SBT Posted September 26, 2009 Share Posted September 26, 2009 Where does one get industrial strength velcro in differing sizes (length and width)? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
MiniStiGuy Posted September 26, 2009 Share Posted September 26, 2009 I'd try fabric stores and or boating supply store. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
addicted4life Posted October 20, 2009 Share Posted October 20, 2009 Just ordered a 5k set. Now that winter is here I seem to be driving at night more than during the day. Plus I'm sick of replacing Silverstars every few months. Edit: oops double post in wrong thread Link to comment Share on other sites More sharing options...
BIGWZ Posted October 29, 2009 Share Posted October 29, 2009 got mine in today! Great walkthrough helped out a lot!! Thanks!! One question though, I did mine first before unplugging the DRL's, after I installed everyhing, turn the car on, lights come on normal, but then they won't come on as DRL's, and will only come on if the handbrake is up (ie DRL deactivated) when handrake is down they won't turn on.. I unplegged DRL's and problem solved they go on when I want them to... I still can't figure out why they were acting like that! Link to comment Share on other sites More sharing options...
Timex Posted April 10, 2010 Share Posted April 10, 2010 I hate to bring back an old thread, but I was searching for help with changing an HID bulb. The car came with an HID kit and I have managed to acquire the right replacement bulb for the driver side headlight. I removed the battery and disconnected all the wires of the burnt bulb, but encountered one wire, a black one, that seems to extend from the set of wires that connects to the balast. This one wire seemed to be a long one that ran down my bumper to some area that wasn't visible. Aside from that one wire, my replacement bulb looks the same with all the same harnesses. Any ideas on what this is and what to do? Also, my ballast seems to be just hanging, dangling more like it, near the base of the bumper. It was actually quite hard to get to. Thanks. Link to comment Share on other sites More sharing options...
jus2phast4uLGT Posted September 7, 2010 Share Posted September 7, 2010 nice write up Link to comment Share on other sites More sharing options...
dmp Posted September 8, 2010 Share Posted September 8, 2010 One year later and my HIDs are easily the best mod I've done, dollar for dollar....next to the brakes...and the VF52...but...still...I love them. SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds. Link to comment Share on other sites More sharing options...
tyrel.boyce Posted September 26, 2010 Share Posted September 26, 2010 I need help i plugged my hids in and one works and the other one just flickers? i have everything hooked together right and one of the drive lights isnt working now can anyone help me with this??? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted September 26, 2010 Share Posted September 26, 2010 check over all the harness connections again. Make sure the wiring is in firmly. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
ej25_TS Posted October 15, 2010 Share Posted October 15, 2010 Great write up. Recommended place to get HIDs for my 06 Leggy. Link to comment Share on other sites More sharing options...
GTS Jeff Posted October 24, 2010 Share Posted October 24, 2010 I finally got around to installing my DDM kit. 55W, 5000K, battery relayed. Thanks for the great write up and photos. So far, everything works exactly like it's supposed to. As expected, the glare through the squirrel finders is ridiculous, but at this point I'm not horribly motivated to remove the headlamp assemblies to fill them. It's not dark out yet, but I can't wait to go for a cruise tonight to see how it looks! Did I mention I did this install outside in the pouring rain the whole time? Unfortunately, the light drizzle turned into a heavy downpour just as I fitted the bulbs in and I was at the point of no return. I had to secure the wiring and tape the ballasts down while getting drenched at the same time. Hopefully the tape holds. Link to comment Share on other sites More sharing options...
GTS Jeff Posted October 25, 2010 Share Posted October 25, 2010 Just drove around as it's dark now. Since everything is wet I can't really appreciate the brightness of the HIDs. The squirrel finders are basically as bright my HIR high beams. Not too happy about that... Link to comment Share on other sites More sharing options...
MiniStiGuy Posted November 18, 2010 Share Posted November 18, 2010 Always use Protection... OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
CB-M3 Posted November 23, 2010 Share Posted November 23, 2010 I just got done installing the DDM kit. see how long these last. install took about 1.5 hrs. did you guys have to aim the headlights after the install? Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 23, 2010 Share Posted November 23, 2010 Did you remove the assembly from the car? '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
CB-M3 Posted November 23, 2010 Share Posted November 23, 2010 Did you remove the assembly from the car? no, only thing i removed was the stock bulb to replace with the HID bulb. Link to comment Share on other sites More sharing options...
bomberlegacy Posted November 23, 2010 Share Posted November 23, 2010 Thats how I did it, along with filling the squirrel finder hole, and I haven't noticed any alignment issues. everything seems normal. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
MiniStiGuy Posted November 23, 2010 Share Posted November 23, 2010 I always suggest you aim them because they aren't always aligned to DOT standards from the factory. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
CB-M3 Posted November 23, 2010 Share Posted November 23, 2010 I always suggest you aim them because they aren't always aligned to DOT standards from the factory. Thanks. I did see your thread on properly aiming the headlights. I will attempt to check it this weekend. Link to comment Share on other sites More sharing options...
ObiWanToby Posted December 27, 2010 Share Posted December 27, 2010 Using a kit, such as the DDM kit, with good aim and stock projectors, people are obtaining results where glare isn't too much of a problem for oncoming drivers? Perhaps there is some bending of a squirrel spotter? I am fine with the stock beam pattern, but I really do not want to blind others or attract unwanted attention from authorities. Link to comment Share on other sites More sharing options...
GTS Jeff Posted December 28, 2010 Share Posted December 28, 2010 Glare was terrible before folding in the squirrel finders. Once the squirrel finders gone, glare is lessened. With the DDM kit, I'd recommend rotating the bulbs to get rid of the return wire shadow too. Link to comment Share on other sites More sharing options...
adhdrockstar Posted May 20, 2011 Share Posted May 20, 2011 Subscribed -Urban Cowboy Link to comment Share on other sites More sharing options...
smashcrunk Posted May 29, 2011 Share Posted May 29, 2011 this write up is super helpful. Thanks for the time to put it up! Link to comment Share on other sites More sharing options...
ej25_TS Posted June 22, 2011 Share Posted June 22, 2011 did this last week. Great write up. I decided to check the alignment after and at stock it was way low going by the alignment write up anyone else have to adjust it up that much? I talking like a foot up from the 25ft away rule. Part of me feel like I'm blinding people now? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted June 25, 2011 Share Posted June 25, 2011 If you did the alignment correctly on "flat" ground then you are fine. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
