Tuned200 Posted October 21, 2006 Share Posted October 21, 2006 excelent work. your next mission is to figure out how to use the extra wire to roll the windows down. Om my 2004 pathfinder, if you hold the unlock button in with the doors shut, the front 2 windows will roll down....is this possible on a leggy? Link to comment Share on other sites More sharing options...
PolarDog Posted October 23, 2006 Share Posted October 23, 2006 excelent work. your next mission is to figure out how to use the extra wire to roll the windows down. Om my 2004 pathfinder, if you hold the unlock button in with the doors shut, the front 2 windows will roll down....is this possible on a leggy? I believe that it is. Working on this now... Link to comment Share on other sites More sharing options...
PolarDog Posted October 27, 2006 Share Posted October 27, 2006 I believe that it is. Working on this now... Okay, I have ordered a DEI 530T module (~$60) and have mapped out the wiring. More to come... PolarDog Link to comment Share on other sites More sharing options...
one69chev Posted January 15, 2007 Share Posted January 15, 2007 bump for a dying thread, found it while searching and performed the mod.... so far so good, now i'll have to rig the ejector seat, or perhaps the old slow-driver-in-the-passing-lane-machine-gun implement Link to comment Share on other sites More sharing options...
99GTL30 Posted February 26, 2007 Share Posted February 26, 2007 With the right relays, I would imagine you could use that second wire for just about anything (once you confirm its polarity). Im not sure about your cars (I drive an older Leggy), but this has definately sparked some intrest. Im going to experiment with mine & see if I can get the first push to roll up the windows/ sunroof & the secont to lock all doors & vise versa. Link to comment Share on other sites More sharing options...
Mr. Ed Posted February 28, 2007 Share Posted February 28, 2007 excelent work. your next mission is to figure out how to use the extra wire to roll the windows down. Om my 2004 pathfinder, if you hold the unlock button in with the doors shut, the front 2 windows will roll down....is this possible on a leggy? Wouldn't all of the wiring for the windows be there...just a matter of ensuring the right "signal" or voltage or whatever, were being sent from the cut red wire that we clipped? my issue right now is that I am under my car and I'm colorblind, so I am having an issue finding the right wires. good thing he was so descriptive with location! ......I could just cut them all and then randomly put them back together......... I'l post my results lol j/k ok so now finished. i couldn't tell the exact color of the "red" wire, only that it looked red and was in the right location. The green with yellow stripe was easy enough to find, again verified by location. Works great, me happy. My kiddo nd gf won't gripe at me anymore for getting the timing wrong and not unlocking their doors. THanks for the pictures! This really helps those of us with color issues Link to comment Share on other sites More sharing options...
caramall2 Posted November 23, 2007 Share Posted November 23, 2007 Finally got around to doing this mod...excellent! Couldn't get the connector to work through the tough insulation so ended up just soldering it. Link to comment Share on other sites More sharing options...
powersmp Posted November 29, 2007 Share Posted November 29, 2007 Yup, I just started this mod, but couldn't find the box of connectors I swore I had, so I soldered it as well. Better connection anyways. Works great. I always hated pushing the button twice. Link to comment Share on other sites More sharing options...
caramall2 Posted November 30, 2007 Share Posted November 30, 2007 Centerpunch, If you're still there, can you work your magic to figure out which wire opens the rear hatch on the wagon? That would be a great addition to the 4 doors. Link to comment Share on other sites More sharing options...
pdlpsher Posted December 30, 2007 Share Posted December 30, 2007 To unlock the hatch on the wagon follow the instructions on the attached thread. I successfully completed this hack on my '08 OB. There's a minor side effect now and that is the alarm light flashes even when the doors are fully unlocked. In my opinion it's a minor annoyance and a small price to pay for the convenience of a single-click unlock. Also, on my '08 OB the module is mounted differently than the pictures shown on the first post by Centerpunch. The wires to be cut are on the side closest to the steering wheel. As a result I had to remove the lower dash panel just below the steering wheel to gain access to the wires. Good luck. http://www.legacygt.com/forums/showthread.php?t=19389&highlight=unlocks Link to comment Share on other sites More sharing options...
Jeffh Posted January 31, 2008 Share Posted January 31, 2008 Has anyone tried this on an 08 Legacy? I pulled the panel off today and it looks like the wiring color codes are different. On the connector specified int he instructions, there are no red wires with a green stripe or light green wires. Has anyone else run into this? Jeff Link to comment Share on other sites More sharing options...
Lothar Posted January 31, 2008 Share Posted January 31, 2008 I'd also be interested if anybody has tried this on an '07 spec.B, or has been able to have the dealer program it? Link to comment Share on other sites More sharing options...
RockyMtnGT Posted February 2, 2008 Share Posted February 2, 2008 I've been on this site since 05...600+ posts and I never saw this thread! I've been cursing the damn 1-click, 1 door, 2 clicks, all doors, situation since I got the car! I am SO doing this mod this weekend. Thanks CP! Link to comment Share on other sites More sharing options...
vr4Legacy Posted February 2, 2008 Share Posted February 2, 2008 as for the 2nd press, I did a write up on Nasioc a few years back, same mod essentially on my '05 impreza, sounds like same wiring from reading. The polarity IIRC was a ground signal. I used a relay to pop my trunk... ordered a cheap magnetic pull from e-bay. I have hated the damn two press unlock since I got my '08, probably will get the nerve to get under there this summer. I am ineterested in the window rolldown.... keep us updated on the parts you get and where you get them... Link to comment Share on other sites More sharing options...
oak23 Posted March 9, 2008 Share Posted March 9, 2008 Anyone else try this successfully on an '08 Legacy or '08 OB? I was about to do this mod today but Jeffh's post above gives me pause (he says the wiring color codes are different - true??). I don't want to waste time taking a panel off in the cold. Link to comment Share on other sites More sharing options...
Andreu Posted March 14, 2008 Share Posted March 14, 2008 DISCLAIMER: No guarantees, but it worked for me. If your car explodes, that's your problem! I have always HATED pushing the remote button twice to unlock the car. I hated it on my Audi S4, and I hated it on my STi, and now I hate it on my GT. So, I downloaded the appropriate pages of the Legacy manual, and figured out how to fix this problem. There are two wires out of the control system. One wire sends a signal to unlock the driver's door when the button is pushed. Then if you push the button again (with the right timing, which I always get wrong), a different wire sends a signal to the other 3 doors. This mod cuts the second wire, and connects it to the first, so when you press the remote button the first time, it unlocks all four doors. THERE IS A PHOTO INCLUDED IN THIS POSTING. YOU MUST REGISTER AT THIS SITE TO VIEW THE PHOTO. PLEASE DO NOT ATTEMPT THIS MODIFICATION WITHOUT REVIEWING THE PHOTO. 1) Remove the panel under the dash on the driver's side. (1 pushpin, and 2 of those plastic pins with the philips-head 1/4 turn screw) 2) The OBDII diagnostic connector is snapped into this panel. Release it with a screwdriver so you can get this panel out of your way. 3) Put your back on the doorsill, and poke your head under the dashboard. You will see a black box under the steering column that has 3 electrical connectors plugged into it. 4) On the connector that is closest to the front of the car, examine the two wires that are on the very end. The top wire is red with a green stripe, and the wire under it is light green. 5) Cut the top wire (red with a green stripe). 6) Do NOT cut the light green wire. 7) Get one of those connectors that lets you tap on wire into another, then connect the LONG PART of the red-wire-with-a-green-stripe (the part thats coming from the wiring harness) to the light green wire. http://www.happcontrols.com/electrical_supplies/43082400.htm 8) There will be a short section of the red-wire-with-a-green-stripe that is left sticking out of the gray connector. Do not hook this to anything. Insulate the end with electrical tape. 9) Voila! It works! You know why they only open one door on the first push. Its a security feature. so if some one is in a danderous setting the drivers door only unlocks, keeping the other doors locked prevents from someone else getting into the car from another door. But kool thread i hate pushing the button too. Link to comment Share on other sites More sharing options...
dalegato Posted March 30, 2008 Share Posted March 30, 2008 Absolutely greatest upgrade...and to be free. Works without any problems. Thank you! Link to comment Share on other sites More sharing options...
Prime Power Posted April 27, 2008 Share Posted April 27, 2008 Just tried it on my 07 obxt. Now no doors lock. Link to comment Share on other sites More sharing options...
Prime Power Posted April 27, 2008 Share Posted April 27, 2008 Put it back to original state and can't even lock the doors with the remote or from the inside using the lock lever. HELP. Link to comment Share on other sites More sharing options...
Prime Power Posted April 27, 2008 Share Posted April 27, 2008 Got it fixed. Read your instructions wrong first and hooked it up to the part coming from the connector. Well, that blew a fuse. Replaced fuse and wired it up according to instructions. Working great so far. Thanks. However, it doesn't unlock the tail on the wagon, which is odd because before if you pressed it twice it would. Oh well, I have another button for that. Thanks Link to comment Share on other sites More sharing options...
jonnnyblaze Posted June 25, 2008 Share Posted June 25, 2008 question. Link to comment Share on other sites More sharing options...
jonnnyblaze Posted June 25, 2008 Share Posted June 25, 2008 question. does this mod work for the 08 version, and if so.. do the wires have the same color coating? I am interested in doing this, the double unlock feature is annoying. Thanks! Link to comment Share on other sites More sharing options...
Prime Power Posted June 26, 2008 Share Posted June 26, 2008 I believe it would, it worked on my 07. Link to comment Share on other sites More sharing options...
Albatross Posted August 25, 2008 Share Posted August 25, 2008 Hi there, I checked on my '08 LGT 5 speed, and the wires were different colors... So is it the same wire in the same place, just a different color; or the same colors, but in different places? Any one with an '08 LGT tried it yet. Thanks, Albatross. Link to comment Share on other sites More sharing options...
dammitjim Posted September 28, 2008 Share Posted September 28, 2008 Done. Great mod, thanks! What it my car trying to tell me when I hit the lock button and it beeps 5 times? Link to comment Share on other sites More sharing options...
