CrakuhBlack Posted December 7, 2006 Share Posted December 7, 2006 Went to the track over the weekend and did two runs up to 90/100 mph with another member of this board. The point was to compare our cars in a safe environment and see what if any difference the modifications we've made affect performance. (and to race before I go stage II). We raced two times in sport mode to eliminate potential driver error. The cars' specs and race results are as follows: Car 1 (Me) is TDC stage I tuned and has megan racing coilovers. Car 2 has a perrin pulley, sti UP, shorty DP, a TDC stage II tune, and stock suspension. Both cars have roughly the same milege, same tires, drivers weigh exactly the same, both cars have sway bars. Essentially everything is equal except what is noted above. Run 1: Car 2 has a 210 pound fat-a$$ passenger in it AAAND gives up the launch to me. I win with the nose of his car next to my rear quarter panel. I am starting to pull harder as we reach and pass 90/100. Run 2: Car 2 loses the extra baggage and we launch exactly at the same time. He ends up winning with the nose of my car at about the middle of his front door and is pulling ever so slightly at 90/100mph. So what are your thoughts? I personally thought that Car 2 was going to pull on me much more than it did. I can only come up with 2 explanations: 1. The combination of UP, DP, and stage II map do virtually nothing more than use up more gas and empty your wallet or 2. The superior suspension of Car 1 allowed it to get more power to the ground and kept it in the race despite the power advantage of Car 2. Is there something I'm missing here? Maybe neither of these explanations make sense and Car 2 was a mechanical F-up from the factory. Opinions and thoughts welcome... Link to comment Share on other sites More sharing options...
mwiener2 Posted December 7, 2006 Share Posted December 7, 2006 maybe car2 driver sucks? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
hutru01 Posted December 7, 2006 Share Posted December 7, 2006 maybe car2 driver sucks? That would be my guess because the dyno charts prove that Stage 2 owns Stage 1 Link to comment Share on other sites More sharing options...
dtmenace Posted December 7, 2006 Share Posted December 7, 2006 ... or 2. The superior suspension of Car 1 allowed it to get more power to the ground and kept it in the race despite the power advantage of Car 2.... this is possible and very likely given your tested results. But in the end I defer to someone with more knowledge about the subject. They should be along shortly...as I am officially BUMPING this thread... Link to comment Share on other sites More sharing options...
HansGT Posted December 7, 2006 Share Posted December 7, 2006 both have stock rubber? the suspension, is going to make a difference...look at the '06 spec b 0-60/ 1/4 mile numbers vs. a stock gt. Link to comment Share on other sites More sharing options...
psucaptainkickass Posted December 7, 2006 Share Posted December 7, 2006 I have progressed through the stages, 0, 1, 2, TDC 2 and I can say that each stage has given me a kick in the ass at first (until I got used to it), so I can say that something is improving. My gauge for this is the amount of time I have to shift from 1 to 2 to 3. After getting used to the car stock, stg 1 made me feel like a frantic wreck to get into the next gear before hitting red line. After getting used to that, the next stage did the same thing. And yes, the TDC 2 map made me feel the same over the Cobb Stg. 2 map, so I knew that the TDC map wasn't snake oil I think a better way for you to determine the benefit of Stage 2 on your car is to time it the way it is...go stage 2, and time it again. Although all our cars are made at the same place doesn't mean they are equal. Link to comment Share on other sites More sharing options...
Spec B Posted December 7, 2006 Share Posted December 7, 2006 How heavy is the driver of car 2... like 400lbs? Link to comment Share on other sites More sharing options...
dtmenace Posted December 7, 2006 Share Posted December 7, 2006 How heavy is the driver of car 2... like 400lbs? ... drivers weigh exactly the same... Link to comment Share on other sites More sharing options...
CrakuhBlack Posted December 7, 2006 Author Share Posted December 7, 2006 Thanks for the replies. To answer some of the questions: The driver of Car 2 may very well suck (haha, jk man). No, we just put the car in sport (auto) mode and punched the gas. In other words, there was really no skill involved. Both cars do have stock rubber. Both drivers weigh exactly 190.5 lbs...so no, hes not 400. There is one other thing I forgot about. It is possible that Car 2 has an exhaust leak. I don't think that this alone could account for the result of the races, but I thought I'd throw it out there... Link to comment Share on other sites More sharing options...
AWDxBOOST Posted December 7, 2006 Share Posted December 7, 2006 stage 2 > stage 1 drivers being equal... i ran a 14.0 stage 1, and a 13.2 stage 2...and gained 7mph you tell me what you think Link to comment Share on other sites More sharing options...
CrakuhBlack Posted December 7, 2006 Author Share Posted December 7, 2006 I think a better way for you to determine the benefit of Stage 2 on your car is to time it the way it is...go stage 2, and time it again. Although all our cars are made at the same place doesn't mean they are equal. Yea, thats the main point. I'm not so sure I want to go stage II now. I'm seriously considering selling my un-installed pipes and staying stage I. Link to comment Share on other sites More sharing options...
Underdog Posted December 7, 2006 Share Posted December 7, 2006 ^ Why quit the race now? In my opinion you have the right idea, upgrading suspension and powertrain together... what a concept! Actually, I think the suspension should be the first thing modified on these cars because even at stock power the suspension can't keep up. Throw the pipes on, get TDC stage 2 and re-test... <---anxiously waiting for results... The Crimson Dynamo Link to comment Share on other sites More sharing options...
Spec B Posted December 7, 2006 Share Posted December 7, 2006 stage 2 > stage 1 drivers being equal... i ran a 14.0 stage 1, and a 13.2 stage 2...and gained 7mph you tell me what you think Nice....thats a big difference. Link to comment Share on other sites More sharing options...
psucaptainkickass Posted December 7, 2006 Share Posted December 7, 2006 +1, I did have iONs put on when going stg 2. The car bucked too much at stg. 1, and the springs greatly eliminated that. It has come back a bit with TDC 2, which gave me another indication that it was kicking ass. Link to comment Share on other sites More sharing options...
CrakuhBlack Posted December 7, 2006 Author Share Posted December 7, 2006 +1, I did have iONs put on when going stg 2. The car bucked too much at stg. 1, and the springs greatly eliminated that. It has come back a bit with TDC 2, which gave me another indication that it was kicking ass. Right, so do you guys think that the car squatting so much can slow down the acceleration? I'm not really sure how the AWD system works, but is it possible the car is reducing power to the front wheels under hard acceleration on Car 2? Link to comment Share on other sites More sharing options...
psucaptainkickass Posted December 7, 2006 Share Posted December 7, 2006 Yeah...I tried looking for it, maybe someone else has the link, but there is a pic here of a Silver LGT owner launching at the track, and his front end is WAY up in the air. I know the owner commented on his setup, but I can't remember if it was stock or not. It had to be judging by how high his front end was in the air. I don't know if it is a factor of the car reducing power to the wheels, I think it is more of a factor of the weight transfer of the car during launch that slows it down. Like if your front end tips way up, all that weight is getting thrown back....then when it comes down, all that weight is coming down in the opposite direction. I can't imagine that being good for drag times. Link to comment Share on other sites More sharing options...
CrakuhBlack Posted December 7, 2006 Author Share Posted December 7, 2006 ^^good point. Link to comment Share on other sites More sharing options...
mwiener2 Posted December 7, 2006 Share Posted December 7, 2006 how much gas in each car? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
melayout Posted December 7, 2006 Share Posted December 7, 2006 You do not stomp with a 5EAT, you tip-in. I keed I keeed Link to comment Share on other sites More sharing options...
CrakuhBlack Posted December 7, 2006 Author Share Posted December 7, 2006 Car one actually had more gas...maybe up to a quarter of a tank. That would make the results even more strange. what are you talking about melayout...im not following. Link to comment Share on other sites More sharing options...
Waxiboy Posted December 7, 2006 Share Posted December 7, 2006 no one has mentioned this yet but... 1. What is the tire pressure on both cars? 2. How much fuel was in the car at the time of the run? Link to comment Share on other sites More sharing options...
mwiener2 Posted December 7, 2006 Share Posted December 7, 2006 one car was going downhill My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
melayout Posted December 7, 2006 Share Posted December 7, 2006 Car one actually had more gas...maybe up to a quarter of a tank. That would make the results even more strange. what are you talking about melayout...im not following. No, we just put the car in sport (auto) mode and punched the gas. In other words, there was really no skill involved. You roll-in on the gas. Punching it will be slower. I keed I keeed Link to comment Share on other sites More sharing options...
CrakuhBlack Posted December 7, 2006 Author Share Posted December 7, 2006 maybe you can elaborate? Link to comment Share on other sites More sharing options...
CrakuhBlack Posted December 7, 2006 Author Share Posted December 7, 2006 Ok, its been said twice now, but WHY?!?!?! Link to comment Share on other sites More sharing options...
