Sublimejoe Posted July 7, 2011 Share Posted July 7, 2011 I installed my HID's last night (before seeing this writeup) and I mounted my ballast to the battery tray (Stupid in hindsight) and it seems that it is getting so hot that it overheats the ballast and turns that headlight off. Am I correct in thinking that it is overheating? Link to comment Share on other sites More sharing options...
TheFinalSprout Posted April 14, 2012 Share Posted April 14, 2012 I have been looking to put in HIDs but i thought it would be much harder then this. a few questions 1) is the DDM kit good? 2) i dont want my lights to be too bright and distract others. would a 35w 4500 or 5000 be good? i say 5000 cause i like the pure white light. 3) is xenon expert a good website to order from? Link to comment Share on other sites More sharing options...
Mendozer Posted April 16, 2012 Share Posted April 16, 2012 I have been looking to put in HIDs but i thought it would be much harder then this. a few questions 1) is the DDM kit good? 2) i dont want my lights to be too bright and distract others. would a 35w 4500 or 5000 be good? i say 5000 cause i like the pure white light. 3) is xenon expert a good website to order from? There are 27 pages in this post that will answer all of your fine questions above take 15mins and have a read!!! However, my perspective on the DDM kit; 1) Is the kit good? That's not really a valid question. Its a less expensive kit than most and that's what you get. Is that considered "good"? I have only had one issue in the 3 years I've had it installed so I've been happy. But read through the posts and you'll see that not everyone is in the same boat as me! Regarding the color + brightness...again that's all up to YOUR tastes. I believe the 55w is "off road" spec, and in fact in some places it is very illegal to change your headlights. So whatever you choose is your choice, but look at your local regulations. Furthermore, if you align your lights properly, it should not distract others. As for the color, its all up to your tastes...lots of sample pictures on this thread (the Xenon site) to look through. Each and everyone opinion will be different! Lastly, I have had to deal with Xenon expert only twice (initial order and warranty a burnt out light) and in both situations, he/she was excellent in getting me the product / resolving my issue. If you don't go via the web-site, where do you plan on ordering it from / through. Have fun with your research I'm sure you'll be satisfied with your outcome. Just my 2c Link to comment Share on other sites More sharing options...
TheFinalSprout Posted April 17, 2012 Share Posted April 17, 2012 Thanks for the input. They are On there way can't wait to get them and put them in. I ended up going with the 5000k. Link to comment Share on other sites More sharing options...
JPU1 Posted May 12, 2012 Share Posted May 12, 2012 I just installed TRS 35w 5000K HIDs, I immediately adjusted my lights down considerably. I feel like I need to go down more... I drove around for about 1 hour and didn't get any flashes from other drivers. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted May 12, 2012 Share Posted May 12, 2012 do the aiming guide in the external section that is sticky'd then you'll be within DOT spec. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
OutdoorOBW Posted May 21, 2012 Share Posted May 21, 2012 Got my TRS 35w 4300k H7 kit in the mail today. I'm installing them this evening and see people talking about rotating the bulb to put the return wire in a certain spot. Should it be in the 6 o'clock or 12 o'clock position? I know I don't want it in the 7 o'clock spot. Link to comment Share on other sites More sharing options...
JPU1 Posted May 22, 2012 Share Posted May 22, 2012 do the aiming guide in the external section that is sticky'd then you'll be within DOT spec. Lowered the beams significantly (8" @ 25 feet). Need to check against a different wall... May have been on a slight slope, they are awfully low now. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted May 22, 2012 Share Posted May 22, 2012 Another way to tell if you are within spec is just by driving around naturally. Look at the cutoff and where it is at on the cars in front of you as you drive around. You can also look at where it is on the sides like if you are driving next to a wall if the slope is going up on the driver side then its to high. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
JPU1 Posted May 23, 2012 Share Posted May 23, 2012 Mine are currently sloping down and barely hitting the bumper of the car ahead of me... But it's raining like stink so I'll adjust them tomorrow... Link to comment Share on other sites More sharing options...
titoedge Posted December 5, 2012 Share Posted December 5, 2012 thanks for this thorough WALK Thru. i have read and re-read this a few times, and finally installed mine ...after owning them for over a year (in box in garage ;-( this worked perfectly. i went with 35w, 6000k one question, and i've read the entire thread (some mention that HID in a high beam is not a good idea, yet i see you can still buy the high beam sizes. What are folks doing for their highbeams? The HID lows are so strong, you can barely see anything when i flick the high beams. i see that the 9005 is offered in a HID package, but not sure if that's a good idea or not. love to hear folks thoughts, thanks for your time again Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 5, 2012 Share Posted December 5, 2012 NO you don't want them in the high beams because they require an ignition time which is not what you would want for flash to pass/quick light. Get some HIR bulbs for the highs. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
titoedge Posted December 5, 2012 Share Posted December 5, 2012 thanks MiniStiGuy! i noticed the warmup, and figured that couldnt be good for flashing high beams, glad i asked here. strange that the high beam bulb is available, guess it may be used in other vehicles as the low beams Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 5, 2012 Share Posted December 5, 2012 they make HID kit bulbs in every type of bulb made now and days. Does it mean it should be used in certain situations? No, but there are plenty of people out there that buy them and try still. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
kevinc08 Posted February 11, 2013 Share Posted February 11, 2013 my next mod, thanks! Link to comment Share on other sites More sharing options...
ej25_TS Posted May 23, 2013 Share Posted May 23, 2013 This is probably somewhere in here but there is a pink and white wire for the bulb. Pink negative? white positive? Link to comment Share on other sites More sharing options...
06GRPLGT Posted May 23, 2013 Share Posted May 23, 2013 This is with the HID bulb in place and both spades connected. The red wire goes to factory pink, and black goes to black. What looks like it used to be a black wire on the factory plug is washed out by a white powder, making it look greyish. This is probably powderized rubber from the wire jacket being exposed to the heat. Note: apparently some kits have black and blue wires, so put blue to suby pink and black still goes to black. http://i180.photobucket.com/albums/x312/kagenmateer/bulbinplacewiresconnected.jpg Link to comment Share on other sites More sharing options...
ej25_TS Posted May 24, 2013 Share Posted May 24, 2013 I have pink and white wire not pink and black? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted May 24, 2013 Share Posted May 24, 2013 ping = red white=black OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
duhst Posted July 6, 2013 Share Posted July 6, 2013 Does anyone know if this will work for 2010? Or if there will be any bulb out errors? Link to comment Share on other sites More sharing options...
MoD_Scotty Posted November 23, 2013 Share Posted November 23, 2013 Just did this on my 05. I went with a 55W 5000K kit (I've been running an identical kit on another car for over a year now, and it's been great). I might need to adjust the headlights a tad, but otherwise, the install was cake. I just used 3M Super Strength Molding tape to mount the ballasts, and they are definitely not going anywhere! Shoulda done this mod months ago! Link to comment Share on other sites More sharing options...
dirtjumper787 Posted October 10, 2017 Share Posted October 10, 2017 Is there any way OP could update pictures to this site? I tried using the post on the front page, and also going to photobucket and typing in the username of OP and photobucket has made their website practically unusable due to all the ads popping up everywhere. Thanks in advance. Link to comment Share on other sites More sharing options...
SBT Posted October 10, 2017 Share Posted October 10, 2017 OP has not been on the site since 2010. Won't be coming back. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
dirtjumper787 Posted October 11, 2017 Share Posted October 11, 2017 OP has not been on the site since 2010. Won't be coming back. I see "banned" now, sorry to bump old post Link to comment Share on other sites More sharing options...
turboboost Posted October 11, 2017 Share Posted October 11, 2017 @dirtjumper -- what specific question do you have regarding the HID install? I'm assuming you're going for a the simpler plug-and-play (PnP) set-up vs a retrofit. It's fairly straightforward, and you wouldn't even need to remove your front bumper, unless you're very particular about where you want to mount your ballasts. Link to comment Share on other sites More sharing options...
