Turbo (un)install HOWTO with pics
At this time, I lossened the lugnuts and jacked up the car. Never trust a jack to hold the car in place, ALWAYS user stands. And for good measure, make sure the car doesn't roll anywhere.
http://img.photobucket.com/albums/v334/wcbjr/DSC00433.jpg
http://img.photobucket.com/albums/v334/wcbjr/DSC00434.jpg
I forgot what I was supposed to remember.
  • Replies 142
  • Created
  • Last Reply
Top Posters In This Topic
Now you'll be looking at something like this.
http://img.photobucket.com/albums/v334/wcbjr/DSC00435.jpg
I wasn't particularly happy to see what the swaybar bushing looked like, but oh well.
http://img.photobucket.com/albums/v334/wcbjr/DSC00436.jpg
Note: Messing with the O2 sensor in the next two posts do not have anything to do with removing a turbo. But I am going a bit further and removing the uppipe as well. Bonus!
Remove the fastener here, slide the cover down and you'll be staring at an oxygen sensor.
http://img.photobucket.com/albums/v334/wcbjr/DSC00435_2.jpg
http://img.photobucket.com/albums/v334/wcbjr/DSC00437.jpg
Up top in the engine bay, locate the O2 sensor wire and unplug it. You'll also have to remove/undo a couple clips that are attached to it.
Snake the O2 sensor wire down to the actual sensor.
http://img.photobucket.com/albums/v334/wcbjr/DSC00439.jpg
Okay, now climb under the car and get underneath the turbo and downpipe. You might have been able to reach this nut/bolt from up top, but if not remove it so the downpipe is no longer fastened to the turbo.
http://img.photobucket.com/albums/v334/wcbjr/DSC00446.jpg
Now go down to the other end of the downpipe and remove the two bolts that connect it to the midpipe. Remember the gasket.
http://img.photobucket.com/albums/v334/wcbjr/DSC00447.jpg
Pull the downpipe off and you'll be looking at something like this. Three things to note. First, the gasket still no the turbo, don't want to forget about that. Second, the bolt I have in the uppipe. That is where the stock EGT probe would be. And third, there is a better look at the lower coolant hose clamp we couldn't see before.
http://img.photobucket.com/albums/v334/wcbjr/DSC00450.jpg
Things got a bit sketchy here with my pics. I was in a rush to get out of the rain.
We need to get back up top in the engine bay. There are three nuts/bolts to be removed to loosen the turbo from the uppipe. The arrow points to the third not shown in the picture.
http://img.photobucket.com/albums/v334/wcbjr/DSC00451.jpg
In front of the turbo, there are a couple things we have to disconnect. The intake and a wastegate hose.
The intake hose can be loosened here.
http://img.photobucket.com/albums/v334/wcbjr/DSC00452.jpg
You can't see it here, but there is a T in the wastegate hose a few inches from the arrow. Disconnect that.
http://img.photobucket.com/albums/v334/wcbjr/DSC00453.jpg
Two things left. Jumping ahead in the pic sequence, reach down under the turbo and slide down the clamp that holds the lower oil hose on. It's easy, it's on the pipe shown here.
http://img.photobucket.com/albums/v334/wcbjr/DSC00461-1.jpg
Now remember that line we disconnected up top? Bend that thing out of the way a bit, but only enough to pull out the turbo. I hate this part because I always hear of people breaking it. I save this part for the end.
http://img.photobucket.com/albums/v334/wcbjr/DSC00432_5.jpg
At this point the turbo should be removed. I don't have a good pic of the result, unfortunately.
Now onto the uppipe... and this gets real sketchy in the pic department.
From the top of the car, remove the two nuts holding the uppipe supports. The pic shows them from below, but get them from the top. Also, if you have an EGT sensor, remove that from the uppipe as well.
http://img.photobucket.com/albums/v334/wcbjr/DSC00450_2.jpg
Why disconnect the 02 if you aren’t pulling the uppipe?
You should also remove the under tray sooner and drain the coolant.
Did you read any of the text, or just look at the pics? ;)
I remove the oil supply line from the flare joint so that you do not have to bend it.
Nice pics :)
Yeah, I know I should do that. Part of me wants it to break so I can install a braided line. :D
Back under the car, in front, we need to get access to the bottom two uppipe bolts. But the bolts are not accessible due to an exhaust manifold heat shield being in the way. So let's remove it.
Stupid undertray, let's move that a bit. Remove the fasteners located here.
http://img.photobucket.com/albums/v334/wcbjr/DSC00443.jpg
There are four bolts holding the heat shield on. Here are two of the bolts, the other two are on the other side of the heat shield.
http://img.photobucket.com/albums/v334/wcbjr/DSC00442.jpg
http://img.photobucket.com/albums/v334/wcbjr/DSC00444.jpg
Thats what Im getting at why remove the uppipe? If its not leaking dont mess with it :icon_wink
Maybe I can rename the thread 'How to (un)install the intercooler, downpipe, turbo and uppipe with pics'...
I believe the uppipe bolts can be removed without taking the O2 sensor out, but if you want to take it out, here's a way how. IIRC, that is a 22mm wrench.
http://img.photobucket.com/albums/v334/wcbjr/DSC00438.jpg
http://img.photobucket.com/albums/v334/wcbjr/DSC00440.jpg
http://img.photobucket.com/albums/v334/wcbjr/DSC00445.jpg
Now remove the two uppipe bolts, lift the uppipe out from the top and you will truly be left with this. Remember the uppipe's lower gasket.
http://img.photobucket.com/albums/v334/wcbjr/DSC00445_2.jpg
http://img.photobucket.com/albums/v334/wcbjr/DSC00461_2.jpg
But wait, you mean to say that the uppipe will not come out from the top or bottom? :)
I don't have pics of this, but, remove the nut(s) from the passenger side motor mount and jack the engine up a bit on that side. The uppipe will slide right out.
