Growling/Clunking noise in rear while accelerating hard in 1st or 2nd ??
Mine does this on ocassion but I think it is due to load...at least for me. If I accelerate fairly hard with just me and the wife no noise, but if I do the same with two more people in the car I get the growling noise.
Welcome to the club! Grab your name badge in the next table. :p
What mods does the wagon have?
  • Replies 964
  • Created
  • Last Reply
Top Posters In This Topic
After 3 months with the filled bushings the results are pretty good. I had no growl down to 30 degrees or so. But after some consistant 20 degree days of leaving my car outside at work the growl has returned somewhat. Maybe 25% back, nowhere near as loud as it used to be.
Sean, How about a poly bushing kit for the entire rear suspension? I'd buy it.
I'm close to buying a block of Delrin and have a local machine shop replace every bushing I can unbolt and take to them. lateral links, lower diff crossmember, and trailing arms.
I met with my product manager Rob Arnold. We are going to look at the diff bushings for inserts. We will address the entire rear end and the driveline. I will let you know what solutions our product team comes up with. We are meeting next Friday. I'll post up next week.
Sean S.
http://i175.photobucket.com/albums/w151/RalliTEK/Ad_banner02_700.jpg
Right now I just have an AP...but I am looking to go Stage 2 in the spring. But I said that last year too. :lol: But at least now I have the parts minus the gaskets so I am closer.
In case these are useful:
http://i150.photobucket.com/albums/s108/wujek1976/diff.jpg
http://i150.photobucket.com/albums/s108/wujek1976/subframe.jpg
That is why I suggested an insert like the ones in the 5EAT tranny mount. Would be as simple as unbolting the nut, inserting bushing, and torquing down the nut. Repeat on second bushing. Done!
May not be that simple. When I tried to take off the nuts, the whole stud ended up unscrewing out of the diff. I was still able to get it out, but a bit of a pain
Just throwing something new on the table for you guys.
I'll assume the 2004+ is for JDM years.
2004~Legacy Diff. Mount Support Bar
http://www.machiii.net/suspension/beatrush/subaru.htm
http://www.machiii.net/images/suspension/beatrush/Subaru/36.jpg
Btw, I just found out that on JDM SpecB (and presumably GT) the piece is aluminum, not steel.
Vimy and his SpecB - you got shafted ;)
Is it for sure that that piece fits our cars? The piece in the pic above.
I tried to loosen the hoizontal bolts with a breaker bar and couldn't get them to budge. I used a 3 foot extension, no luck.
I think I will have to have it up on a hoist to get them loose.
I think the picture shows an Impreza (notice single exhaust). So, yeah, possibly the pictured part won't fit Legacy.
Legacy of course has that part, but might have different dimensions.
Just waiting now for whatever Sean tells us from the meeting!
When I meet with the other engineers on our product development team, we will addrss the issue as a whole. We have each read through the thread, and I will post the results of our meeting ASAP.
One question. You guys are sure it is not the rear sway bar touching aftermarket exhaust? Someone has factory exhaust, and factory rear sway bar, that has this noise. Correct?
Thx,
Sean S.
www.RalliTEK.com
http://i175.photobucket.com/albums/w151/RalliTEK/Ad_banner_GCSP01.jpg
I, too, Sean, am running stock struts, stock sways, and stock exhaust with H-techs... and I get the noise.
It isn't any aftermarket issue.... other than the car is lowered.... and making more power (Stg. 2.5)
At this point I don't think its a power level thing other than the weakening of bushings over time. I can produce this noise at near no throttle taking a right hander sharply from a stop and I've already filled the rear mounts and done the rallitek race trans mount.
I think its a combination of mounts but here is a wierd finding. We all know that it lightens up as the car warms and get more miles per drive cycle. Well, since the temps dropped I notice that the noise is Much worse when I don't use the blok heater overnight. When I use the block heater the noise isn't as bad in the AM. I've done this little experiment numerous times. I'm guessing some of the bushing in the front are also aiding in the noise. Filling the rears and doing the trans mount definately helped but I think the motor mounts would halp some too. How hard is it to do the lowers with the engine in the car?
