turbodave Posted September 30, 2006 Share Posted September 30, 2006 The understeer and tyre squeeling on sharp corners is now starting to annoy me. My focus wagon can take the same corner at the same speed - and (dare i say it) actually feels like it could out-corner the legacy; assuming it had another 100+ hp to actually accelerate out of the corner LOL! In hindsight - it makes sense. It's not designed as a track car, but a brisk comfortable cruiser, and understeer is a nice safe place for the average driver... But - I really would like to make some changes. I am very satisifed with the stock spring rates and ride height; especially with where I venture in Michigan over the winter. The shocks feel potentially like they could be firmed up - but overall I want to keep the ride quality as it is. So I'm down to Sway bars right? Do i really need both front and rears given i just want to slightly change the characteristics of the suspension to eliminate this 'safe' understeer? I'm also looking for opinions on the end-links; I occasionally take it to the track - but I'm certainly not beating on it round every corner. Will the factory ones be upto the job? Many thanks for any advice... Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2006 Share Posted September 30, 2006 Get JDM GT Bilsteins and sway bars. Probably somehting like set of Cusco bars. I have Bilsteins and JDM GT rsb. IMHO the bar is not enough for Bilsteins but was enough for stock suspension. I'll be buying a set of bars soon, most likely Cusco, perhaps Cobb, perhaps Whiteline. Can't decide yet. I really suggest that you get rid of stock dampers. But if you want to keep them then JDM GT rsb makes a very noticeable difference. Also, if you run stock tires - GET RID OF THEM ASAP. That's the first mod to do. Link to comment Share on other sites More sharing options...
turbodave Posted September 30, 2006 Author Share Posted September 30, 2006 Cheers, Vehicle is box-stock btw... I can guess someone was going to mention the Factory tyres - but surely changing those would just give the same handling, but at a slightly higher speed? I get the impression the JDM GT rear sway-bar on its own could give me the result I'm after? Link to comment Share on other sites More sharing options...
SC GT Posted September 30, 2006 Share Posted September 30, 2006 JDM RSB would be a good, cheap start. Also, full JDM GT or Spec B takeoffs should work for you. Keeps stock height, but improves handling dramatically. Link to comment Share on other sites More sharing options...
turbodave Posted September 30, 2006 Author Share Posted September 30, 2006 That sounds good Where is the Best place to source the JDM GT rear sway bar? Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2006 Share Posted September 30, 2006 That sounds good Where is the Best place to source the JDM GT rear sway bar? avoturboworld.com. Yesterday I posted link for a used one for $100 shipped. New is $190 shipped. Link to comment Share on other sites More sharing options...
turbodave Posted September 30, 2006 Author Share Posted September 30, 2006 This one? http://www.avoturboworld.com/avoshop/product_info.php?products_id=389 I don't see any reference to it being a JDM one though - or am i missing something Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2006 Share Posted September 30, 2006 20mm rsb = JDM GT There was also 19mm rsb on some JDM SpecB cars. Link to comment Share on other sites More sharing options...
turbodave Posted September 30, 2006 Author Share Posted September 30, 2006 Thanks Mat, Off to order it Edit - Damn: "Products marked with *** dont exist in desired quantity in our stock." I'll drop them a line and enquire Link to comment Share on other sites More sharing options...
eHoward Posted September 30, 2006 Share Posted September 30, 2006 Tires are the single most important part of "handling" Cheers, Vehicle is box-stock btw... I can guess someone was going to mention the Factory tyres - but surely changing those would just give the same handling, but at a slightly higher speed? Link to comment Share on other sites More sharing options...
whitetiger Posted September 30, 2006 Share Posted September 30, 2006 Get tires first. Link to comment Share on other sites More sharing options...
melayout Posted September 30, 2006 Share Posted September 30, 2006 TIRES first. I keed I keeed Link to comment Share on other sites More sharing options...
Th3Franz Posted October 1, 2006 Share Posted October 1, 2006 Tires first. Then sways. Then more if you desire (springs and struts or coilover) -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
panamajack Posted October 1, 2006 Share Posted October 1, 2006 Tires are the single most important part of "handling" yip Link to comment Share on other sites More sharing options...
dark_templer_102 Posted October 1, 2006 Share Posted October 1, 2006 The RE92s are great for "normal" driving, but getting new tires seems to make the most different for aggressive driving. Link to comment Share on other sites More sharing options...
Guest Posted October 1, 2006 Share Posted October 1, 2006 The RE92s are great for "normal" driving, but getting new tires seems to make the most different for aggressive driving. No, they are NOT great for normal driving. RE92s are downright dangerous in wet (hydroplane pretty badly) and don't stop the car quite well... Link to comment Share on other sites More sharing options...
wukindada Posted October 1, 2006 Share Posted October 1, 2006 Def tires & sways......the car transforms with those 2 items;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
cantona156 Posted October 1, 2006 Share Posted October 1, 2006 Focus is one of the best handling family hatch I have ever driven. And it rides very well, no harsh ride. Pity the poor engine power. Link to comment Share on other sites More sharing options...
Garandman Posted October 1, 2006 Share Posted October 1, 2006 G/// Also, if you run stock tires - GET RID OF THEM ASAP. That's the first mod to do. I was one of those who didn't want to blame the OEM Potenzas - "A poor workman blames his tools." But I put the Potenzas on a minivan and Goodyear F1 GS D3's on my OBW. All I can say is WOW! Replace the tires before you spend a dime on other mods. Focus wagon is lighter so they turn in well, and they have plenty of suspension travel, but your cornering limits should be higher, after all. Who Dares Wins スバル Link to comment Share on other sites More sharing options...
ronemus Posted October 2, 2006 Share Posted October 2, 2006 I was disappointed with my '02 LGT once I drove it a while, but upgrades have transformed it: Centerforece DFX clutch (LGT clutch is ~$180 more than '01 Impreza turbo for the same parts) is lighter with smoother takeup, KYB GR-2 shocks are just right for the street, Pirelli P0 Nero M&S tire are a huge improvement over the Bridgestones, the Kartboy shifter and bushings vastly improve shift feel, and a Whiteline caster/ALK improves steering feel. I'm waiting for delivery of the Whiteline heavy duty front and rear sway bars (Addco's didn't fit, but Renick and Addco were good about refunding my money) which should work well with AVO end links. The upgrades improved it so much that I sold my '03 MR2; the LGT now handles a swell but isn't nearly as punishing, and has a much lower visual profile as well (beige wagon vs. red 2--seater with vents and wing). Link to comment Share on other sites More sharing options...
jim1969 Posted October 2, 2006 Share Posted October 2, 2006 Thanks Mat, Off to order it Edit - Damn: "Products marked with *** dont exist in desired quantity in our stock." I'll drop them a line and enquire I'd get a matched set of larger fronts and rears. I have whiteline but cusco are another option. I had my rear whiteline put on first and was happy. Then I had a larger front whiteline put in and was even happier. Link to comment Share on other sites More sharing options...
pdw Posted October 2, 2006 Share Posted October 2, 2006 The RE92's were not great but, IMO, I'd rather have bad tires on a good suspension than good tires on a bad suspension. At least with the former combination, you can feel what's going on. I had an A4 with sport suspension and that felt much better than the LGT. It was even enjoyable with the 195/65-15 snows I used in the winter. So far I've had the RE92's, Nokian WR's, Bridgestone S03's and Michelin Exalto PE2's on my stock LGT wagon. The Michelins are very nice tires and are a great compromise between grip, ride and noise. However, the LGT's biggest problem is the dampers. They suck. I don't want to go with coilovers so I'm either getting JDM Bilsteins and Pinks or waiting for the Konis. I'm also going to put a JDM rear sway on. Link to comment Share on other sites More sharing options...
Guest Posted October 2, 2006 Share Posted October 2, 2006 Yes stock Kayabas suck bug time. Bilsteins FTW! Link to comment Share on other sites More sharing options...
lhsa Posted October 2, 2006 Share Posted October 2, 2006 for a wagon, get the AVO 20mm one. don't go JDM 20mm because its too flexible for the wagon rear. This one? http://www.avoturboworld.com/avoshop/product_info.php?products_id=389 I don't see any reference to it being a JDM one though - or am i missing something Link to comment Share on other sites More sharing options...
gfxdave99 Posted October 2, 2006 Share Posted October 2, 2006 +1 on the tires... This is coming from somebody who drove on stocks for almost a year, then had my 18's with my Toyo Proxes4, fubed a rim, had to go back to stock for 2 mos and then back to new 18s with my Proxes4 and I can tell you it is a totally different car with wider 18s and better tires on it. It really helps the weighting of the steering (its slightly heavier), the car has a more 'planted' feel and doesnt have that i'm about to fly off the pavement feel you get when you push the re92s too hard. If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
