11, so it has been hard to design something. Link to comment Share on other sites More sharing options...
jCubed Posted January 20, 2011 Share Posted January 20, 2011 More then happy too! I'll PM you my email address. Thanks! Link to comment Share on other sites More sharing options...
n888aw Posted February 13, 2011 Share Posted February 13, 2011 These still for sale? Link to comment Share on other sites More sharing options...
ryobi1 Posted February 14, 2011 Author Share Posted February 14, 2011 Yeah, they are still for sale. Check out my website http://www.cubbymounts.com/ Link to comment Share on other sites More sharing options...
n888aw Posted February 15, 2011 Share Posted February 15, 2011 Hi ryobi1 - i just purchased one of your mounts. Just letting you know you have a pending order ... how fast does shipping take usually? Link to comment Share on other sites More sharing options...
ryobi1 Posted February 16, 2011 Author Share Posted February 16, 2011 I shipped yesterday. You should have received a tracking number from paypal. My guess is 2-3 days from Oregon to Colorado. Thanks for the order, Ryan Link to comment Share on other sites More sharing options...
