Unofficial Seat Temps
After thinking that my heated seats were flaky -- I tested them.
BTW they did work OK...
Here's what I got with engine running at 1400 rpm and a 5 minute stabilizing wait between temp sets.
Low position 1 --- 89.6 degrees
position 2 --- 95.4 degrees
position 3 --- 99.6 degrees
High position 4 --- 102.7 degrees
There you have it.:p
Man......I just simply cannot handle anything higher than the lowest setting. Having a sweaty hizass is not a good feeling;)
Swamp Crotch!!!!! :eek:
That is the first thing my buddy said when I got the car... Ah you have swamp crotchers! :rolleyes:
OK, I also want to know if the different stages heat up the seat on different parts of the seats.
I swear the back rest heats up on stage 4.
I know the lumbar area also heats up at the same time as the arss part. But I couldn't sit still enough to check that area.:cool:
I have a feeling the northern climate people are used to high settings and lower warmer climate people think having them at all is useless. Being in chicago I use all the settings. When its -30 with the wind chill you better believe the setting is on fry mode. But once it gets over 50 I don't use it at all. Most of the winter its on 2.
